ralfi1
December 19, 2022, 9:42am
1
Hi all,
today morning i run the firmware update on my fritzbox 7590 to version 7.50. After that all of my certs in my apache config recognized as self-signed and nothing works anymore for all of my sub domains.
Then i try to setup a new site (see below) but this also failed with the certbot message:
Domain: trythissite.hasihome.ddnss.de
Type: connection
Detail: 2003:c0:c7ff:27a3:de15:c8ff:fe5c:6cc4: Fetching http://trythissite.hasihome.ddnss.de/.well-known/acme-challenge/N7yhigbX23pjT5riO23yM4sZFrEJWNm-7aOtwxZAX0A: Error getting validation data
After this i set my Linux server who hold all sites as "exposed host" in my fritzbox conf for looking if firtzbox firewall related but the same error appears.
Any hints?
Thanks a lot!
rg305
December 19, 2022, 10:46am
3
Hi @ralfi1 , and welcome to the LE community forum
Your question seems more suited for a Fritzbox support channel.
But since you're here...
Are these IPs correct?:
Addresses: 2003:c0:c728:f100:1049:2aec:6e3e:267b
84.182.156.166
Aliases: trythissite.hasihome.ddnss.de
The problem seems IPv6 related:
curl -Ii4 hasihome.ddnss.de
HTTP/1.1 200 OK
Date: Mon, 19 Dec 2022 10:46:10 GMT
Server: Apache
Last-Modified: Tue, 09 Nov 2021 10:19:11 GMT
ETag: "4a-5d05870d0f725"
Accept-Ranges: bytes
Content-Length: 74
Vary: Accept-Encoding
Content-Type: text/html
curl -Ii6 hasihome.ddnss.de
ralfi1
December 19, 2022, 12:22pm
4
Thanks a lot for reply,
your hint let me go the right way, two causes:
automatic recognation of changed ip addresses from dyn dns provider fails, could be related to fb firmware settings?
related to this dns failed
everything works now.
BTW, thanks for the warm welcome...
