Hello.
I got the problem installing CertBot. For some reason, it try to install python 2.6 that doesn’t exist in ports long time ago.
Ports are updated today.
root@localhost:/usr/ports/security/py-certbot # make install clean
"/usr/ports/Mk/bsd.port.mk", line 1042: Need an operator
"/usr/ports/Mk/Uses/python.mk", line 404: Could not find /usr/ports/lang/python26/Makefile.version
Usage: /usr/local/bin/python2.6-config [--prefix|--exec-prefix|--includes|--libs|--cflags|--ldflags|--help]
"/usr/ports/Mk/Uses/python.mk", line 416: warning: "/usr/local/bin/python2.6-config --abiflags" returned non-zero status
Unknown modifier 't'
"/usr/ports/Mk/bsd.port.mk", line 1741: Malformed conditional (defined(LLD_UNSAFE) && ${_TEST_LD:tA} == "/usr/bin/ld.lld")
"/usr/ports/Mk/bsd.port.mk", line 5357: if-less endif
make: fatal errors encountered -- cannot continue
Any advice would be appreciated.
