My domain is: jonmcghee.co.uk scottishlodge.co.uk
I ran this command:certonly
It produced this output:Log file
2021-11-28 16:17:49,717:DEBUG:certbot._internal.main:certbot version: 1.21.0
2021-11-28 16:17:49,717:DEBUG:certbot._internal.main:Location of certbot entry point: D:\Certbot\bin\certbot.exe
2021-11-28 16:17:49,717:DEBUG:certbot._internal.main:Arguments: ['--preconfigured-renewal']
2021-11-28 16:17:49,717:DEBUG:certbot._internal.main:Discovered plugins: PluginsRegistry(PluginEntryPoint#manual,PluginEntryPoint#null,PluginEntryPoint#standalone,PluginEntryPoint#webroot)
2021-11-28 16:17:49,786:DEBUG:certbot._internal.log:Root logging level set at 30
2021-11-28 16:17:49,786:DEBUG:certbot._internal.plugins.selection:Requested authenticator None and installer None
2021-11-28 16:17:49,786:DEBUG:certbot._internal.plugins.selection:Multiple candidate plugins: * standalone
Description: Spin up a temporary webserver
Interfaces: Authenticator, Plugin
Entry point: standalone = certbot._internal.plugins.standalone:Authenticator
Initialized: <certbot._internal.plugins.standalone.Authenticator object at 0x04553C88>
Prep: True
* webroot
Description: Place files in webroot directory
Entry point: webroot = certbot._internal.plugins.webroot:Authenticator
Initialized: <certbot._internal.plugins.webroot.Authenticator object at 0x04553F58>
Prep: True
2021-11-28 16:17:54,698:DEBUG:certbot._internal.plugins.selection:Selected authenticator <certbot._internal.plugins.webroot.Authenticator object at 0x04553F58> and installer None
2021-11-28 16:17:54,698:INFO:certbot._internal.plugins.selection:Plugins selected: Authenticator webroot, Installer None
2021-11-28 16:17:54,729:DEBUG:certbot._internal.main:Picked account: <Account(RegistrationResource(body=Registration(key=None, contact=(), agreement=None, status=None, terms_of_service_agreed=None, only_return_existing=None, external_account_binding=None), uri='https://acme-v02.api.letsencrypt.org/acme/acct/298832840', new_authzr_uri=None, terms_of_service=None), 1788522ff7b30242814e2be1fd0dd700, Meta(creation_dt=datetime.datetime(2021, 11, 28, 12, 29, 53, tzinfo=<UTC>), creation_host='Jons-PC', register_to_eff='jonmcghee77@gmail.com'))>
2021-11-28 16:17:54,745:DEBUG:acme.client:Sending GET request to https://acme-v02.api.letsencrypt.org/directory.
2021-11-28 16:17:54,745:DEBUG:urllib3.connectionpool:Starting new HTTPS connection (1): acme-v02.api.letsencrypt.org:443
2021-11-28 16:17:55,199:DEBUG:urllib3.connectionpool:https://acme-v02.api.letsencrypt.org:443 "GET /directory HTTP/1.1" 200 658
2021-11-28 16:17:55,199:DEBUG:acme.client:Received response:
HTTP 200
Server: nginx
Date: Sun, 28 Nov 2021 16:17:54 GMT
Content-Length: 658
X-Frame-Options: DENY
"2cy5fkTFLXw": "https://community.letsencrypt.org/t/adding-random-entries-to-the-directory/33417",
"meta": {
"caaIdentities": [
"letsencrypt.org"
"termsOfService": "https://letsencrypt.org/documents/LE-SA-v1.2-November-15-2017.pdf",
2021-11-28 16:17:55,199:DEBUG:certbot.display.ops:No installer, picking names manually
2021-11-28 16:18:08,368:DEBUG:certbot._internal.display.obj:Notifying user: Requesting a certificate for jonmcghee.co.uk
2021-11-28 16:18:08,551:DEBUG:certbot.crypto_util:Generating RSA key (2048 bits): C:\Certbot\keys\0012_key-certbot.pem
2021-11-28 16:18:08,561:DEBUG:certbot.crypto_util:Creating CSR: C:\Certbot\csr\0012_csr-certbot.pem
2021-11-28 16:18:08,561:DEBUG:acme.client:Requesting fresh nonce
2021-11-28 16:18:08,561:DEBUG:acme.client:Sending HEAD request to https://acme-v02.api.letsencrypt.org/acme/new-nonce.
2021-11-28 16:18:08,708:DEBUG:urllib3.connectionpool:https://acme-v02.api.letsencrypt.org:443 "HEAD /acme/new-nonce HTTP/1.1" 200 0
2021-11-28 16:18:08,708:DEBUG:acme.client:Received response:
HTTP 200
Server: nginx
Date: Sun, 28 Nov 2021 16:18:08 GMT
Replay-Nonce: 00023Djter9up7ASK6BU5TMdMh606vC5qW0IsrOx5SVF0yI
2021-11-28 16:18:08,708:DEBUG:acme.client:Storing nonce: 00023Djter9up7ASK6BU5TMdMh606vC5qW0IsrOx5SVF0yI
2021-11-28 16:18:08,708:DEBUG:acme.client:JWS payload:
b'{\n "identifiers": [\n {\n "type": "dns",\n "value": "jonmcghee.co.uk"\n }\n ]\n}'
2021-11-28 16:18:08,708:DEBUG:acme.client:Sending POST request to https://acme-v02.api.letsencrypt.org/acme/new-order:
"protected": "eyJhbGciOiAiUlMyNTYiLCAia2lkIjogImh0dHBzOi8vYWNtZS12MDIuYXBpLmxldHNlbmNyeXB0Lm9yZy9hY21lL2FjY3QvMjk4ODMyODQwIiwgIm5vbmNlIjogIjAwMDIzRGp0ZXI5dXA3QVNLNkJVNVRNZE1oNjA2dkM1cVcwSXNyT3g1U1ZGMHlJIiwgInVybCI6ICJodHRwczovL2FjbWUtdjAyLmFwaS5sZXRzZW5jcnlwdC5vcmcvYWNtZS9uZXctb3JkZXIifQ",
"signature": "Kct6qMvM9NqvTbHpMCAoHKaJT9BmcSc0yaQoS3FxYQvj6p6Ln6W54LNgoYJZo1u4H3maJmUHgXD_ijZMuz5aW4p9zfQpa3VbRN3-njVdyz47SsmSoeDDVL5LmlUuyP7KPwj5PltKXTj76UP1hEGvzOK2qScL-bsQySsVOQvkBGgbk_a84_cZaugCWuchxMiZOPShG6KQG6JV7oh5TKokRFvXNvC47NrAVAMsY0Qdg4KQmn5N6eWaIp0mNYt6W_YnX8GWaybGRfsjsRqVvq91tmKsyHB-NKKx-5rrxXf6R-H76nA_JShaBQfXL6T5d_sD3DKH2JJNJHgJ3qbvRP6D-A",
"payload": "ewogICJpZGVudGlmaWVycyI6IFsKICAgIHsKICAgICAgInR5cGUiOiAiZG5zIiwKICAgICAgInZhbHVlIjogImpvbm1jZ2hlZS5jby51ayIKICAgIH0KICBdCn0"
2021-11-28 16:18:09,109:DEBUG:urllib3.connectionpool:https://acme-v02.api.letsencrypt.org:443 "POST /acme/new-order HTTP/1.1" 201 338
2021-11-28 16:18:09,109:DEBUG:acme.client:Received response:
HTTP 201
Server: nginx
Content-Length: 338
Boulder-Requester: 298832840
Location: https://acme-v02.api.letsencrypt.org/acme/order/298832840/43173001680
Replay-Nonce: 0002ltaSKqilWyUobu5XZEfiK7juu2SFGP4T193-0VHmTVs
"status": "pending",
"expires": "2021-12-05T16:18:08Z",
"identifiers": [
"type": "dns",
"authorizations": [
"https://acme-v02.api.letsencrypt.org/acme/authz-v3/53533956310"
"finalize": "https://acme-v02.api.letsencrypt.org/acme/finalize/298832840/43173001680"
2021-11-28 16:18:09,109:DEBUG:acme.client:Storing nonce: 0002ltaSKqilWyUobu5XZEfiK7juu2SFGP4T193-0VHmTVs
2021-11-28 16:18:09,109:DEBUG:acme.client:JWS payload:
b''
2021-11-28 16:18:09,124:DEBUG:acme.client:Sending POST request to https://acme-v02.api.letsencrypt.org/acme/authz-v3/53533956310:
"protected": "eyJhbGciOiAiUlMyNTYiLCAia2lkIjogImh0dHBzOi8vYWNtZS12MDIuYXBpLmxldHNlbmNyeXB0Lm9yZy9hY21lL2FjY3QvMjk4ODMyODQwIiwgIm5vbmNlIjogIjAwMDJsdGFTS3FpbFd5VW9idTVYWkVmaUs3anV1MlNGR1A0VDE5My0wVkhtVFZzIiwgInVybCI6ICJodHRwczovL2FjbWUtdjAyLmFwaS5sZXRzZW5jcnlwdC5vcmcvYWNtZS9hdXRoei12My81MzUzMzk1NjMxMCJ9",
"signature": "nC_6MVIF5qSTlt8D9VQ9giwNNki1Ve8AS22TwOWZA2BuJlOUFrovAWAvkrdeE9PBuBrZuZbQD_XMKoisg8yIVF5wEI8Wxn1fgyyLQpB7XyP4MCl14rkfGi4tuTkcLfranfUUtrqSBuaJqPcrSZyIsSh3fonoUgbvSOQQ7Xo0piuGO-3l6JZD1vPsUp27xDvG57DH-DN1I0ucpZp_gCFYRRGzQIS2udhNIaNJ0dVfr0hdmNAJY5Au-kko7vliVxqejP1Shagv8u3jeHC6l5hArSBWDDemj_zxG3teJrU_63zGZ6mllZ4xonKpzC3tGf7mj8nHeJS0-2FYoakftbGz8Q",
"payload": ""
2021-11-28 16:18:09,272:DEBUG:urllib3.connectionpool:https://acme-v02.api.letsencrypt.org:443 "POST /acme/authz-v3/53533956310 HTTP/1.1" 200 796
2021-11-28 16:18:09,272:DEBUG:acme.client:Received response:
HTTP 200
Server: nginx
Content-Length: 796
Replay-Nonce: 0002ccnw5AVjve_ikTd-WBWkuxzdgEF47-5YUL6LfGLrOE4
"identifier": {
"type": "dns",
"challenges": [
"type": "http-01",
"url": "https://acme-v02.api.letsencrypt.org/acme/chall-v3/53533956310/f4D39Q",
"token": "IszgMGIOHIqyKNB93ND3WC-eR8cP73rFgt9KTs-oAMA"
"type": "dns-01",
"url": "https://acme-v02.api.letsencrypt.org/acme/chall-v3/53533956310/1fEjIA",
"type": "tls-alpn-01",
"url": "https://acme-v02.api.letsencrypt.org/acme/chall-v3/53533956310/OG_z1A",
2021-11-28 16:18:09,287:DEBUG:acme.client:Storing nonce: 0002ccnw5AVjve_ikTd-WBWkuxzdgEF47-5YUL6LfGLrOE4
2021-11-28 16:18:09,287:INFO:certbot._internal.auth_handler:Performing the following challenges:
2021-11-28 16:18:09,287:INFO:certbot._internal.auth_handler:http-01 challenge for jonmcghee.co.uk
2021-11-28 16:18:35,375:DEBUG:certbot._internal.plugins.webroot:Creating root challenges validation dir at D:\wamp64\www\Photos\.well-known\acme-challenge
2021-11-28 16:18:35,377:INFO:certbot._internal.plugins.webroot:Creating a web.config file in D:\wamp64\www\Photos\.well-known\acme-challenge to allow IIS to serve challenge files.
2021-11-28 16:18:35,377:DEBUG:certbot._internal.plugins.webroot:Attempting to save validation to D:\wamp64\www\Photos\.well-known\acme-challenge\IszgMGIOHIqyKNB93ND3WC-eR8cP73rFgt9KTs-oAMA
2021-11-28 16:18:35,377:DEBUG:acme.client:JWS payload:
b'{}'
2021-11-28 16:18:35,377:DEBUG:acme.client:Sending POST request to https://acme-v02.api.letsencrypt.org/acme/chall-v3/53533956310/f4D39Q:
"protected": "eyJhbGciOiAiUlMyNTYiLCAia2lkIjogImh0dHBzOi8vYWNtZS12MDIuYXBpLmxldHNlbmNyeXB0Lm9yZy9hY21lL2FjY3QvMjk4ODMyODQwIiwgIm5vbmNlIjogIjAwMDJjY253NUFWanZlX2lrVGQtV0JXa3V4emRnRUY0Ny01WVVMNkxmR0xyT0U0IiwgInVybCI6ICJodHRwczovL2FjbWUtdjAyLmFwaS5sZXRzZW5jcnlwdC5vcmcvYWNtZS9jaGFsbC12My81MzUzMzk1NjMxMC9mNEQzOVEifQ",
"signature": "iSf78IOb-G6kC1e2NfCDAYj-9E86ZVG5W0Nfzfkrf3OLEtEmzU-VGjqEAdtCSh1tjvNx7z-LGz_7D1imkti0jaSoU9zdsnyK4A26Rvw00nCEPnoLUHOsFRhHhukLq0aVX806g8QEbHUwb24-qou4TZrXmMt6iz71PABuLLHHiToSS3I9QHdV3gC8g0IodIOyb3dU_aa8eYDfa3s77IJ-YExZGsc3JyrKdriwIAFLURAnQBfiZ_jY4Wpof09tZYI3oA0kik6yb8dcq0siW2vDstjLKbWlmnZe45t5jstXqJZBe-WGdDEokOf58e1_AOVfn2x8FSJaGN2HCZzHwd8W_A",
"payload": "e30"
2021-11-28 16:18:35,557:DEBUG:urllib3.connectionpool:https://acme-v02.api.letsencrypt.org:443 "POST /acme/chall-v3/53533956310/f4D39Q HTTP/1.1" 200 186
2021-11-28 16:18:35,557:DEBUG:acme.client:Received response:
HTTP 200
Server: nginx
Date: Sun, 28 Nov 2021 16:18:34 GMT
Content-Length: 186
Link: <https://acme-v02.api.letsencrypt.org/directory>;rel="index", <https://acme-v02.api.letsencrypt.org/acme/authz-v3/53533956310>;rel="up"
Location: https://acme-v02.api.letsencrypt.org/acme/chall-v3/53533956310/f4D39Q
Replay-Nonce: 0002-EJXLbS8lsl7QuaY1-k6DWTsNhlxFfSpREvMG7UZluY
"type": "http-01",
2021-11-28 16:18:35,557:DEBUG:acme.client:Storing nonce: 0002-EJXLbS8lsl7QuaY1-k6DWTsNhlxFfSpREvMG7UZluY
2021-11-28 16:18:35,557:INFO:certbot._internal.auth_handler:Waiting for verification...
2021-11-28 16:18:36,575:DEBUG:acme.client:JWS payload:
b''
2021-11-28 16:18:36,575:DEBUG:acme.client:Sending POST request to https://acme-v02.api.letsencrypt.org/acme/authz-v3/53533956310:
"protected": "eyJhbGciOiAiUlMyNTYiLCAia2lkIjogImh0dHBzOi8vYWNtZS12MDIuYXBpLmxldHNlbmNyeXB0Lm9yZy9hY21lL2FjY3QvMjk4ODMyODQwIiwgIm5vbmNlIjogIjAwMDItRUpYTGJTOGxzbDdRdWFZMS1rNkRXVHNOaGx4RmZTcFJFdk1HN1VabHVZIiwgInVybCI6ICJodHRwczovL2FjbWUtdjAyLmFwaS5sZXRzZW5jcnlwdC5vcmcvYWNtZS9hdXRoei12My81MzUzMzk1NjMxMCJ9",
"signature": "XC6rbhhWhF9zOZJL-gxl-_thlURC3fTY-5kp1fOFbfJktYGA0XnfLPpRct3L3WwPZr81GXB6sykWIJzMzjdZn229uCpsxyNZS_QsxT6qP4ssHGmT_5lWK6N4lnrS6mhG6PcjOvh37E-WfGMEpkJIzNAOj9moIyzZ38SjxZdrAq1cJQjqTf5EkYRYmeGFjlkzEiLhjU6-aN3UPvmH15UIYw0mIuNGfTHFNRwqbpuBsfkCIeo1DQy0PNSIDz-KdPJ7RI_HxryRY3G7x0D4uaBzR4CHsO9fpQzGn07LEuLOrP3Rqii-OagBQNaYTz5W5cdp6Gjc6I-K29hhmx8zYc97Sg",
"payload": ""
2021-11-28 16:18:36,754:DEBUG:urllib3.connectionpool:https://acme-v02.api.letsencrypt.org:443 "POST /acme/authz-v3/53533956310 HTTP/1.1" 200 1215
2021-11-28 16:18:36,754:DEBUG:acme.client:Received response:
HTTP 200
Server: nginx
Date: Sun, 28 Nov 2021 16:18:36 GMT
Content-Length: 1215
Replay-Nonce: 0001X6b-x4ofo3HnYc2i8Q4bFGgXw9Y_cNF7L39-eh20_5Y
"identifier": {
"type": "dns",
"status": "invalid",
"challenges": [
"type": "http-01",
"error": {
"type": "urn:ietf:params:acme:error:unauthorized",
"detail": "Invalid response from http://jonmcghee.co.uk/.well-known/acme-challenge/IszgMGIOHIqyKNB93ND3WC-eR8cP73rFgt9KTs-oAMA [94.136.40.82]: \"\u003c!DOCTYPE HTML PUBLIC \\\"-//W3C//DTD HTML 4.01 Frameset//EN\\\" \\\"http://www.w3.org/TR/html4/frameset.dtd\\\"\u003e\\r\\n\u003chtml lang=\\\"en\\\"\u003e\\r\\n\u003chead\u003e\u003c\"",
"status": 403
"token": "IszgMGIOHIqyKNB93ND3WC-eR8cP73rFgt9KTs-oAMA",
"validationRecord": [
"url": "http://jonmcghee.co.uk/.well-known/acme-challenge/IszgMGIOHIqyKNB93ND3WC-eR8cP73rFgt9KTs-oAMA",
"hostname": "jonmcghee.co.uk",
"port": "80",
"addressesResolved": [
"94.136.40.82"
"addressUsed": "94.136.40.82"
"validated": "2021-11-28T16:18:34Z"
2021-11-28 16:18:36,754:DEBUG:acme.client:Storing nonce: 0001X6b-x4ofo3HnYc2i8Q4bFGgXw9Y_cNF7L39-eh20_5Y
2021-11-28 16:18:36,754:INFO:certbot._internal.auth_handler:Challenge failed for domain jonmcghee.co.uk
2021-11-28 16:18:36,754:INFO:certbot._internal.auth_handler:http-01 challenge for jonmcghee.co.uk
2021-11-28 16:18:36,754:DEBUG:certbot._internal.display.obj:Notifying user:
Domain: jonmcghee.co.uk
Detail: Invalid response from http://jonmcghee.co.uk/.well-known/acme-challenge/IszgMGIOHIqyKNB93ND3WC-eR8cP73rFgt9KTs-oAMA [94.136.40.82]: "<!DOCTYPE HTML PUBLIC \"-//W3C//DTD HTML 4.01 Frameset//EN\" \"http://www.w3.org/TR/html4/frameset.dtd\">\r\n<html lang=\"en\">\r\n<head><"
2021-11-28 16:18:36,754:DEBUG:certbot._internal.error_handler:Encountered exception:
File "D:\Certbot\pkgs\certbot\_internal\auth_handler.py", line 90, in handle_authorizations
File "D:\Certbot\pkgs\certbot\_internal\auth_handler.py", line 178, in _poll_authorizations
2021-11-28 16:18:36,754:DEBUG:certbot._internal.error_handler:Calling registered functions
2021-11-28 16:18:36,754:INFO:certbot._internal.auth_handler:Cleaning up challenges
2021-11-28 16:18:36,754:DEBUG:certbot._internal.plugins.webroot:Removing D:\wamp64\www\Photos\.well-known\acme-challenge\IszgMGIOHIqyKNB93ND3WC-eR8cP73rFgt9KTs-oAMA
2021-11-28 16:18:37,261:INFO:certbot._internal.plugins.webroot:Cleaning web.config file generated by Certbot in D:\wamp64\www\Photos\.well-known\acme-challenge.
2021-11-28 16:18:37,261:DEBUG:certbot._internal.plugins.webroot:All challenges cleaned up
2021-11-28 16:18:37,261:DEBUG:certbot._internal.log:Exiting abnormally:
File "runpy.py", line 197, in _run_module_as_main
File "runpy.py", line 87, in _run_code
File "D:\Certbot\bin\certbot.exe\__main__.py", line 29, in <module>
sys.exit(main())
File "D:\Certbot\pkgs\certbot\main.py", line 15, in main
File "D:\Certbot\pkgs\certbot\_internal\main.py", line 1574, in main
File "D:\Certbot\pkgs\certbot\_internal\main.py", line 1434, in certonly
lineage = _get_and_save_cert(le_client, config, domains, certname, lineage)
File "D:\Certbot\pkgs\certbot\_internal\main.py", line 133, in _get_and_save_cert
File "D:\Certbot\pkgs\certbot\_internal\client.py", line 459, in obtain_and_enroll_certificate
File "D:\Certbot\pkgs\certbot\_internal\client.py", line 389, in obtain_certificate
File "D:\Certbot\pkgs\certbot\_internal\client.py", line 439, in _get_order_and_authorizations
2021-11-28 16:18:37,261:ERROR:certbot._internal.log:Some challenges have failed.
My web server is (include version):WAMP Ver 3.2.3
The operating system my web server runs on is (include version):Windows 10
or certbot-auto --version
if you're using Certbot):Not sure, just downloaded it today
