My domain is: budeshi.ng
I ran this command: certbot install --cert-name budeshi.ng
It produced this output: File: /etc/apache2/sites-available/le-redirect-https://budeshi.ng.conf - Could not be found to be deleted
Certbot probably shut down unexpectedly
An unexpected error occurred:
FileNotFoundError: [Errno 2] No such file or directory: '/etc/apache2/sites-available/le-redirect-https://budeshi.ng.conf'
My web server is (include version): apache2
The operating system my web server runs on is (include version): Linux ubuntu-g-2vcpu-8gb-lon1-01 5.4.0-126-generic
My hosting provider, if applicable, is: DigitalOcean
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 1.30.0
In addition to the above, I'm also interested in the contents of any configuration file in /etc/apache2/. To me it sounds like the Apache configuration files parser from Certbot chokes on some specific part of the configuration file where it tries to include a certain file which obviously can't exist.
Thanks for the response! And thanks for the welcome!
I managed to solve this. I added a le-redirect-https:/ folder, and in it I added an empty budeshi.ng.conf file, and it worked!
I don't know if that's the best solution, but my server is running now.
This is the response form certbot certificates:
Certificate Name: budeshi.ng
Serial Number: 49588c06474c4d302171a7114ada3c6d863
Key Type: RSA
Domains: budeshi.ng
Expiry Date: 2022-12-24 15:30:47+00:00 (VALID: 89 days)
Certificate Path: /etc/letsencrypt/live/budeshi.ng/fullchain.pem
Private Key Path: /etc/letsencrypt/live/budeshi.ng/privkey.pem
