fFailed to verify temporary files,trying for two weeks desparate
My domain is: quantummobileai.com
I ran this command: certbot -v
It produced this output:certbot -v
We recommend selecting either all domains, or all domains in a VirtualHost/server block.
1: quantummobileai.com
2: www.quantummobileai.com
Requesting a certificate for quantummobileai.com and www.quantummobileai.com
http-01 challenge for quantummobileai.com
http-01 challenge for www.quantummobileai.com
Challenge failed for domain quantummobileai.com
Challenge failed for domain www.quantummobileai.com
Domain: quantummobileai.com
Detail: 2a02:4780:2b:1725:0:d37:d377:2: Invalid response from http://quantummobileai.com/.well-known/acme-challenge/AgEF-3S_1uSrFOpzZefYqIsGS2bD0kLKUWZnlAd9xZQ: 404
Domain: www.quantummobileai.com
Detail: 2a02:4780:2b:1725:0:d37:d377:2: Invalid response from http://www.quantummobileai.com/.well-known/acme-challenge/62j0-ygVATspPzdl442KG3uJQ44uOrVoJJGHk0nZENg: 404
Ask for help or search for solutions at https:/
My hosting provider, if applicable, is: Hostinger
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot):certbot 2.11.0
See: Let's Debug
You have both an IPv4 A record and an IPv6 AAAA record in your DNS
But, the IPv6 address points to a Hostinger service not your server. Hostinger creates this AAAA record automatically for new setups.
You need to update the AAAA address or remove it if you do not support IPv6.
Any client trying to use IPv6 will connect to that Hostinger service instead of your server.
Let's Encrypt favors IPv6 when an AAAA record is present.
See Hostinger article here: How to manage AAAA records | Hostinger Help Center
I can't thank you enough! how good it was to se that padlock close. I honestly don't know if I would ever have solved that problem. Always more to learn it's been humbling I'm very grateful! Thanks so much ! that just made my day.
You are welcome. We see that problem often with Hostinger
Usually we ask you to mark the post that solved it as the Solution but ... :slight_smile:
new to this as well done!
