Fetching standalone OCSP result does not work
sebbe.eu
openssl ocsp -issuer cacert.pem -cert ocspcert.pem -url http://ocsp.int-x3.letsencrypt.org -header “HOST” “ocsp.int-x3.letsencrypt.org” -respout ocsptest
Responder Error: unauthorized (6)
cacert.pem is:
-----BEGIN CERTIFICATE-----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-----END CERTIFICATE-----
ocspcert.pem is:
What im doing wrong? Why im getting a unauthorized response from the OCSP responder?
ooh found it…
Turned out I copied the wrong certificate from the chain file.
Both certs are idetical.
ocspcertficate.pem should be: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A bit complicated to find which certificate is which, especially in a fullchain.pem file
Anyways, now I get the following:
WARNING: no nonce in response
Response Verify Failure
140482443708056:error:27069076:OCSP routines:OCSP_basic_verify:signer certificate not found:ocsp_vfy.c:92:
ocspcert.pem: good
This Update: Nov 15 11:00:00 2017 GMT
Next Update: Nov 22 11:00:00 2017 GMT
“signer certificate not found”?
Which certificate is the OCSP responses signed with?
Hi @sebastiannielsen,
Use this command instead:
openssl ocsp -no_nonce -issuer cacert.pem -cert ocspcert.pem -VAfile cacert.pem -text -url http://ocsp.int-x3.letsencrypt.org/ -header Host ocsp.int-x3.letsencrypt.org -respout ocsptest
Cheers,
sahsanu
