Failure with Let's Encrypt using NextCloud guide
Nothing, after to check your commands nothing. My error is the same on the beginning
steve@Server:~$ netstat -ptan | grep LISTEN | grep nginx
(Not all processes could be identified, non-owned process info
will not be shown, you would have to be root to see it all.)
steve@Server:~$ ss -pln | grep nginx
steve@Server:/root# chmod +x /root/permissions.sh && /root/permissions.sh
chmod: cannot access ‘/etc/letsencrypt/live/myid.duckdns.org/fullchain.pem’: No such file or directory
chmod: cannot access ‘/etc/letsencrypt/live/myid.duckdns.org/privkey.pem’: No such file or directory
chmod: cannot access ‘/etc/letsencrypt/live/myid.duckdns.org/chain.pem’: No such file or directory
chmod: cannot access ‘/etc/letsencrypt/live/angus.duckdns.org/cert.pem’: No such file or directory
steve@Server:~$ curl -ikL http://127.0.0.1:81/.well-known/acme-challenge/testHTTP/1.1 403 Forbidden
Server: nginx
Date: Sat, 26 May 2018 10:45:10 GMT
Content-Type: text/html; charset=utf-8
Content-Length: 162
X-Content-Type-Options: nosniff
X-XSS-Protection: 1; mode=block
Referrer-Policy: same-origin
403 Forbidden
403 Forbidden
nginx steve@Server:~$ grep 'acme-challenge' /var/log/nginx/le.*.log /var/log/nginx/le.access.log:127.0.0.1 - - [25/May/2018:12:45:10 +0200] "GET /.well-known/acme-challenge/test HTTP/1.1" 403 162 "-" "curl/7.47.0" "-" "127.0.0.1" sn="127.0.0.1" rt=0.000 ua="-" us="-" ut="-" ul="-" cs=- /var/log/nginx/le.error.log:2018/05/25 12:45:10 [error] 6305#6305: *1 open() "/var/www/letsencrypt/.well-known/acme-challenge/test" failed (13: Permission denied), client: 127.0.0.1, server: 127.0.0.1, request: "GET /.well-known/acme-challenge/test HTTP/1.1", host: "127.0.0.1:81"
Hi @SimonLoe,
Above commands should be executed as user root or with sudo from your user.
Seems nginx user doesn't have access to that file (or dirs), could you please show the output of this command (as root):
namei -mo /var/www/letsencrypt/.well-known/acme-challenge/test
Cheers,
sahsanu
