FAILURE of renewal due to DNS problem
My domain is: https://sapakreatif.com
The operating system my web server runs on is (include version): I don't know
My hosting provider, if applicable, is: niagahoster.com
I'm using a control panel to manage my site (no, or provide the name and version of the control panel): Cpanel
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): i don't know
I was sent this email
Automatic Let's Encrypt renewal for sapakreatif.com was attempted and failed.
This certificate expires on 2022-04-05 17:10:16 +0700 WIB.
Unable to renew certificate: Updating challenge for ipv6.sapakreatif.com: acme: error code 400 "urn:ietf:params:acme:error:dns": DNS problem: NXDOMAIN looking up TXT for _acme-challenge.ipv6.sapakreatif.com - check that a DNS record exists for this domain (order URL: https://acme-v02.api.letsencrypt.org/acme/order/350155820/71576283490)
You can configure/re-install/remove this certificate by logging into cPanel, and visiting the Lets Encrypt SSL page.
Welcome to the community @meisterakbar
Can you explain more what you are trying to do?
I ask because I see your main domain name sapakreatif.com server is using a Cloudflare cert which you got on Jan16 2022 which does not expire for a year.
Before you setup Cloudflare you got a cert from Let's Encrypt (maybe with cPanel?) on Jan5 2022.
I am guessing the cert you got on Jan5 needs to be changed for your newer Cloudflare configuration. But, it would help if you would explain what you are trying to do. Thanks
If you originally set up your certificate with DNS validation in cPanel, it means you were using cPanel nameservers for your domain at the time.
I would guess that you have since moved your domain to Cloudflare nameservers. This means that you can no longer use the DNS validation method within cPanel, because cPanel does not have access to modify your DNS records in Cloudflare.
What you can do is login to cPanel and recreate the certificate through the Lets Encrypt SSL interface, choosing the HTTP validation method instead.
Except that ipv6.sapakreatif.com doesn't resolve to any IP (presently) - and may require DNS-01 authentication to obtain a certificate. [catch-22]
Maybe there is some clever way to use CNAME that can overcome this limitation.
Hi Mike,
I was trying to renew my SSL Certificate, and yes, my certificate was registered before I configured the Cloudflare.
Oh, and I didn't that cPanel can't modify my records in Cloudflare. So, I'll have to delete my current certificate and issue a new one using the HTTP method?
Just issue a new one without deleting the current one.
Or ask cloudflare for a certificate from their "origin CA"
Well... You only need a TXT record on _acme-challenge.ipv6.sapakreatif.com
ipv6.sapakreatif.com can NXDOMAIN all it wants.
NXDOMAIN means that subdomains don't exist as well. If a subdomain exists, but there's just no record for the subdomain level being requested, it should still return NOERROR. (So if _acme-challenge.name.example is supposed to have a TXT record, then name.example needs to return NOERROR with no records instead of NXDOMAIN.) This has been a common source of confusion in some DNSSEC implementations, though.
Didn't know that.
