Failing to issue certificates
My domain is: etherealplayground.com
I ran this command: sudo certbot --apache --agree-tos --preferred-challenges http -d etherealplayground.com
http-01 challenge for etherealplayground.com
Challenge failed for domain etherealplayground.com
    Domain: etherealplayground.com
    Type: connection
    Detail: 2601:701:c200:c9b0:1195:7743:3b67:f432: Fetching
    http://etherealplayground.com/.well-known/acme-challenge/mAMnYnklJVoYRG5zgmJQklx7sxK4hOGOOMadCCoD6iI:
    Network unreachable
My web server is (include version): ehcp (newest version)
The operating system my web server runs on is (include version): ubuntu 20.4'ish
My hosting provider, if applicable, is: comcast
I'm using a control panel to manage my site (no, or provide the name and version of the control panel): ehcp
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): 0.40.0
I did some searches and seen that the best way to use openssl for ehcp was to do some kind of all in one domain ssl certificates for all at once. So I decided to try to do it myself with lets encrypt not finding much data and went for doing them individually myself. I'm looking for some guidance on this topic directly or for ehcp with openssl.
Hi @layz1307,
It looks like your Comcast IP address can't receive incoming connection from the rest of the Internet. The ability to receive connections from the outside world is a requirement for the method that you're using to try to get the certificate.
It could be blocked by a firewall run by Comcast, or a firewall policy on your own router, or maybe Comcast requires customers to opt-in to receiving connections from the public Internet, or maybe it was a dynamic IP address that you were allocated in the past but that doesn't match your current IP address?
These are all just guesses, but the problem you're encountering relates to the ability of others to connect to your service on your IPv6 address.
Addresses: 2601:701:c200:c9b0:1195:7743:3b67:f432
           10.0.0.228
You should ensure you provide only Internet routable IPs.
The 10 dot network is not routable over the Internet.
do you have a way to test the first reply?
I have etherealplayground.com running, and it should be able to be hit by the outside world all that is there now is a text telling you its ran by ehcp and gives ips.
I'm not familiar with "ehcp".
Does it support IPv6?
That was a mistake im using apache
EHCP is the control panel im using.
This is not likely to be a problem with the server software. We get an ICMPv6 message back from a Comcast router indicating that the IPv6 address is unroutable.
17:38:23.897869 IP6 2001:558:2d2:ffff::2 > demorgan: ICMP6, destination unreachable, unreachable route 2601:701:c200:c9b0:1195:7743:3b67:f432, length 88
OK, since you are using Apache.
I would start with the output of:
sudo apachectl -t -D DUMP_VHOSTS
There are strong indications here it's a network problem, not an Apache configuration problem.
OR
Both - LOL
@layz1307, from the server, please also show the outputs of:
curl -4 ifconfig.io
curl -6 ifconfig.io
root@73:~# sudo apachectl -t -D DUMP_VHOSTS
AH00548: NameVirtualHost has no effect and will be removed in the next release /etc/apache2/ports.conf:10
VirtualHost configuration:
: is a NameVirtualHost
default server default (/etc/apache2/sites-enabled/default:3)
port * namevhost default (/etc/apache2/sites-enabled/default:3)
port * namevhost webmail.etherealplayground.com (/var/www/new/ehcp/webserver_ehcp.conf:7)
alias mail.etherealplayground.com
alias email.etherealplayground.com
port * namevhost webmail2.etherealplayground.com (/var/www/new/ehcp/webserver_ehcp.conf:25)
alias mail2.etherealplayground.com
alias email2.etherealplayground.com
port * namevhost cpanel.etherealplayground.com (/var/www/new/ehcp/webserver_ehcp.conf:40)
alias panel.etherealplayground.com
alias ehcp.etherealplayground.com
alias cp.etherealplayground.com
port * namevhost etherealplayground.com (/var/www/new/ehcp/webserver_ehcp.conf:55)
alias www.etherealplayground.com
port * namevhost webmail.thronesoftime.net (/var/www/new/ehcp/webserver_ehcp.conf:93)
alias mail.thronesoftime.net
alias email.thronesoftime.net
port * namevhost webmail2.thronesoftime.net (/var/www/new/ehcp/webserver_ehcp.conf:111)
alias mail2.thronesoftime.net
alias email2.thronesoftime.net
port * namevhost cpanel.thronesoftime.net (/var/www/new/ehcp/webserver_ehcp.conf:126)
alias panel.thronesoftime.net
alias ehcp.thronesoftime.net
alias cp.thronesoftime.net
port * namevhost thronesoftime.net (/var/www/new/ehcp/webserver_ehcp.conf:141)
alias www.thronesoftime.net
root@73:~# curl -4 ifconfig.io
73.27.126.62
root@73:~# curl -6 ifconfig.io
2601:701:c200:d680::9c56
i did not have my ipv6 set on ehcp and im going to test it while set with the outside ip that i just got from apache
This is different from your address in DNS:
They're only the same as far as 2601:701:c200 which is, I guess, Comcast in Florida.
It might be that your Comcast account, or your home router, currently does not allow incoming IPv6 connections. (Also, where did you get the address 2601:701:c200:c9b0:1195:7743:3b67:f432 that you have listed in DNS?)
In theory with IPv6 you can have multiple devices on a home connection accept connections directly from the Internet, but your router or ISP might not allow this by default because many people are no longer accustomed to actually being reachable by the whole public Internet.
im having some other problems after rebooting atm, im going to have to sort through before i can continue
I'm unfamiliar with the use of "*" there.
Are there any listen statements within the file?:
I have reinstalled my ehcp (cpanel equivalent) and this is what im getting now after redoing some of the ip configurations.
I stopped the firewall this way before running it a second time.
root@micromedia:~/ehcp# sudo ufw disable
Firewall stopped and disabled on system startup
root@micromedia:~/ehcp# sudo certbot --apache --agree-tos --preferred-challenges http -d etherealplayground.com
    Type: connection
    Detail: 73.27.126.62: Fetching
    http://etherealplayground.com/.well-known/acme-challenge/OVO7Nt88gdlHmDQQUKyK-jFNUl7d5tIJJjxcBVu7cEA:
what's that servers ip?
curl ifconfig.me
ip addr
root@micromedia:~# curl ifconfig.me
73.27.126.62
Previously you didn't have your IPv4 address in DNS (only IPv6); now you have both.
They give different errors when trying to connect to them from outside. The IPv6 address still has Comcast (apparently) actively giving an error and not agreeing to route to it, while the IPv4 address has a timeout which is indeed suggestive of a firewall.
Have you ever been able to connect to either of these addresses successfully from a device that wasn't on your home network?
