Failed to renew certificate on OSX running apache homebrew
I get the following when I try and renew a certificate using
sudo cerbot renew --dry-run
I get the following exception and also apache crashes any help welcome :slight_smile:
Processing /etc/letsencrypt/renewal/jamalade.duckdns.org.conf
tls-sni-01 challenge for jamalade.duckdns.org
No vhost exists with servername or alias of: jamalade.duckdns.org (or it’s in a file with multiple vhosts, which Certbot can’t parse yet). No vhost was selected. Please specify ServerName or ServerAlias in the Apache config, or split vhosts into separate files.
Falling back to default vhost *:443…
Waiting for verification…
Attempting to renew cert from /etc/letsencrypt/renewal/jamalade.duckdns.org.conf produced an unexpected error: Failed authorization procedure. jamalade.duckdns.org (tls-sni-01): urn:acme:error:unauthorized :: The client lacks sufficient authorization :: Incorrect validation certificate for TLS-SNI-01 challenge. Requested 1c44043bc1893a0c93193cf4a0a63a15.376346324440dcc2883226a472976eb6.acme.invalid from 86.6.118.75:443. Received 2 certificate(s), first certificate had names “jamalade.duckdns.org”. Skipping.
/etc/letsencrypt/live/jamalade.duckdns.org/fullchain.pem (failure)
    Domain: jamalade.duckdns.org
    Detail: Incorrect validation certificate for TLS-SNI-01 challenge.
    Requested
    Nicks-MacBook-Pro:~ nickpoaros$ sudo apachectl -k start
    Password:
Has your vhost file changes since you obtained the certificate ?
You may be better obtaining a new cert using the “webroot” option which will mean it can then renew more easily without needing the vhost configuration.
Thanks for your advice - I re-run with webroot and -certonly only which seems to work except that in the browsers the old expiry is showing also when I run certbot certificates i get the following error for cert.perm
OCSP check failed for /etc/letsencrypt/live/jamalade.duckdns.org/cert.pem (are we offline?
the full chain and privacy look fine.
I am a bit confused
If you refresh in your browser are you still getting an old certificate ? from a quick check I get
$ certinfo jamalade.duckdns.org
getting cert from server - jamalade.duckdns.org
Certificate chain
 0 s:/CN=jamalade.duckdns.org
   i:/C=US/O=Let's Encrypt/CN=Let's Encrypt Authority X3
 1 s:/C=US/O=Let's Encrypt/CN=Let's Encrypt Authority X3
Certificate:
Issuer: C=US, O=Let's Encrypt, CN=Let's Encrypt Authority X3
Not Before: Feb 14 19:51:00 2017 GMT
Not After : May 15 19:51:00 2017 GMT
Subject: CN=jamalade.duckdns.org
Public Key Algorithm: rsaEncryption
DNS:jamalade.duckdns.org, DNS:www.jamalade.duckdns.org
Hi yes I was in the end i needed to reboot the machine and then all fine. not quite sure why starting stopping apache didn’t do the trick but hey ho.
thanks for the help all running sweet now.
