This is the two files for my apache conf file please check it
Once checked please let me know will remove the link
Possibly stupid question: is mod_ssl installed and enabled? You can install it using yum install mod_ssl or check if itâs enabled via httpd -M.
hello itâs already installed and i have installed the certificate also
Could you please see below
[root@ip-172-31-19-172 ~]# yum list mod_ssl
Loaded plugins: priorities, update-motd, upgrade-helper
Installed Packages
mod_ssl.x86_64 1:2.2.31-1.8.amzn1 @amzn-main
[root@ip-172-31-19-172 ~]# httpd -M | grep ssl
Syntax OK
I have already told first I have installed certificate for main domain , but am not able to setup for sub domains at the time only i got error
The important bit is whatâs on the server right now, not previously. Just to clarify: You currently have no domains/other vhosts on this server that work via HTTPS, correct?
Anyhow, the mod_ssl situation looks fine. I donât see anything in the two config files you shared that would cause this. Are there any other files containing vhosts, and what are their contents? grep -r VirtualHost /etc/httpd should do.
Yes I have other files.
check the following file for ssl configuartion part i have done for same thing other domains also.
I need to setup ssl cert atleast any one of the domain probably
For all other vhosts that are for port 443, can you verify that each of them contains SSLEngine On? For the file you posted, this is probably done via Include /etc/letsencrypt/options-ssl-apache.conf, which should contain that line, but if you have any other vhosts on port 443 that do not include that directive, this could be causing what you're seeing here.
If that's not the issue, take a look at this post:
My opinion is letsencrypt has been blocked my server IP trying to verify while creating the ssl certificate. acme-v01.api.letsencrypt.org
Just now am tring to create certifictae with only one domain i got below error.
Command i have executed
./letsencrypt-auto --apache -d www.bezirk.com
Failed authorization procedure. www.bezirk.com (tls-sni-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: Failed to connect to 54.218.126.252:443 for TLS-SNI-01 challenge
This above problem I am getting you people telling configuration part I think there is no configuration error in apache level.
Ok i will check let you know
I have installed the certificate for www.bezirk.com bu am not able to setup for sub domains.
I have executed letsencrypt-auto --debug and successfully installed but not works for sub doamins.
I have installed the certificates for all the domain.
But i having problem with sub domains itâs redirecting to default apache page the main site working properly
