Failed authorization procedure. mydomain (tls-sni-01): urn:acme:error:connection
I can’t issue a letsencrypt cert by running:
sudo letsencrypt certonly \
  --standalone \
  -d itsnikolay.ru
I get the following exception:
Failed authorization procedure. itsnikolay.ru (tls-sni-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: Failed to connect to 178.62.204.132:443 for TLS-SNI-01 challenge
   Domain: itsnikolay.ru
   Type:   connection
   Detail: Failed to connect to 178.62.204.132:443 for TLS-SNI-01
   challenge
I made sure those tips by running the following command:
curl 178.62.204.132:443
curl itsnikolay.ru:443
curl 178.62.204.132
curl itsnikolay.ru
And they pass!
What’s wrong?
You are currently providing http on port 443 via an nginx server.
If you are using the standalone method, you need to shut down the existing services on ports 80 / 443.
I turned off nginx server
But it still fails
nginx is still running when I test from here to your IP
$ curl -I http://itsnikolay.ru:443
HTTP/1.1 200 OK
Server: nginx/1.6.2
Date: Tue, 11 Oct 2016 09:46:40 GMT
Content-Type: text/html; charset=utf-8
Sorry, Monit run Nginx
now I disable Monit and Nginx, but the same stuff is till here:
❯ curl -I http://itsnikolay.ru:443
curl: (7) Failed to connect to itsnikolay.ru port 443: Connection refused
❯ sudo letsencrypt certonly \        project-notes/git/master !
  --standalone \
  -d itsnikolay.ru
   Type:   connection
   challenge
Hi @itsNikolay,
Could you have any kind of firewall that either (1) prevents certain programs from listening on port 443, or (2) prevents certain IP addresses from making inbound connections to your server?
Sorry, my fault
Letsencrypt command should be run from the same server wherever the domain follows
Note that if this isn’t possible, the DNS challenge type can sometimes help – it’s supported by several of the bash clients and now by Certbot in 0.9.0 and later versions. But you would have to be able to update DNS records for the subject domain from the machine where you’re running whichever Let’s Encrypt client.
