Failed authorization procedure. example.com (tls-sni-01): urn:acme:error:unauthorized :: The client lacks sufficient authorization :: Correct zName not found for TLS SNI challenge. Found ‘www.example.com, example.com’, example.com (tls-sni-01): urn:acme:error:unauthorized :: The client lacks sufficient authorization :: Correct zName not found for TLS SNI challenge. Found ‘*.herokuapp.com, herokuapp.com’, example.com (tls-sni-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: Failed to connect to host for DVSNI challenge
What command are you using ? (with correct domain names if you’re happy to provide - they will be publicly available on the cert anyway )
There is a mixture of *.herokuapp.com, herokuapp.com and example.com in the response here. Did you include “example.com” or is that just you editing to hide your domain ?
