Facing issue with cert activation
animebob.in
sudo certbot certonly --webroot --webroot-path /home/ubuntu/autolycus -d animebob.in
ubuntu@movies3-storage:~$ sudo certbot certonly --webroot --webroot-path /home/ubuntu/autolycus -d an imebob.in
Requesting a certificate for animebob.in
Certbot failed to authenticate some domains (authenticator: webroot). The Certificate Authority report ed these problems:
Domain: animebob.in
Detail: 129.159.20.202: Invalid response from Autolycus s7B9frqtspgjlRAsF1P-2xnN-E9fpS7vGNo: "\n<html lang="en">\n \n <meta charset ="utf-8" />\n <link rel="icon" href="/autolycus/icons/bx-meteor.svg"
Hint: The Certificate Authority failed to download the temporary challenge files created by Certbot. E nsure that the listed domains serve their content from the provided --webroot-path/-w and that files c reated there can be downloaded from the internet.
ubuntu 22.04
oracle instance added 80, 443 in ingress rules
no
certbot 1.21.0
can someone help me pls
extra information, : i've installed with same command in other instance 1 day before, now i've deleted that instane and created a new one and trying again
using cloudflare.(no proxy option on in dns records)
Welcome @bharathganji1
Can you show us the nginx server block for the animebob.in domain? I want to check that the webroot path in your certbot command is correct given how you redirect the acme challenge request.
curl -IL animebob.in/.well-known/acme-challenge/Test123
HTTP/1.1 302 Found
Server: nginx/1.17.10
Location: /autolycus/.well-known/acme-challenge/Test123
upstream api {
    server api:5000;
upstream client {
    server ui:3000;
    listen 80;
    # listen 443 ssl;
    # ssl_certificate     /etc/ssl/certs/server.crt;
    # ssl_certificate_key /etc/ssl/certs/server.key;
    rewrite_log on;
    error_log   /var/log/nginx/error.log debug;
        proxy_pass http://client;
    location /sockjs-node {
        proxy_http_version 1.1;
        proxy_set_header Connection "Upgrade";
    location /api {
        proxy_set_header Host $http_host;
        proxy_redirect off;
        proxy_buffering off;
        rewrite /api/(.*) /$1 break;
        proxy_pass http://api;
        # enable WebSockets
        proxy_set_header Connection "upgrade";
After the above location block I suggest adding the below location and then reload nginx. This will cause the acme challenge to be processed right away and not be redirected.
location /.well-known/acme-challenge {
    root /home/ubuntu/autolycus;
You should also add this to that server block
server_name animebob.in www.animebob.in;
Then, try this with both domain names as shown
sudo certbot certonly --dry-run --webroot --w /home/ubuntu/autolycus -d animebob.in -d www.animebob.in
If that works, remove --dry-run and do again to get production certs. If it fails, show us the error message
I have no idea what files are present in that directory. Maybe a lot of stuff that shouldn't be accessible would be accessible to the entire world wide web? I'd recommend to proceed with caution and not to advice such root directive. (Unless absolutely sure there's nothing in it.)
there will be important data,
suggest alternative approach pls
Just use a different folder name in that location block and the certbot -w command then
Fair point but they were already using that folder in their original command
I know and when reading that I also thought it was a bad idea :wink: To me, it suggested OP didn't know what they were doing.
ubuntu@movie3-storage:~$ sudo certbot certonly --dry-run --webroot --webroot-path /home/ubuntu/autolycus/temp -d animebob.in -d www.animebob.in
Account registered.
Simulating a certificate request for animebob.in and www.animebob.in
Domain: animebob.in
Detail: 68.233.118.212: Invalid response from http://animebob.in/.well-known/acme-challenge/1aniLb-f7NjdblfTp6vWgjL4JeZIMR41pOnF-rEJQss: 404
Domain: www.animebob.in
Detail: 68.233.118.212: Invalid response from http://www.animebob.in/.well-known/acme-challenge/Np5Wm7TH-uvNunxNZwBlsfpezTDHLo-9sXnl-xiMo10: 404
upstream api {
    server api:5000;
upstream client {
    server ui:3000;
    listen 80;
    # listen 443 ssl;
    rewrite_log on;
        root /home/ubuntu/autolycus/temp;
    location /api {
        proxy_redirect off;
        # enable WebSockets
"nginx.conf" 50L, 1169B        25,10-13      Top
pls check the result and server block
Please show that folder does exist, with:
ls -l /home/ubuntu/autolycus/temp
Please post this log file:
/var/log/letsencrypt/letsencrypt.log
And also, while we review that log file, place a test file in that webroot path:
echo "test-file" >> /home/ubuntu/autolycus/temp/test-file
It should then be accessible via:
http://animebob.in/.well-known/acme-challenge/test-file
http://www.animebob.in/.well-known/acme-challenge/test-file
Personally I would use a completely separate directory such as /var/lib/letsencrypt/http_challenges/ (which is also used by the Certbot apache plugin, so probably a good fit) for the challenge directory.
log.txt (12.5 KB)
not getting possible to export log file send some of it
i dont have much knowledge,
i'm trying to run a git project GitHub - imneonizer/autolycus: A seedr.cc inspired web application to download and stream torrent files from hosted web servers.
through oracle instance via docker
earlier on different instrance i hve connected same website with different ip it worked same command , yesterday only..
sudo certbot certonly --webroot --webroot-path /home/ubuntu/autolycus/temp -d animebob.in
i deleted that instance and trying to do same today in new instance now, getting error
I see nginx:
curl -Ii http://animebob.in/.well-known/acme-challenge/test-file  HTTP/1.1 404 Not Found
Date: Sat, 08 Jul 2023 16:40:26 GMT
Content-Type: text/html
Content-Length: 154
And the "test-file" is NOT accessible.
I would have liked to recommend certbot certonly --nginx instead of --webroot and avoid issues with any paths. But, when I see a config with lots of proxy I am less inclined. Especially when there are other apparent issues with the config. And, when using a somewhat older certbot version as well. The --nginx plug-in would be cleaner but potentially a lot more work to get them sorted out.
