root@westfield-nas:/letsencrypt# grep -r ssl_certificate /etc/nginx
/etc/nginx/snippets/snakeoil.conf:ssl_certificate /etc/ssl/certs/ssl-cert-snakeoil.pem;
/etc/nginx/snippets/snakeoil.conf:ssl_certificate_key /etc/ssl/private/ssl-cert-snakeoil.key;
/etc/nginx/sites-available/portal_ssl.dhc.nz: ssl_certificate /etc/letsencrypt/live/portal.dhc.nz/fullchain.pem;
/etc/nginx/sites-available/portal_ssl.dhc.nz: ssl_certificate_key /etc/letsencrypt/live/portal.dhc.nz/privkey.pem;
/etc/nginx/sites-available/portal_ssl.dhc.nz: #ssl_certificate /etc/letsencrypt/live/portal.bluedoor.nz/fullchain.pem;
/etc/nginx/sites-available/portal_ssl.dhc.nz: #ssl_certificate_key /etc/letsencrypt/live/portal.bluedoor.nz/privkey.pem;
/etc/nginx/sites-available/portal.dhc.nz: ssl_certificate /etc/letsencrypt/live/portal.dhc.nz/fullchain.pem; # managed by Certbot
/etc/nginx/sites-available/portal.dhc.nz: ssl_certificate_key /etc/letsencrypt/live/portal.dhc.nz/privkey.pem; # managed by Certbot
reapply the certificate renewal
root@westfield-nas:/letsencrypt# ./letsencrypt-auto
Failed to find executable apache2ctl in PATH: /usr/local/sbin:/usr/local/bin:/us r/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games
1: portal.dhc.nz
blank to select all options shown (Enter ‘c’ to cancel):
Cert not yet due for renewal
You have an existing certificate that has exactly the same domains or certificat e name you requested and isn’t close to expiry.
(ref: /etc/letsencrypt/renewal/portal.dhc.nz.conf)
What would you like to do?
Select the appropriate number [1-2] then [enter] (press ‘c’ to cancel): 1
Deploying Certificate to VirtualHost /etc/nginx/sites-enabled/portal.dhc.nz
Please choose whether or not to redirect HTTP traffic to HTTPS, removing HTTP ac cess.
new sites, or if you’re confident your site works on HTTPS. You can undo this
change by editing your web server’s configuration.
Select the appropriate number [1-2] then [enter] (press ‘c’ to cancel): 2
Redirecting all traffic on port 80 to ssl in /etc/nginx/sites-enabled/portal.dhc .nz
Congratulations! You have successfully enabled https://portal.dhc.nz
https://www.ssllabs.com/ssltest/analyze.html?d=portal.dhc.nz
Congratulations! Your certificate and chain have been saved at:
Your cert will expire on 2018-07-22. To obtain a new or tweaked
version of this certificate in the future, simply run
letsencrypt-auto again with the “certonly” option. To
non-interactively renew all of your certificates, run
“letsencrypt-auto renew” -
Donating to ISRG / Let’s Encrypt: https://letsencrypt.org/donate
root@westfield-nas:/letsencrypt# service nginx restart
root@westfield-nas:/letsencrypt# service nginx stop
root@westfield-nas:/letsencrypt# service nginx start
You need to follow the packets…
The external IP I see is: 103.68.58.20
check the firewall logs and see where it leads to.
Maybe you have multiple servers, load-balancer, active/standby servers, etc.
There must be a reason we get two different certs.
Without SNI, the IP returns a cert for: project.dhc.org.nz
Where is that system?
thats where their old website is hosted, another linux box
And yet it is online via the same IP:
https://www.ssllabs.com/ssltest/analyze.html?d=project.dhc.org.nz&hideResults=on
At least it still has a valid cert:
Valid until Thu, 31 May 2018 00:34:56 UTC (expires in 1 month and 6 days)
What I don’t get is how did you get the cert renewed?
Unless the http connections terminate at this server and the https terminate on the other server? ? ?
It seems to be corrected now:
https://www.ssllabs.com/ssltest/analyze.html?d=portal.dhc.nz&latest
found the issue. thanks for this advise
certificate is now valid
