revert this part of the changes:
we can tackle the v01 to v02 issue separately; as it really makes little/no difference at this point.
revert to v01 heres what i get
root@westfield-nas:/letsencrypt# ./letsencrypt-auto --nginx renew --force-renewal
tls-sni-01 challenge for portal.dhc.nz
Waiting for verification…
Attempting to renew cert (portal.dhc.nz) from /etc/letsencrypt/renewal/portal.dhc.nz.conf produced an unexpected error: Failed authorization procedure. portal.dhc.nz (tls-sni-01): urn:acme:error:unauthorized :: The client lacks sufficient authorization :: Incorrect validation certificate for tls-sni-01 challenge. Requested a3658b72747ab7480a9e895a5df7ab85.fe11c43b5909fdb91c269579fce9fab8.acme.invalid from 103.68.58.20:443. Received 3 certificate(s), first certificate had names “project.dhc.org.nz”. Skipping.
/etc/letsencrypt/live/portal.dhc.nz/fullchain.pem (failure)
Domain: portal.dhc.nz
Detail: Incorrect validation certificate for tls-sni-01 challenge.
Requested
switch to http:
--preferred-challenges http-01
or
This may require an exclusion for the challenge request folder:
http://project.dhc.org.nz/.well-known/acme-challenge/*
As there seems to be an HTTP to HTTPS redirect in place.
Place a test.txt file at:
http://project.dhc.org.nz/.well-known/acme-challenge/test.txt
and ensure it can be reached from the Internet.
success. thank heaps
root@westfield-nas:/etc/letsencrypt/renewal# cd /letsencrypt
root@westfield-nas:/letsencrypt# ./letsencrypt-auto --nginx renew --force-renewal --preferred-challenges http-01
http-01 challenge for portal.dhc.nz
OK now show the new contents of:
cert = /etc/letsencrypt/live/portal.dhc.nz/cert.pem
privkey = /etc/letsencrypt/live/portal.dhc.nz/privkey.pem
chain = /etc/letsencrypt/live/portal.dhc.nz/chain.pem
fullchain = /etc/letsencrypt/live/portal.dhc.nz/fullchain.pem
version = 0.23.0
archive_dir = /etc/letsencrypt/archive/portal.dhc.nz
[renewalparams]
installer = nginx
authenticator = nginx
account = 7f918b69102628ecaa2633f7821d1a2f
pref_challs = http-01,
portal.dhc.nz.conf (END)
So
can now be reduced to:
./letsencrypt-auto renew
or just
./letsencrypt-auto
as the conf now has:
You now need to work on the cron job to get this automated and be done with it.
To that end, first gather some useful info:
which letsencrypt
find / -name nginx.pid
Use that to create a cron job something along these lines (or whatever you feel comfortable with):
9 */12 * * * sudo /usr/bin/letsencrypt -q --deploy-hook ‘kill -HUP $( cat /run/nginx.pid )’
see: https://www.nginx.com/resources/wiki/start/topics/tutorials/commandline/
Sorry, I skipped the v01 to v02 issue.
If that is of concern (it would be if you wanted to do wild card validation), I suggest opening a new thread topic for just that.
are you able to advise why the certificate is still invalid?
https://portal.dhc.nz
have already restarted the nginx service
How is Nginx configured? You can use “nginx -T” to display it.
Has Nginx really been reloaded or restarted?
And what does “./letsencrypt-auto certificates” display?
done service nginx restart and reload
root@westfield-nas:/etc/nginx/sites-available# nginx -T
user www-data;
worker_processes auto;
pid /run/nginx.pid;
events {
worker_connections 768;
# multi_accept on;
http {
# Basic Settings
sendfile on;
tcp_nopush on;
tcp_nodelay on;
keepalive_timeout 65;
types_hash_max_size 2048;
client_max_body_size 2000M;
# server_tokens off;
# SSL Settings
ssl_protocols TLSv1 TLSv1.1 TLSv1.2; # Dropping SSLv3, ref: POODLE
ssl_prefer_server_ciphers on;
# Logging Settings
# Gzip Settings
gzip on;
gzip_disable "msie6";
# gzip_vary on;
# gzip_proxied any;
# gzip_comp_level 6;
# gzip_buffers 16 8k;
# gzip_http_version 1.1;
# Virtual Host Configs
#mail {
types {
text/html html htm shtml;
text/css css;
text/xml xml;
image/gif gif;
image/jpeg jpeg jpg;
application/javascript js;
application/atom+xml atom;
application/rss+xml rss;
text/mathml mml;
text/plain txt;
text/vnd.sun.j2me.app-descriptor jad;
text/vnd.wap.wml wml;
text/x-component htc;
image/png png;
image/tiff tif tiff;
image/vnd.wap.wbmp wbmp;
image/x-icon ico;
image/x-jng jng;
image/x-ms-bmp bmp;
image/svg+xml svg svgz;
image/webp webp;
application/font-woff woff;
application/java-archive jar war ear;
application/json json;
application/mac-binhex40 hqx;
application/msword doc;
application/pdf pdf;
application/postscript ps eps ai;
application/rtf rtf;
application/vnd.apple.mpegurl m3u8;
application/vnd.ms-excel xls;
application/vnd.ms-fontobject eot;
application/vnd.ms-powerpoint ppt;
application/vnd.wap.wmlc wmlc;
application/vnd.google-earth.kml+xml kml;
application/vnd.google-earth.kmz kmz;
application/x-7z-compressed 7z;
application/x-cocoa cco;
application/x-java-archive-diff jardiff;
application/x-java-jnlp-file jnlp;
application/x-makeself run;
application/x-perl pl pm;
application/x-pilot prc pdb;
application/x-rar-compressed rar;
application/x-redhat-package-manager rpm;
application/x-sea sea;
application/x-shockwave-flash swf;
application/x-stuffit sit;
application/x-tcl tcl tk;
application/x-x509-ca-cert der pem crt;
application/x-xpinstall xpi;
application/xhtml+xml xhtml;
application/xspf+xml xspf;
application/zip zip;
application/octet-stream bin exe dll;
application/octet-stream deb;
application/octet-stream dmg;
application/octet-stream iso img;
application/octet-stream msi msp msm;
application/vnd.openxmlformats-officedocument.wordprocessingml.document docx;
application/vnd.openxmlformats-officedocument.spreadsheetml.sheet xlsx;
application/vnd.openxmlformats-officedocument.presentationml.presentation pptx;
audio/midi mid midi kar;
audio/mpeg mp3;
audio/ogg ogg;
audio/x-m4a m4a;
audio/x-realaudio ra;
video/3gpp 3gpp 3gp;
video/mp2t ts;
video/mp4 mp4;
video/mpeg mpeg mpg;
video/quicktime mov;
video/webm webm;
video/x-flv flv;
video/x-m4v m4v;
video/x-mng mng;
video/x-ms-asf asx asf;
video/x-ms-wmv wmv;
video/x-msvideo avi;
listen 80 default_server;
# SSL configuration
root /var/www/html;
server_name _;
try_files $uri $uri/ =404;
# pass the PHP scripts to FastCGI server listening on 127.0.0.1:9000
#location ~ \.php$ {
# include snippets/fastcgi-php.conf;
# # With php7.0-cgi alone:
# fastcgi_pass 127.0.0.1:9000;
# # With php7.0-fpm:
# fastcgi_pass unix:/run/php/php7.0-fpm.sock;
# concurs with nginx's one
#location ~ /\.ht {
# deny all;
#server {
listen 192.168.3.4:80 default_server;
server_name _;
return 444;
server_name
portal.dhc.nz
#return 301 https://portal.dhc.nz$request_uri;
index index.php index.html;
if ( $host != 'portal.dhc.nz' ){
client_max_body_size 20M;
access_log /var/log/nginx/portal.dhc.nz_access.log;
error_log /var/log/nginx/portal.dhc.nz_error.log;
root /srv/www/portal.dhc.nz/public/;
#try_files $uri $uri/ @rewrite;
try_files $uri $uri/ /index.php?$query_string;
expires 1h;
add_header Pragma public;
add_header Cache-Control "public, must-revalidate, proxy-revalidate";
#include options.d/cache_10m.conf;
location ~ \.php$ {
try_files $uri /index.php =404;
fastcgi_split_path_info ^(.+\.php)(/.+)$;
fastcgi_pass unix:/var/run/php/php7.0-fpm.sock;
fastcgi_index index.php;
fastcgi_param SCRIPT_FILENAME $document_root$fastcgi_script_name;
include fastcgi_params;
fastcgi_read_timeout 1800;
ssl_certificate /etc/letsencrypt/live/portal.dhc.nz/fullchain.pem; # managed by Certbot
ssl_certificate_key /etc/letsencrypt/live/portal.dhc.nz/privkey.pem; # managed by Certbot
if ($host = portal.dhc.nz) {
} # managed by Certbot
listen 192.168.3.4:80;
server_name
portal.dhc.nz
fastcgi_param QUERY_STRING $query_string;
fastcgi_param REQUEST_METHOD $request_method;
fastcgi_param CONTENT_TYPE $content_type;
fastcgi_param CONTENT_LENGTH $content_length;
fastcgi_param SCRIPT_NAME $fastcgi_script_name;
fastcgi_param REQUEST_URI $request_uri;
fastcgi_param DOCUMENT_URI $document_uri;
fastcgi_param DOCUMENT_ROOT $document_root;
fastcgi_param SERVER_PROTOCOL $server_protocol;
fastcgi_param REQUEST_SCHEME $scheme;
fastcgi_param HTTPS $https if_not_empty;
fastcgi_param GATEWAY_INTERFACE CGI/1.1;
fastcgi_param SERVER_SOFTWARE nginx/$nginx_version;
fastcgi_param REMOTE_ADDR $remote_addr;
fastcgi_param REMOTE_PORT $remote_port;
fastcgi_param SERVER_ADDR $server_addr;
fastcgi_param SERVER_PORT $server_port;
fastcgi_param SERVER_NAME $server_name;
fastcgi_param REDIRECT_STATUS 200;
ssl_session_cache shared:le_nginx_SSL:1m;
ssl_session_timeout 1440m;
ssl_ciphers “ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:DHE-RSA-AES128-GCM-SHA256:DHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-AES128-SHA256:ECDHE-RSA-AES128-SHA256:ECDHE-ECDSA-AES128-SHA:ECDHE-RSA-AES256-SHA384:ECDHE-RSA-AES128-SHA:ECDHE-ECDSA-AES256-SHA384:ECDHE-ECDSA-AES256-SHA:ECDHE-RSA-AES256-SHA:DHE-RSA-AES128-SHA256:DHE-RSA-AES128-SHA:DHE-RSA-AES256-SHA256:DHE-RSA-AES256-SHA:ECDHE-ECDSA-DES-CBC3-SHA:ECDHE-RSA-DES-CBC3-SHA:EDH-RSA-DES-CBC3-SHA:AES128-GCM-SHA256:AES256-GCM-SHA384:AES128-SHA256:AES256-SHA256:AES128-SHA:AES256-SHA:DES-CBC3-SHA:!DSS”;
listen 443 ssl http2 default_server;
listen [::]:443 ssl http2 default_server;
include snippets/ssl-params.conf;
root /srv/www/portal.dhc.nz/public;
index index.html index.htm index.nginx-debian.html index.php;
error_log /var/log/nginx/error.portal.log warn;
server_name _;
try_files $uri $uri/ /index.php$is_args$args;
location ~ \.php$ {
#fastcgi_pass 127.0.0.1:9000;
# With php7.0-fpm:
fastcgi_read_timeout 600;
#ssl_certificate /etc/letsencrypt/live/portal.bluedoor.nz/fullchain.pem;
#ssl_certificate_key /etc/letsencrypt/live/portal.bluedoor.nz/privkey.pem;
error_page 404 /index.php;
location ~ /\.ht {
deny all;
ssl_ciphers “EECDH+AESGCM:EDH+AESGCM:AES256+EECDH:AES256+EDH”;
ssl_ecdh_curve secp384r1;
ssl_session_cache shared:SSL:10m;
ssl_session_tickets off;
ssl_stapling on;
ssl_stapling_verify on;
resolver 8.8.8.8 8.8.4.4 valid=300s;
resolver_timeout 5s;
#add_header Strict-Transport-Security “max-age=63072000; includeSubdomains; preload”;
add_header Strict-Transport-Security “max-age=63072000; includeSubdomains”;
add_header X-Frame-Options DENY;
add_header X-Content-Type-Options nosniff;
ssl_dhparam /etc/ssl/private/dh4096.pem;
fastcgi_split_path_info ^(.+.php)(/.+)$;
try_files $fastcgi_script_name =404;
set $path_info $fastcgi_path_info;
fastcgi_param PATH_INFO $path_info;
include fastcgi.conf;
Found the following certs:
Certificate Name: portal.dhc.nz
Domains: portal.dhc.nz
Expiry Date: 2018-07-22 04:04:39+00:00 (VALID: 89 days)
Certificate Path: /etc/letsencrypt/live/portal.dhc.nz/fullchain.pem
Private Key Path: /etc/letsencrypt/live/portal.dhc.nz/privkey.pem
Please post the contents of (it’s the public cert, so no need to worry):
and also the result of:
ls -l /etc/letsencrypt/live/portal.dhc.nz/
root@westfield-nas:/etc/letsencrypt/live/portal.dhc.nz# less fullchain.pem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-----END CERTIFICATE-----
-----BEGIN CERTIFICATE-----
MIIEkjCCA3qgAwIBAgIQCgFBQgAAAVOFc2oLheynCDANBgkqhkiG9w0BAQsFADA/
MSQwIgYDVQQKExtEaWdpdGFsIFNpZ25hdHVyZSBUcnVzdCBDby4xFzAVBgNVBAMT
DkRTVCBSb290IENBIFgzMB4XDTE2MDMxNzE2NDA0NloXDTIxMDMxNzE2NDA0Nlow
SjELMAkGA1UEBhMCVVMxFjAUBgNVBAoTDUxldCdzIEVuY3J5cHQxIzAhBgNVBAMT
GkxldCdzIEVuY3J5cHQgQXV0aG9yaXR5IFgzMIIBIjANBgkqhkiG9w0BAQEFAAOC
AQ8AMIIBCgKCAQEAnNMM8FrlLke3cl03g7NoYzDq1zUmGSXhvb418XCSL7e4S0EF
q6meNQhY7LEqxGiHC6PjdeTm86dicbp5gWAf15Gan/PQeGdxyGkOlZHP/uaZ6WA8
SMx+yk13EiSdRxta67nsHjcAHJyse6cF6s5K671B5TaYucv9bTyWaN8jKkKQDIZ0
Z8h/pZq4UmEUEz9l6YKHy9v6Dlb2honzhT+Xhq+w3Brvaw2VFn3EK6BlspkENnWA
a6xK8xuQSXgvopZPKiAlKQTGdMDQMc2PMTiVFrqoM7hD8bEfwzB/onkxEz0tNvjj
/PIzark5McWvxI0NHWQWM6r6hCm21AvA2H3DkwIDAQABo4IBfTCCAXkwEgYDVR0T
AQH/BAgwBgEB/wIBADAOBgNVHQ8BAf8EBAMCAYYwfwYIKwYBBQUHAQEEczBxMDIG
CCsGAQUFBzABhiZodHRwOi8vaXNyZy50cnVzdGlkLm9jc3AuaWRlbnRydXN0LmNv
bTA7BggrBgEFBQcwAoYvaHR0cDovL2FwcHMuaWRlbnRydXN0LmNvbS9yb290cy9k
c3Ryb290Y2F4My5wN2MwHwYDVR0jBBgwFoAUxKexpHsscfrb4UuQdf/EFWCFiRAw
VAYDVR0gBE0wSzAIBgZngQwBAgEwPwYLKwYBBAGC3xMBAQEwMDAuBggrBgEFBQcC
ARYiaHR0cDovL2Nwcy5yb290LXgxLmxldHNlbmNyeXB0Lm9yZzA8BgNVHR8ENTAz
MDGgL6AthitodHRwOi8vY3JsLmlkZW50cnVzdC5jb20vRFNUUk9PVENBWDNDUkwu
Y3JsMB0GA1UdDgQWBBSoSmpjBH3duubRObemRWXv86jsoTANBgkqhkiG9w0BAQsF
AAOCAQEA3TPXEfNjWDjdGBX7CVW+dla5cEilaUcne8IkCJLxWh9KEik3JHRRHGJo
uM2VcGfl96S8TihRzZvoroed6ti6WqEBmtzw3Wodatg+VyOeph4EYpr/1wXKtx8/
wApIvJSwtmVi4MFU5aMqrSDE6ea73Mj2tcMyo5jMd6jmeWUHK8so/joWUoHOUgwu
X4Po1QYz+3dszkDqMp4fklxBwXRsW10KXzPMTZ+sOPAveyxindmjkW8lGy+QsRlG
PfZ+G6Z6h7mjem0Y+iWlkYcV4PIWL1iwBi8saCbGS5jN2p8M+X+Q7UNKEkROb3N6
KOqkqm57TH2H3eDJAkSnh6/DNFu0Qg==
root@westfield-nas:/etc/letsencrypt/live/portal.dhc.nz# ls -l
total 0
lrwxrwxrwx 1 root root 37 Apr 23 19:44 cert.pem -> …/…/archive/portal.dhc.nz/c ert3.pem
lrwxrwxrwx 1 root root 38 Apr 23 19:44 chain.pem -> …/…/archive/portal.dhc.nz/ chain3.pem
lrwxrwxrwx 1 root root 42 Apr 23 19:44 fullchain.pem -> …/…/archive/portal.dhc .nz/fullchain3.pem
lrwxrwxrwx 1 root root 40 Apr 23 19:44 privkey.pem -> …/…/archive/portal.dhc.nz/privkey3.pem
That “looks good” in that it has multiple certs; but less fullchain.pem command didn’t show the entire file so it is difficult to see if it is correct.
Also online system isn’t sending out the fullchain.pem (multiple cert).
As shown by:
openssl s_client -connect portal.dhc.nz:443 -servername portal.dhc.nz -showcerts
only the simple public cert is being provided (cert.pem).
resending fullchaim.pem
root@westfield-nas:/etc/letsencrypt/live/portal.dhc.nz# more fullchain.pem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That is the correct FULLCHAIN cert but NOT the same cert being served:
Have you restarted the server/service since the cert was renewed?
yes done service nginx restart and reload
even stop and start
would it require to reboot the server?
No, that shouldn’t have any effect. Maybe try
grep -r ssl_certificate /etc/nginx
or something?
