I’m trying to renew a certificate and I’m getting the following error:
TypeError: sequence item 2: expected string, NoneType found
How should I proceed?
My environment:
CentOS 7, nginx, multiple virtual hosts.
nginx is here: /etc/nginx
The websites are under here: /var/www/html/*
I just rebuilt my server. I was using an old version of letsencrypt on the old server, but when I rebuilt the server I switched to certbot.
I was able to create a new certificate on this new server, but I can’t renew the certs that I created on the previous server.
Note that I am using elastic IP, so the public IP is the same in the old and new servers.
The config file in /etc/letsencrypt/renewal/my-domain.org.conf contains:
version = 0.12.0
archive_dir = /etc/letsencrypt/archive/my-domain.org
cert = /etc/letsencrypt/live/my-domain.org/cert.pem
privkey = /etc/letsencrypt/live/my-domain.org/privkey.pem
chain = /etc/letsencrypt/live/my-domain.org/chain.pem
fullchain = /etc/letsencrypt/live/my-domain.org/fullchain.pem
[renewalparams]
authenticator = standalone
installer = None
account = 9999999999999999999999999
$ sudo certbot renew -a nginx --cert-name /etc/letsencrypt/renewal/my-domain.org --dry-run --debug -vvv
Root logging level set at -10
Processing /etc/letsencrypt/renewal/my-domain.org.conf
Should renew, less than 30 days before certificate expiry 2017-06-24 18:50:00 UTC.
Requested authenticator nginx and installer None
Single candidate plugin: * nginx
Description: Nginx Web Server plugin - Alpha
Interfaces: IAuthenticator, IInstaller, IPlugin
Entry point: nginx = certbot_nginx.configurator:NginxConfigurator
Initialized: <certbot_nginx.configurator.NginxConfigurator object at 0x29c2b10>
Prep: True
Selected authenticator <certbot_nginx.configurator.NginxConfigurator object at 0x29c2b10> and installer None
Picked account: <Account(RegistrationResource(body=Registration(status=None, contact=(), agreement=u'https://letsencrypt.org/documents/LE-SA-v1.1.1-August-1-2016.pdf', key=JWKRSA(key=<ComparableRSAKey(<cryptography.hazmat.backends.openssl.rsa._RSAPublicKey object at 0x20bd9d0>)>)), uri=u'https://acme-staging.api.letsencrypt.org/acme/reg/2629245', new_authzr_uri=u'https://acme-staging.api.letsencrypt.org/acme/new-authz', terms_of_service=u'https://letsencrypt.org/documents/LE-SA-v1.1.1-August-1-2016.pdf'), a835e03f6ebfc0d90bf7619f71f30fad, Meta(creation_host=u'ip-172-31-62-200.ec2.internal', creation_dt=datetime.datetime(2017, 6, 16, 18, 23, 6, tzinfo=<UTC>)))>
Sending GET request to https://acme-staging.api.letsencrypt.org/directory.
Starting new HTTPS connection (1): acme-staging.api.letsencrypt.org
"GET /directory HTTP/1.1" 200 473
Received response:
HTTP 200
content-length: 473
expires: Sat, 17 Jun 2017 03:24:17 GMT
boulder-request-id: xbe-MdaPkamo3DZGX_krFi4qgoq0CC8MxZcbLLYXTC8
strict-transport-security: max-age=604800
server: nginx
connection: keep-alive
pragma: no-cache
cache-control: max-age=0, no-cache, no-store
date: Sat, 17 Jun 2017 03:24:17 GMT
x-frame-options: DENY
content-type: application/json
replay-nonce: UfwP_X1OX8bMR9M_hTZakg-v5L3aWQdlgh1Ume8kWU8
"IWv7-iKgeVI": "https://community.letsencrypt.org/t/adding-random-entries-to-the-directory/33417",
"key-change": "https://acme-staging.api.letsencrypt.org/acme/key-change",
"new-authz": "https://acme-staging.api.letsencrypt.org/acme/new-authz",
"new-cert": "https://acme-staging.api.letsencrypt.org/acme/new-cert",
"new-reg": "https://acme-staging.api.letsencrypt.org/acme/new-reg",
"revoke-cert": "https://acme-staging.api.letsencrypt.org/acme/revoke-cert"
Requesting fresh nonce
Sending HEAD request to https://acme-staging.api.letsencrypt.org/acme/new-authz.
"HEAD /acme/new-authz HTTP/1.1" 405 0
Received response:
HTTP 405
content-length: 91
pragma: no-cache
boulder-request-id: 3E-HMVyoGCenR6ag7rg-dheqbVYYqTCxg5ZH93OnTW4
server: nginx
allow: POST
content-type: application/problem+json
replay-nonce: fZO-58widg9onqCcDZEugCoUJ-EKBcQMvSIlr7NjXwc
Storing nonce: fZO-58widg9onqCcDZEugCoUJ-EKBcQMvSIlr7NjXwc
JWS payload:
"identifier": {
"type": "dns",
"value": "my-domain.org"
"resource": "new-authz"
Sending POST request to https://acme-staging.api.letsencrypt.org/acme/new-authz:
"header": {
"alg": "RS256",
"jwk": {
"e": "AQAB",
"kty": "RSA",
"n": "vkJFYgby66WE29EpDtUQOunSwDg4aRdeul1In-bg-RBokHNwTjPf_0u4OG5rPqaDhZjUa6GkOqc1mUTwUjRGyrO-El5wknxj8NiueKY0TugZFZM6_2tqa3rj2HnoAvi5w6PiFz_42zHNeoED_Q1nMIU3QALUxB6SrIlcIiWMdZY4iP2DneBjauo6590xZ9M1rhmchPJ87sp0STO1XuF7V4k3qeVxurcKVJ6DS9a8g9uoICBNgTKGT5T_UPmfzonrT-9hbUzFuWMtzbh_d2cBX68WhWpfaTxtXNFGjtSBp-_cE_Tt3lvyNpCz_bqeuJCoTyBhHJA8bXcr-Zfj2mmQ6w"
"protected": "eyJub25jZSI6ICJmWk8tNTh3aWRnOW9ucUNjRFpFdWdDb1VKLUVLQmNRTXZTSWxyN05qWHdjIn0",
"payload": "ewogICJpZGVudGlmaWVyIjogewogICAgInR5cGUiOiAiZG5zIiwgCiAgICAidmFsdWUiOiAidGFkYW1zdmEub3JnIgogIH0sIAogICJyZXNvdXJjZSI6ICJuZXctYXV0aHoiCn0",
"signature": "gdbJxZXqukyMKUrg7Xzic3hUvYX64rUmfAx_y_QDzRpWFFaPJUN_pT2awsFOWSxg2nPseS49Kcpf0rNwx9J41i1_DsJ2IuB8QyOaFwWrKQPPcs9_vmlXwixoFv3DjL6kFL-xXa5ZiFN0ATlL_PiUmdGX5t0XUCK7gYN0a-zpTbPwjyUqWiOgCiUFAwfujkAHhQlLCRmLtK0_8x7sUDeMG-TZh6h4EboyKtaHt7OXDjBU814a0GXFo82JOZjK3qaumh1RqvrbF-BU3DSSo4V-KyqFvK1anDvr-fNiG1az7-9h5lPjsObVs9mLCvxAWFYiY9FmOi7zLJhXh9-J_ccW3A"
"POST /acme/new-authz HTTP/1.1" 201 1006
Received response:
HTTP 201
content-length: 1006
boulder-request-id: wdSTLeiQ759nE_g7gHfgN7aAh8YZP2jboskiDEacN8w
server: nginx
link: <https://acme-staging.api.letsencrypt.org/acme/new-cert>;rel="next"
location: https://acme-staging.api.letsencrypt.org/acme/authz/zPtEj04N-YBAzJWEnYPH5O4xKGWUNFK3TUFrbP32EKg
pragma: no-cache
boulder-requester: 2629245
replay-nonce: IiLGjHAxc56JckGYd7p2ErS7f2cIdTUiofpPUaXOLZw
"identifier": {
"type": "dns",
"status": "pending",
"expires": "2017-06-24T03:24:17.825786246Z",
"challenges": [
"type": "dns-01",
"uri": "https://acme-staging.api.letsencrypt.org/acme/challenge/zPtEj04N-YBAzJWEnYPH5O4xKGWUNFK3TUFrbP32EKg/44148767",
"token": "9rjMzLSMs2pKJRzpG_2tlL1UosaoFzpnd03LFzPLp-c"
"type": "http-01",
"uri": "https://acme-staging.api.letsencrypt.org/acme/challenge/zPtEj04N-YBAzJWEnYPH5O4xKGWUNFK3TUFrbP32EKg/44148768",
"token": "KX4_FTnscvRjXNChT8SZvwj-_TLorDAACTSXPQpjOSw"
"type": "tls-sni-01",
"uri": "https://acme-staging.api.letsencrypt.org/acme/challenge/zPtEj04N-YBAzJWEnYPH5O4xKGWUNFK3TUFrbP32EKg/44148769",
"token": "ZjG1RK3nVLxnmFIitQ6xxdf6LwZHoscpqc5r0rSrcpo"
"combinations": [
2
1
0
Storing nonce: IiLGjHAxc56JckGYd7p2ErS7f2cIdTUiofpPUaXOLZw
JWS payload:
"identifier": {
"type": "dns",
"value": "www.my-domain.org"
"header": {
"alg": "RS256",
"jwk": {
"e": "AQAB",
"kty": "RSA",
"protected": "eyJub25jZSI6ICJJaUxHakhBeGM1Nkpja0dZZDdwMkVyUzdmMmNJZFRVaW9mcFBVYVhPTFp3In0",
"payload": "ewogICJpZGVudGlmaWVyIjogewogICAgInR5cGUiOiAiZG5zIiwgCiAgICAidmFsdWUiOiAid3d3LnRhZGFtc3ZhLm9yZyIKICB9LCAKICAicmVzb3VyY2UiOiAibmV3LWF1dGh6Igp9",
"signature": "pzPhqHOLB_SnD_173RX5U2LaQITQge-pWhwmchGKEBlVtGTdPb_QywjhEpCSmMxtJDchYRA0V7-4rg51Guy7mLyQzAEwXfydBKqK5DNtzPmCNOfCokPYlP0iisieyamUFsKV7RtnnH6Zy8NSpPiqVlNt3WiKsGmRqwb0ezss9-9PA7z8cdfcgHJUikqs2PwNUqyY39C_wgBRFTuv2UYgaztjbo7yCd1OsXCVo579J6tzLxcJAiy-f7KVXoSFNUaxaDeyX29BynhZi1oHkTpi4VRRtUTE0onuUcDN_UTJSBU7zPVrSbfunpSPibOXEsUwqvTh9lhDhD0B2UFEIdycCg"
"POST /acme/new-authz HTTP/1.1" 201 1010
Received response:
HTTP 201
content-length: 1010
boulder-request-id: 2GFVvBOa91VxCiBefeSmGuDLztgPcGzkhvwmy3-Ir6k
server: nginx
location: https://acme-staging.api.letsencrypt.org/acme/authz/z48m1-Ic0dkxBOEq6CGTuUbD3y42yw8OYWSttJuB1iw
pragma: no-cache
replay-nonce: jyCrlU5doHp5qUT3ZKU91AIkIvJgrfO3FOAsIVeyHno
"identifier": {
"type": "dns",
"expires": "2017-06-24T03:24:17.923687156Z",
"challenges": [
"type": "dns-01",
"uri": "https://acme-staging.api.letsencrypt.org/acme/challenge/z48m1-Ic0dkxBOEq6CGTuUbD3y42yw8OYWSttJuB1iw/44148770",
"token": "_5tZAza-dzpd-RRx-3ne-ryyvq7PnwEQs3BC9FaOCgE"
"type": "http-01",
"uri": "https://acme-staging.api.letsencrypt.org/acme/challenge/z48m1-Ic0dkxBOEq6CGTuUbD3y42yw8OYWSttJuB1iw/44148771",
"token": "qt8ilqpwPXWXBYtwETa9w-9UIo5hsV_Fok5xUHc2ef0"
"uri": "https://acme-staging.api.letsencrypt.org/acme/challenge/z48m1-Ic0dkxBOEq6CGTuUbD3y42yw8OYWSttJuB1iw/44148772",
"token": "HpIoPQaqJBTGODWsAo-4vHdk2jNzHKu8w95wvhx3thM"
"combinations": [
2
0
1
Storing nonce: jyCrlU5doHp5qUT3ZKU91AIkIvJgrfO3FOAsIVeyHno
tls-sni-01 challenge for my-domain.org
tls-sni-01 challenge for www.my-domain.org
Generating key (1024 bits), not saving to file
Creating backup of /etc/nginx/conf.d/[MANY FILES].conf
Encountered exception:
File "/usr/lib/python2.7/site-packages/certbot/auth_handler.py", line 115, in _solve_challenges
resp = self.auth.perform(self.achalls)
File "/usr/lib/python2.7/site-packages/certbot_nginx/configurator.py", line 805, in perform
sni_response = chall_doer.perform()
File "/usr/lib/python2.7/site-packages/certbot_nginx/tls_sni_01.py", line 75, in perform
self.configurator.save("SNI Challenge", True)
File "/usr/lib/python2.7/site-packages/certbot_nginx/configurator.py", line 717, in save
self.parser.filedump(ext='')
File "/usr/lib/python2.7/site-packages/certbot_nginx/parser.py", line 239, in filedump
out = nginxparser.dumps(tree)
File "/usr/lib/python2.7/site-packages/certbot_nginx/nginxparser.py", line 133, in dumps
return str(RawNginxDumper(blocks.spaced))
File "/usr/lib/python2.7/site-packages/certbot_nginx/nginxparser.py", line 97, in __str__
return ''.join(self)
File "/usr/lib/python2.7/site-packages/certbot_nginx/nginxparser.py", line 86, in __iter__
for line in self.__iter__([parameter]): # negate "for b0 in blocks"
File "/usr/lib/python2.7/site-packages/certbot_nginx/nginxparser.py", line 93, in __iter__
yield "".join(item) + semicolon
Calling registered functions
Attempting to renew cert from /etc/letsencrypt/renewal/my-domain.org.conf produced an unexpected error: sequence item 2: expected string, NoneType found. Skipping.
Traceback was:
File "/usr/lib/python2.7/site-packages/certbot/renewal.py", line 418, in handle_renewal_request
main.renew_cert(lineage_config, plugins, renewal_candidate)
File "/usr/lib/python2.7/site-packages/certbot/main.py", line 640, in renew_cert
_get_and_save_cert(le_client, config, lineage=lineage)
File "/usr/lib/python2.7/site-packages/certbot/main.py", line 77, in _get_and_save_cert
renewal.renew_cert(config, domains, le_client, lineage)
File "/usr/lib/python2.7/site-packages/certbot/renewal.py", line 296, in renew_cert
new_certr, new_chain, new_key, _ = le_client.obtain_certificate(domains)
File "/usr/lib/python2.7/site-packages/certbot/client.py", line 313, in obtain_certificate
self.config.allow_subset_of_names)
File "/usr/lib/python2.7/site-packages/certbot/auth_handler.py", line 74, in get_authorizations
resp = self._solve_challenges()
/etc/letsencrypt/live/my-domain.org/fullchain.pem (failure)
Exiting abnormally:
File "/bin/certbot", line 9, in <module>
load_entry_point('certbot==0.14.1', 'console_scripts', 'certbot')()
File "/usr/lib/python2.7/site-packages/certbot/main.py", line 742, in main
File "/usr/lib/python2.7/site-packages/certbot/main.py", line 692, in renew
renewal.handle_renewal_request(config)
File "/usr/lib/python2.7/site-packages/certbot/renewal.py", line 435, in handle_renewal_request
len(renew_failures), len(parse_failures)))
Error: 1 renew failure(s), 0 parse failure(s)
