My domain is: *.clubhelp.com.au (qcc.clubhelp.com.au, demo.clubhelp.com.au...)
sudo certbot certonly --manual --preferred-challenges dns -d '*.clubhelp.com.au' -d clubhelp.com.au
root@ip-172-30-1-44:/etc/letsencrypt/live# sudo certbot certonly --manual --preferred-challenges dns -d '*.clubhelp.com.au' -d clubhelp.com.au
requested (ref: /etc/letsencrypt/renewal/clubhelp.com.au.conf)
It contains these names: clubhelp.com.au
You requested these names for the new certificate: *.clubhelp.com.au,
clubhelp.com.au.
certificate?
(E)xpand/(C)ancel: E
Renewing an existing certificate for *.clubhelp.com.au and clubhelp.com.au
Please deploy a DNS TXT record under the name:
_acme-challenge.clubhelp.com.au.
with the following value:
pdtPCoPBXbWw7cuDTjlfIjU47pqtre363zy0xXSZzOk
Before continuing, verify the TXT record has been deployed. Depending on the DNS
provider, this may take some time, from a few seconds to multiple minutes. You can
check if it has finished deploying with aid of online tools, such as the Google
Admin Toolbox: https://toolbox.googleapps.com/apps/dig/#TXT/_acme-challenge.clubhelp.com.au.
Look for one or more bolded line(s) below the line ';ANSWER'. It should show the
value(s) you've just added.
Press Enter to Continue
Certificate is saved at: /etc/letsencrypt/live/clubhelp.com.au/fullchain.pem
Key is saved at: /etc/letsencrypt/live/clubhelp.com.au/privkey.pem
This certificate expires on 2024-08-08.
NEXT STEPS:
- This certificate will not be renewed automatically. Autorenewal of --manual certificates requires the use of an authentication hook script (--manual-auth-hook) but one was not provided. To renew this certificate, repeat this same certbot command before the certificate's expiry date.
* Donating to ISRG / Let's Encrypt: https://letsencrypt.org/donate
* Donating to EFF: https://eff.org/donate-le
nginx version: nginx/1.18.0 (Ubuntu)
Ubuntu 22.04.4 LTS
no
certbot 2.10.0
The command appears to work fine. The nginx config entry is:
root@ip-172-30-1-44:/etc/letsencrypt# cat /etc/nginx/sites-enabled/qcc
listen 80;
server_name qcc.clubhelp.com.au;
return 301 https://$host$request_uri; # Redirect all HTTP traffic to HTTPS
location = /favicon.ico {
root /home/qcc/qcc/collected_static;
access_log off;
log_not_found off;
location /static {
alias /home/qcc/qcc/collected_static;
root /home/qcc;
include proxy_params;
proxy_pass http://unix:/home/qcc/site.sock;
auth_basic "Restricted Content. Contact paul.whipp at gmail.com for access.";
auth_basic_user_file /etc/nginx/htpasswd;
ssl_certificate /etc/letsencrypt/live/clubhelp.com.au/fullchain.pem; # managed by Certbot
ssl_certificate_key /etc/letsencrypt/live/clubhelp.com.au/privkey.pem; # managed by Certbot
However, accessing the site using chrome (and probably any other browser) results in:
Not secure: NET::ERR_CERT_COMMON_NAME_INVALID
Calling certbot renew tells me that the certificate is not due for renewal.
This all seemed to be working prior to renewal although I had accidentally created two certificates.
I removed one completely before attempting the above expansion.
It appears that the certificate is not supporting the wildcard subdomains in spite of my apparently successful attempt the expand it above. The certificate appears to have the wildcard in it:
root@ip-172-30-1-44:/etc/letsencrypt# openssl x509 -in /etc/letsencrypt/live/clubhelp.com.au/fullchain.pem -text -noout
Certificate:
Data:
Version: 3 (0x2)
Serial Number:
03:cb:66:e5:97:ba:e4:20:e7:07:81:fc:c9:73:4a:21:ea:42
Signature Algorithm: sha256WithRSAEncryption
Issuer: C = US, O = Let's Encrypt, CN = R3
Validity
Not Before: May 10 23:31:10 2024 GMT
Not After : Aug 8 23:31:09 2024 GMT
Subject: CN = *.clubhelp.com.au
Subject Public Key Info:
