Attempting to parse the version 0.14.0 renewal configuration file │
│ found at /etc/letsencrypt/renewal/nabil.photo.conf with version │
│ 0.8.1 of Certbot. This might not work. │
│ Attempting to parse the version 0.19.0 renewal configuration file │
│ found at /etc/letsencrypt/renewal/virtuabook.com.conf with version │
│ found at /etc/letsencrypt/renewal/democrasite.com.conf with version │
│ Client with the currently selected authenticator does not support │
│ any combination of challenges that will satisfy the CA
Seems to me you’re running version 0.8.1 of certbot now… Which is like, ancient? How did that happen? Did you perhaps use certbot-auto previously in stead of certbot, the version which comes with the Debian package manager? Hmm, jessie-backportsshould install version 0.10.2 of certbot… Sow how is it possible you’re running such an old version?
Thanks guys for your precious help, but i’m afraid to not be enough experimented yet. Maybe I had an old version from LetsEncrypt. Here, what I have in my Debian
**apt-cache search certbot**
certbot - automatically configure HTTPS using Let's Encrypt
letsencrypt - transitional dummy package
python-certbot - main library for certbot
python-certbot-doc - client documentation for certbot
python-certbot-apache - Apache plugin for Certbot
python-certbot-apache-doc - Apache plugin documentation for Certbot
python-certbot-nginx - Nginx plugin for Certbot
python-certbot-nginx-doc - Nginx plugin documentation for Certbot
Package: certbot
Source: python-certbot
Version: 0.10.2-1~bpo8+1
Installed-Size: 79
Maintainer: Debian Let's Encrypt <letsencrypt-devel@lists.alioth.debian.org>
Architecture: all
Replaces: letsencrypt
Provides: letsencrypt
Depends: python-certbot (= 0.10.2-1~bpo8+1), init-system-helpers (>= 1.18~), python, python:any (>= 2.7~)
Suggests: python-certbot-apache, python-certbot-doc
Breaks: letsencrypt (<= 0.6.0)
Description-en: automatically configure HTTPS using Let's Encrypt
The objective of Certbot, Let's Encrypt, and the ACME (Automated
Certificate Management Environment) protocol is to make it possible
to set up an HTTPS server and have it automatically obtain a
browser-trusted certificate, without any human intervention. This is
accomplished by running a certificate management agent on the web
server.
This agent is used to:
- Automatically prove to the Let's Encrypt CA that you control the website
- Obtain a browser-trusted certificate and set it up on your web server
- Keep track of when your certificate is going to expire, and renew it
- Help you revoke the certificate if that ever becomes necessary.
This package contains the main application, including the standalone
and the manual authenticators.
Description-md5: deb7e404ce1b150b59379c3f9a73ac1a
Homepage: https://certbot.eff.org/
Section: web
Priority: optional
Filename: pool/main/p/python-certbot/certbot_0.10.2-1~bpo8+1_all.deb
MD5sum: cafb44d050a688025c96f12aa28d1b47
SHA1: ///////////////
SHA256: //////////////
Package: certbot
Status: install ok installed
Priority: extra
Section: web
Installed-Size: 60
Architecture: all
Version: 0.8.1-2~bpo8+1
Depends: dialog, python-certbot (= 0.8.1-2~bpo8+1), python, python:any (>= 2.7~)
Conffiles:
/etc/cron.d/certbot 13165288622784a749fd3c2bf4ddff6c
server.
