I have two servers behind a load balancer, with >350 domains pointed to the load balancer’s IP, which are redirected 50/50 to one of two nodes. All management including certbot is to be carried out on node 01.
There is an NFS mount point for /var/www/vhosts and Unison synchronises specified files and directories including all Apache conf files, LE certs and LE http-01 challenge files.
The problem is that I need to run a command to force sync of the challenge files and reload apache on the 02 node between writing the challenge files and requesting authorization from the ACME server. Because if I don’t, only the 01 node has the challenge files and temporary conf edits, and when the auth request comes in via the load balancer, it is sometimes hitting the 02 node and getting a 404.
I haven’t found quite enough documentation on the --deploy-hook option, but I’ve tried pre and post hooks and they don’t work.
I appreciate a DNS challenge might be an alternative but the provider (Gandi) has an enforced minimum TTL and what appears to be slow propagation. I don’t believe I can achieve automation of this without other issues and would like certbot to handle Apache configuration for me, so the http-01 challenge makes sense. Any and all advice appreciated.
maple-motor-services.co.uk
certbot --expand --reinstall --apache --redirect --non-interactive --preferred-challenges http --deploy-hook “/usr/bin/file_sync.sh && httpd -t && apachectl graceful && ssh -p2020 merr-web-02 apachectl graceful” -d adm02.clients.merrehill.co.uk,c.adm02.clients.merrehill.co.uk,www.adm02.clients.merrehill.co.uk,maple-motor-services.co.uk,c.maple-motor-services.co.uk,www.maple-motor-services.co.uk
Domain: c.adm02.clients.merrehill.co.uk
Detail: Invalid response from
[159.253.213.20]: "<!DOCTYPE HTML PUBLIC "-//IETF//DTD HTML
2.0//EN">\n<html><head>\n<title>404 Not
Found</title>\n</head><body>\n<h1>Not Found</h1>\n<p"
Domain: www.maple-motor-services.co.uk
Domain: c.maple-motor-services.co.uk
Apache 2.4.6
CentOS 7.6.1810
N/A
Yes
Webmin 1.900/Virtualmin 6.06
certbot 0.30.2
