Hello ,
I am working to automate the certificate create process upon selecting a domain from my drop-down list.
Server side programming i am using is in Perl Language.
I have used to create the certificate by use of system command as follows.
$command = /root/letsencrypt/./certbot-auto certonly --standalone -n -d ‘. $domainname .’ -w '. $webroot;
system($command);
But, it always throwing below error
Can’t exec “/root/letsencrypt/./certbot-auto”: Permission denied
Can anyone help on this please.
Thanks in advance
Rajkumar S
Are you running your perl script as root?
Yes, i am running as root user
Try to run the command in your shell, if it works, there should be no permission problem.
/root/letsencrypt/./certbot-auto certificates
No issues were found on this command
Found the following certs:
Certificate Name: mydomain.com
Domains: mydomain.com
Expiry Date: 2018-07-08 12:07:31+00:00 (INVALID: TEST_CERT)
Certificate Path: /etc/letsencrypt/live/mydomain.com/fullchain.pem
Private Key Path: /etc/letsencrypt/live/mydomain.com/privkey.pem
Let me check to find if any other issues
Thanks
If you can run the exact same command line on your shell, it must work with perl's system() command, too.
Try the following in a perl script:
$command = "/root/letsencrypt/./certbot-auto certificates";
system($command);
@bytecamp
thanks .
The error was with my side as i am running the let’s encrypt service without root user. Now it has been corrected.
Thanks
Rajkumar S
