'/etc/letsencrypt/live/prod2.femtotest.com/fullchain.pem' does not exist or is empty
My domain is: prod2.femtotest.com
I ran this command: sudo apache2ctl configtest
[Wed Jul 03 11:03:06.003921 2019] [so:warn] [pid 121800:tid 140290606566336] AH01574: module wsgi_module is already loaded, skipping
AH00526: Syntax error on line 117 of /etc/apache2/sites-enabled/prod2.femtotest.com.conf:
SSLCertificateFile: file ‘/etc/letsencrypt/live/prod2.femtotest.com/fullchain.pem’ does not exist or is empty
Action ‘configtest’ failed.
My web server is (include version): apache 2.4.29
The operating system my web server runs on is (include version): ubuntu 18.04
My hosting provider, if applicable, is: not applicable
I know this topic comes up a lot. My impression from the other answers is that it has to do with a chicken and egg thing - like it needs apache to standup to do the test, but for apache to standup it needs that /etc/letsencrypt/live directory with all its stuff like fullchain.pem which doesn’t exist. So Im not sure how to get out of this state. I have seen people metion deleting certain conf files but nothing has worked so far for me. Any help would be much appreciated
Hi @alexyz
looks like you have deleted or moved that file or the resulting file (live contains symlinks).
One simple option. Deactivate that site with a2dissite.
Or create a self signed certificate and use that temporary.
No. It's only a problem if a used certificate is deleted. That's always bad.
