when I execute "sudo certbot" I get the following:
File "/usr/local/bin/certbot", line 7, in
from certbot.main import main
File "/usr/local/lib/python2.7/dist-packages/certbot/main.py", line 2, in
from certbot._internal import main as internal_main
File "/usr/local/lib/python2.7/dist-packages/certbot/_internal/main.py", line 22, in
from certbot._internal import cert_manager
File "/usr/local/lib/python2.7/dist-packages/certbot/_internal/cert_manager.py", line 16, in
from certbot._internal import storage
File "/usr/local/lib/python2.7/dist-packages/certbot/_internal/storage.py", line 83, in
def add_time_interval(base_time, interval, textparser=parsedatetime.Calendar()):
File "/usr/local/lib/python2.7/dist-packages/parsedatetime/init.py", line 270, in init
self.ptc = Constants()
File "/usr/local/lib/python2.7/dist-packages/parsedatetime/init.py", line 2381, in init
self.locale = get_icu(self.localeID)
File "/usr/local/lib/python2.7/dist-packages/parsedatetime/pdt_locales/icu.py", line 56, in get_icu
result['icu'] = icu = pyicu.Locale(locale)
AttributeError: 'module' object has no attribute 'Locale'
Is there a way that I can resolve the problem ? thanks.
