Error when running certbot on ubuntu
My domain is: nutch.io
I ran this command: sudo certbot certonly --apache
Please enter the domain name(s) you would like on your certificate (comma and/or
space separated) (Enter 'c' to cancel): nutch.io
Requesting a certificate for nutch.io
Domain: nutch.io
Detail: The key authorization file from the server did not match this challenge. Expected "nL2wKmHB_Vybj9J55FQV2OwB77nIEEOaso709Xux7rc.aF2IfBhSvpoJ3J52iOLj1hGmy9r98R-1lejAbxPze60" (got "nL2wKmHB_Vybj9J55FQV2OwB77nIEEOaso709Xux7rc.4E3VCTFsySjUrqnCg0ooULx-3kbdPBygi0aWkvg5Gd8")
Server version: Apache/2.4.58 (Ubuntu)
Server built: 2024-07-17T18:55:23
Linux ns5028403 6.8.0-47-generic #47-Ubuntu SMP PREEMPT_DYNAMIC Fri Sep 27 21:40:26 UTC 2024 x86_64 x86_64 x86_64 GNU/Linux
OVH dedicated server (metal)
I'm using a control panel to manage my site (no, or provide the name and version of the control panel): no, command line
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): 2.11.0
Welcome @sartgegru
It looks like your DNS AAAA address for IPv6 points to a different Apache server than the one in the DNS A record for IPv4.
Let's Encrypt prefers IPv6 when present.
You should set the AAAA record to the correct public IPv6 address. Or, remove that record if you do not support IPv6
Note particularly the "Server" response header for IPv4 and v6 is different
Address=2001:41d0:301::26,Address Type=IPv6,Server=Apache
Address=15.235.67.205,Address Type=IPv4,Server=Apache/2.4.58 (Ubuntu)
Thank you, removing the AAAA entry worked!
