Error when running certbot --apache
My domain is: sigmadeltapi.club
I ran this command: certbot --apache
It produced this output: Requesting a certificate for sigmadeltapi.club and www.sigmadeltapi.club
http-01 challenge for sigmadeltapi.club
http-01 challenge for www.sigmadeltapi.club
Challenge failed for domain sigmadeltapi.club
Challenge failed for domain www.sigmadeltapi.club
http-01 challenge for sigmadeltapi.clubCertbot failed to authenticate some domains (authenticator: apache). The Certificate Authority reported these problems:
Domain: sigmadeltapi.club
Type: connection
Detail: 162.210.21.107: Fetching http://sigmadeltapi.club/.well-known/acme-challenge/yiROwYnmHJ2VWa6hg05FEw_0VWpmUNYx5TgsJUD8jfI: Error getting validation data
Domain: www.sigmadeltapi.club
Type: connection
Detail: 162.210.21.107: Fetching http://www.sigmadeltapi.club/.well-known/acme-challenge/j3sLJ_GQiCxvmpOREMr48FlD1ezxzgkGuXSYeKykMiY: Error getting validation data
My web server is (include version): apache2
The operating system my web server runs on is (include version): Ubuntu 24.04 LTS
I can login to a root shell on my machine (yes or no, or I don't know): No, sudo only
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 2.9.0
Can't view letsencrypt.log even with sudo.
The "Error getting validation data" means the Let's Encrypt server could not complete its HTTP request to your domain. This is most likely a firewall on your premises. Or, perhaps a routing problem like wrong NAT or port forwarding in your router or comms config.
This is not a problem unique to Let's Encrypt. This test site cannot reach your domain's server from any of many locations around the world: Check website performance and response : Check host - online website monitoring
To use the HTTP challenge your domain needs to be accessible to HTTP requests on port 80. The --apache option you chose uses the HTTP Challenge. See: Challenge Types - Let's Encrypt
