Error running command ['apache2ctl'
My server: Ubuntu 18.04 LTS Apache/2.4.29 (Ubuntu)
Rackspace: shell access
Test Command I ran - an cerbot --apache generated certificate
certbot --dry-run --force-renewal renew --cert-name drjosephpengecir.com
Processing /etc/letsencrypt/renewal/drjosephpengecir.com.conf
Error running command [‘apache2ctl’, ‘-t’, ‘-D’, ‘DUMP_INCLUDES’] for runtime parameters!
  1. I believe the apache plugin is having a problem with my 490 domains.
  2. apache2ctl -t -D DUMP_INCLUDES | wc -c
    shows this
    AH00558: apache2: Could not reliably determine the server’s fully qualified domain name, using 2001:4801:7820:75:be76:4eff:fe10:489f. Set the ‘ServerName’ directive globally to suppress this message
    91738
is the word count, it is large
The cert I am testing with is /etc/letsencrypt/renewal/
renew_before_expiry = 30 days
version = 0.31.0
archive_dir = /etc/letsencrypt/archive/drjosephpengecir.com
cert = /etc/letsencrypt/live/drjosephpengecir.com/cert.pem
privkey = /etc/letsencrypt/live/drjosephpengecir.com/privkey.pem
chain = /etc/letsencrypt/live/drjosephpengecir.com/chain.pem
fullchain = /etc/letsencrypt/live/drjosephpengecir.com/fullchain.pem
[renewalparams]
account = 51759ba3dccb8494b190da63f954a1f3
authenticator = apache
installer = apache
Note - I had issues with the apache plugin after requesting 250 certificates
So I switched to the webroot plugin
I tested a cert generated with the webroot plugin
certbot --dry-run --force-renewal renew --cert-name drlawrencedavisonline.com
  • DRY RUN: simulating ‘certbot renew’ close to cert expiry
version = 0.31.0
archive_dir = /etc/letsencrypt/archive/drlawrencedavisonline.com
cert = /etc/letsencrypt/live/drlawrencedavisonline.com/cert.pem
privkey = /etc/letsencrypt/live/drlawrencedavisonline.com/privkey.pem
chain = /etc/letsencrypt/live/drlawrencedavisonline.com/chain.pem
fullchain = /etc/letsencrypt/live/drlawrencedavisonline.com/fullchain.pem
[renewalparams]
authenticator = webroot
webroot_path = /var/www/html,
[[webroot_map]]
drlawrencedavisonline.com = /var/www/html
www.drlawrencedavisonline.com = /var/www/html
Does anybody see a problem if I change the renewal files under /etc/letsencrypt/renewal/ and switch the failing apache ones to the same format as the succeeding webroot ones? The documentation basically says, do not change anything. Certbot expects things to be like it created them. Or in other words, are there dependencies in the renewal process that rely on data saved by the certbot plugin used for the request?
Hi @gmgj,
Sounds like you've got a large webhost to control. You could always take a backup of the /etc/letsencrypt folder before trying to edit the renewal files. According to User Guide — Certbot 2.7.0.dev0 documentation
For advanced certificate management tasks, it is possible to manually modify the certificate’s renewal configuration file, but this is discouraged since it can easily break Certbot’s ability to renew your certificates. If you choose to modify the renewal configuration file we advise you to test its validity with the certbot renew --dry-run command.
Thank you. I am a little ashamed I did not find that myself. Another question, Can I write a pre or post hook in php and invocate in a BasH srcipt
#!/bin/bash
/etc/cron.daily/example
echo "$0 # $PWD # date # whoami :whoami "
php /var/www/html/wip/certs/GenURLList1.php
In my case, I changed the apache generated conf file in /etc/letsencrypt/renewal/
to be in the same format as the webroot one, and it worked.
The line changed were
[[webroot_map]]
domain name .com = /var/www/html
www.*domain name.*com = /var/www/html
It was generated with certbot -n –apache –agree-tos –redirect -d ‘ . $ourhost . ‘ -d ‘ . $ourhostwww;
were outhost and ourhostwww correspond to the domain name and www. domain name
You can write the hooks in any language you prefer!
Indeed, if you start them with something like
#!/usr/bin/php
or whatever the appropriate version is for your system and interpreter, the operating system will automatically run that interpreter (instead of bash) to interpret the script. For example, Python scripts often start with
#!/usr/bin/python
or
#!/usr/bin/env python
and they could be run directly as hooks without having a shell script in between.
