Error running certbot
Hey there,
I installed certbot on my ubuntu 17.04 successfully but when I run:
sudo certbot --apache
I get the following error:`
[sudo] password for vps:
1: babataher.org
2: forum.babataher.org
blank to select all options shown (Enter 'c' to cancel): 1,2
tls-sni-01 challenge for babataher.org
tls-sni-01 challenge for forum.babataher.org
File:
 - Could not be found to be deleted /var/lib/letsencrypt/WKMjjxei-84cBk3gCmds4R-EMiioUgswQcAtFsleliI.pem - Certbot probably shut down unexpectedly
File:
 - Could not be found to be deleted /var/lib/letsencrypt/WKMjjxei-84cBk3gCmds4R-EMiioUgswQcAtFsleliI.crt - Certbot probably shut down unexpectedly
An unexpected error occurred:
AttributeError: 'module' object has no attribute 'rand'
Hi @pharb0d,
Did you run Certbot just once, or did you run it multiple times? How did you install Certbot on this system?
And could you post the logs from /var/log/letsencrypt somewhere?
