Yes
root@online:~# ls -lrht /etc/letsencrypt/live/online.cdiu.university-12-31-2020
total 4.0K
-rw-r--r-- 1 root root 692 Oct 8 12:43 README
lrwxrwxrwx 1 root root 54 Jan 1 00:59 privkey.pem -> ../../archive/online.cdiu.university-0001/privkey1.pem
lrwxrwxrwx 1 root root 56 Jan 1 00:59 fullchain.pem -> ../../archive/online.cdiu.university-0001/fullchain1.pem
lrwxrwxrwx 1 root root 52 Jan 1 00:59 chain.pem -> ../../archive/online.cdiu.university-0001/chain1.pem
lrwxrwxrwx 1 root root 51 Jan 1 00:59 cert.pem -> ../../archive/online.cdiu.university-0001/cert1.pem
root@online:~#
Since we know that your certificate acquisition process works (I can already see the new certificate on crt.sh), we can safely straighten things out...
Please show the outputs of running these...
certbot delete online.cdiu.university-12-31-2020
certbot delete online.cdiu.university-0001
certbot delete online.cdiu.university-0002
certbot delete online.cdiu.university-0003
You won't lose anything of value by running those since you're using manual authentication and no installer.
root@online:/etc/letsencrypt/live# certbot delete online.cdiu.university-12-31-2020
usage:
certbot [SUBCOMMAND] [options] [-d DOMAIN] [-d DOMAIN] ...
Certbot can obtain and install HTTPS/TLS/SSL certificates. By default,
it will attempt to use a webserver both for obtaining and installing the
certificate.
certbot: error: unrecognized arguments: online.cdiu.university-12-31-2020
usage:
certificate.
My fault...
certbot delete --cert-name online.cdiu.university-12-31-2020
certbot delete --cert-name online.cdiu.university-0001
certbot delete --cert-name online.cdiu.university-0002
certbot delete --cert-name online.cdiu.university-0003
root@online:/etc/letsencrypt/live# certbot delete --cert-name online.cdiu.university-12-31-2020
No certificate found with name online.cdiu.university-12-31-2020 (expected /etc/letsencrypt/renewal/online.cdiu.university-12-31-2020.conf).
Deleted all files relating to certificate online.cdiu.university.
root@online:/etc/letsencrypt/live# certbot delete --cert-name online.cdiu.university-0001
Deleted all files relating to certificate online.cdiu.university-0001.
root@online:/etc/letsencrypt/live# certbot delete --cert-name online.cdiu.university-0002
Deleted all files relating to certificate online.cdiu.university-0002.
root@online:/etc/letsencrypt/live# certbot delete --cert-name online.cdiu.university-0003
No certificate found with name online.cdiu.university-0003 (expected /etc/letsencrypt/renewal/online.cdiu.university-0003.conf).
Go ahead and manually remove /etc/letsencrypt/live/online.cdiu.university-12-31-2020
then let's see...
ls -l /etc/letsencrypt/live
ls -l /etc/letsencrypt/archive
ls -l /etc/letsencrypt/renewal
root@online:/etc/letsencrypt/live# rm -Rf online.cdiu.university-12-31-2020
root@online:/etc/letsencrypt/live# ls -l /etc/letsencrypt/live
total 12
drwxr-xr-x 2 root root 4096 Jul 9 02:43 ORIG-online.cdiu.university
-rw-r--r-- 1 root root 740 Jul 9 02:43 README
drwxr-xr-x 2 root root 4096 Oct 8 12:43 online.cdiu.university-0001-ORIG-renewed
root@online:/etc/letsencrypt/live# ls -l /etc/letsencrypt/archive
total 0
root@online:/etc/letsencrypt/live# ls -l /etc/letsencrypt/renewal
total 0
Go ahead and remove these from the live folder too:
root@online:/etc/letsencrypt/live# rm -Rf ORIG-online.cdiu.university
root@online:/etc/letsencrypt/live# rm -Rf online.cdiu.university-0001-ORIG-renewed
root@online:/etc/letsencrypt/live# ls -lrht
total 4.0K
Nice. Now...
certbot certonly --manual -d "online.cdiu.university,www.online.cdiu.university"
root@online:/etc/letsencrypt/live# certbot certonly --manual -d "online.cdiu.university,www.online.cdiu.university"
Congratulations! Your certificate and chain have been saved at:
/etc/letsencrypt/live/online.cdiu.university/fullchain.pem
/etc/letsencrypt/live/online.cdiu.university/privkey.pem
Your cert will expire on 2021-04-01. To obtain a new or tweaked
version of this certificate in the future, simply run certbot
again. To non-interactively renew all of your certificates, run
"certbot renew" -
Donating to ISRG / Let's Encrypt: Donate - Let's Encrypt
Donating to EFF: Support EFF's Work on Let's Encrypt | Electronic Frontier Foundation
Beautiful!
Now...
nginx -s reload
OMG....................... This is great it works
root@online:/etc/letsencrypt/live# nginx -s reload
nginx: [warn] conflicting server name "online.cdiu.university" on 0.0.0.0:80, ignored
nginx: [warn] conflicting server name "www.online.cdiu.university" on 0.0.0.0:80, ignored
nginx: [warn] conflicting server name ".online.cdiu.university" on 0.0.0.0:80, ignored
nginx: [warn] conflicting server name "online.cdiu.university" on [::]:80, ignored
nginx: [warn] conflicting server name "www.online.cdiu.university" on [::]:80, ignored
nginx: [warn] conflicting server name ".online.cdiu.university" on [::]:80, ignored
nginx: [warn] conflicting server name "online.cdiu.university" on 0.0.0.0:443, ignored
nginx: [warn] conflicting server name "www.online.cdiu.university" on 0.0.0.0:443, ignored
nginx: [warn] conflicting server name "online.cdiu.university" on [::]:443, ignored
nginx: [warn] conflicting server name "www.online.cdiu.university" on [::]:443, ignored
Thank you very.... very much
so to renew what should I do? in 2 months?
Yep. Around 60 days should do it. Use this when you do though...
Have a Happy New Year!
Happy new year to you too. This was my celebration fixing this issue
