@schoen
On closer inspection I found out that above quotes are opening and closing type as below.
and not standard ones as below.
The post editor converts standard quotes to smart ones, so added them as pre-formatted text!
@schoen
@schoen, Now is it OK to change to the correct authentication method nginx from standalone in /etc/letsencrypt/renewal?
Also if it is okey, then will I also have to add --renew-hook to load renewed certificates in Nginx?
We usually suggest that people try doing this with certbot certonly --cert-name whatever.org --nginx --force-renewal
(just once) so that Certbot will edit the file for you and you'll immediately see if it worked or not.
If it works and it gets set as both authenticator
and installer
in the file, then you wouldn't need the --renew-hook
because installer = nginx
is able to restart the web server for you.
