Please show this file:
# Virtual Hosts
# If you want to maintain multiple domains/hostnames on your
# machine you can setup VirtualHost containers for them. Most configurations
# use only name-based virtual hosts so the server doesn't need to worry about
# IP addresses. This is indicated by the asterisks in the directives below.
# Please see the documentation at
# <URL:http://httpd.apache.org/docs/trunk/vhosts/>
# for further details before you try to setup virtual hosts.
# You may use the command line option '-S' to verify your virtual host
# configuration.
# Use name-based virtual hosting.
# VirtualHost example:
# Almost any Apache directive may go into a VirtualHost container.
# The first VirtualHost section is used for all requests that do not
# match a ServerName or ServerAlias in any <VirtualHost> block.
# First Virtual Host must be a shallow duplicate of the main host
# in httpd.conf
<VirtualHost _default_:80>
<Directory "C:/laragon/www/">
AllowOverride All
Require all granted
</Directory>
</VirtualHost>
<VirtualHost _default_:8282>
AllowOverride All
Require all granted
</Directory>
SSLEngine on
SSLCertificateFile C:/laragon/etc/ssl/laragon.crt
SSLCertificateKeyFile C:/laragon/etc/ssl/laragon.key
</VirtualHost>
That file is a complete mess!
- It has NO
DocumentRoot
setting.
<VirtualHost _default_:80> <Directory "C:/laragon/www/"> AllowOverride All Require all granted </Directory> </VirtualHost>
I dont know about servers, i like front and backend, but an production app its having problems and i need to run it again
how can i fix it? do you know??
Add this line to that vhost:
DocumentRoot C:/laragon/www/apiapolo2021/public
Like:
DocumentRoot "C:/laragon/www/apiapolo2021/public"
AllowOverride All
Require all granted
</Directory>
</VirtualHost>
The reason is to match what is being looked for:
[[webroot_map]] 642f07948b0f.sn.mynetname.net = C:\laragon\www\apiapolo2021\public
but i have another file named auto.apiapolo2021.test.conf
it contains this:
define ROOT "C:/laragon/www/apiapolo2021/public/"
define SITE "apiapolo2021.test"
<VirtualHost *:80>
DocumentRoot "${ROOT}"
ServerName ${SITE}
ServerAlias *.${SITE}
<Directory "${ROOT}">
AllowOverride All
Require all granted
</Directory>
</VirtualHost>
<VirtualHost *:8282>
ServerName ${SITE}
AllowOverride All
Require all granted
</Directory>
SSLEngine on
</VirtualHost>
There is no vhost to cover the name being requested:
JOSENAVAS46:
My domain is: 642f07948b0f.sn.mynetname.net
As shown by:
VirtualHost configuration: *:80 is a NameVirtualHost default server Laragon (C:/laragon/etc/apache2/sites-enabled/00-default.conf:29) port 80 namevhost Laragon (C:/laragon/etc/apache2/sites-enabled/00-default.conf:29) port 80 namevhost AdmMovilApi.test (C:/laragon/etc/apache2/sites-enabled/auto.AdmMovilApi.test.conf:4) wild alias *.AdmMovilApi.test port 80 namevhost apiapolo2021.test (C:/laragon/etc/apache2/sites-enabled/auto.apiapolo2021.test.conf:4) wild alias *.apiapolo2021.test *:8282 is a NameVirtualHost default server Laragon (C:/laragon/etc/apache2/sites-enabled/00-default.conf:35) port 8282 namevhost Laragon (C:/laragon/etc/apache2/sites-enabled/00-default.conf:35) port 8282 namevhost AdmMovilApi.test (C:/laragon/etc/apache2/sites-enabled/auto.AdmMovilApi.test.conf:14) wild alias *.AdmMovilApi.test port 8282 namevhost apiapolo2021.test (C:/laragon/etc/apache2/sites-enabled/auto.apiapolo2021.test.conf:14) wild alias *.apiapolo2021.test
There is no "642f07948b0f.sn.mynetname.net
" anywhere in that output.
The _default_
would be used to serve from when a name is not matched:
That is why I asked for you to edit that file.
oka, i understand, im going to change that
i put that in the C:/laragon/etc/apache2/sites-enabled/00-default.conf, it look like:
AllowOverride All
Require all granted
</Directory>
</VirtualHost>
AllowOverride All
Require all granted
</Directory>
SSLEngine on
</VirtualHost>
so, can you tell me , whats the next step?
and, thanks, really
<VirtualHost _default_:80> <Directory "C:/laragon/www/"> DocumentRoot "C:/laragon/www/apiapolo2021/public" AllowOverride All Require all granted </Directory> </VirtualHost>
That was NOT what I wrote:
<VirtualHost _default_:80> DocumentRoot "C:/laragon/www/apiapolo2021/public" <Directory "C:/laragon/www/"> AllowOverride All Require all granted </Directory> </VirtualHost>
