My apache on ubuntu 16.04 is configured to serve 5 virtual SSL sites. Each SSL site is in its own .conf apache file.
I removed one site with the usual procedure for apache: a2dissite site2.mydom.com, restart apache, deleted A record for DNS.
But now, at each letsencrypt renew I get a lot of errors:
2017-01-30 20:22:17,158:WARNING:letsencrypt.cli:Attempting to renew cert from /etc/letsencrypt/renewal/site1.mydom.com.conf produced an unexpected error: Failed authorization procedure. site2.mydom.com (tls-sni-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: DNS problem: NXDOMAIN looking up A for site2.mydom.com. Skipping.
Processing /etc/letsencrypt/renewal/site3.mydom.com.conf
/etc/letsencrypt/live/site3.mydom.com/fullchain.pem (skipped)
/etc/letsencrypt/live/site1.mydom.com/fullchain.pem (failure)
Domain: site2.mydom.com
Type: connection
Detail: DNS problem: NXDOMAIN looking up A for site2.mydom.com
How do I correctly remove site2.mydom.com and stop letsencrypt tool to request a certificate for the disabled site site2.mydom.com ?
Thank you.
