Error generating AWS network load balance certificate
Guys I’m having a problem when I’m going to generate a certificate on servers that are behind the Network Load Balance from AWS, if the IP address is directly on EC2 the certificate is generated without any problem, now when I put it on LB I have an error return.
http-01 challenge for site1.domain.com.br
Waiting for verification …
Challenge failed for domain site1.domain.com.br
    Domain: site1.domain.com.br
    Detail: Invalid response from
    https://site1.domain.com.br:443/.well-known/acme-challenge/UzA-shXG8GTmcXyhWHTDzxW222wEmk8zpT7aL0LlJI4
    [54.207.184.139]: "<! DOCTYPE html> \ n \ n \ n
    \ n <meta http-equiv = \ "refresh \" content = \ "0; url = http: // site"
    entered correctly and the DNS A / AAAA record (s) for that domain
    contain (s) the right IP address.
log.
Link: https://acme-staging-v02.api.letsencrypt.org/directory; rel = “index”
Replay-Nonce: 00013A9E4SOBKVg9Vz-SIKwwrOBXUnS2oRqiADt2pr9vy_4
X-Frame-Options: DENY
Strict-Transport-Security: max-age = 604800
“identifier”: {
“type”: “dns”,
“value”: “site1.domain.com.br”
“status”: “invalid”,
“expires”: “2020-07-22T23: 12: 22Z”,
“challenges”: [
“type”: “http-01”,
“error”: {
“type”: “urn: ietf: params: acme: error: unauthorized”,
“detail”: "Invalid response from https://site1.domain.com.br:443/.well-known/acme-challenge/yl0_JIC9oCnRUjZtcZ4T29DDp3uz9IHCPzB_ZfyU5pw [54.207.184.139]: " \ u003c! DOCTYPE html \ n \ u003e \ \ u003chtml \ u003e \ n \ u003eead \ u003e \ n \ u003cmeta charset = \\ “UTF-8 \” / \ u003e \ n \ u003cmeta http-equiv = \\ “refresh \” content = \\ "0; url = http: // site " ",
“status”: 403
“url”: “https://acme-staging-v02.api.letsencrypt.org/acme/chall-v3/77923151/C05xsg”,
“token”: “yl0_JIC9oCnRUjZtcZ4T29DDp3uz9IHCPzB_ZfyU5pw”,
“validationRecord”: [
“url”: “http://site1.domain.com.br/.well-known/acme-challenge/yl0_JIC9oCnRUjZtcZ4T29DDp3uz9IHCPzB_ZfyU5pw”,
“hostname”: “site1.domain.com.br”,
“port”: “80”,
“addressesResolved”: [
“54,207,184,139”
“addressUsed”: “54.207.184.139”
“url”: “https://site1.domain.com.br:443/.well-known/acme-challenge/yl0_JIC9oCnRUjZtcZ4T29DDp3uz9IHCPzB_ZfyU5pw”,
“port”: “443”,
“54,207,184,139”
2020-07-15 20: 12: 28,790: DEBUG: acme.client: Storing nonce: 00013A9E4SOBKVg9Vz-SIKwwrOBXUnS2oRqiADt2pr9vy_4
2020-07-15 20: 12: 28,790: WARNING: certbot.auth_handler: Challenge failed for domain site1.domain.com.br
2020-07-15 20: 12: 28,791: INFO: certbot.auth_handler: http-01 challenge for site1.domain.com.br
2020-07-15 20: 12: 28,791: DEBUG: certbot.reporter: Reporting to user: The following errors were reported by the server:
Detail: Invalid response from https://site1.domain.com.br:443/.well-known/acme-challenge/yl0_JIC9oCnRUjZtcZ4T29DDp3uz9IHCPzB_ZfyU5pw [54.207.184.139]: "<! DOCTYPE html> \ n \ n \ n <meta charset = \ "UTF-8 " /> \ n <meta http-equiv = \ "refresh " content = \ “0; url = http: // site”
Your NLB ports are mismatched.
Port 80 on the NLB should connect to port 80 on your backend.
In your setup, port 80 on the NLB is connecting to port 443 on your backend. That’s where the problem is coming from.
Fix that, and the Certbot authenticator should start working.
perfect observation, I did it quickly and didn’t pay attention to it, thank you very much!
