Error EXT [Making and trusting your own certificates]
localhost
I ran this command (1) :
openssl req -x509 -out localhost.crt -keyout localhost.key -newkey rsa:2048 -nodes -sha256 -subj ‘/CN=localhost’ -extensions EXT -config <(printf “[dn]\nCN=localhost\n[req]\ndistinguished_name = dn\n[EXT]\nsubjectAltName=DNS:localhost\nkeyUsage=digitalSignature\nextendedKeyUsage=serverAuth”)
It produced this output (1):
Error in req
I ran this command (2) :
It produced this output (2):
Error Loading extension section EXT
Windows 10
I use that version of OpenSSL :
Win64 OpenSSL v1.1.1g
https://slproweb.com/products/Win32OpenSSL.html
Hello everybody,
I try to create a self signed certificate but I have this issue. Even if I add an EXT section in the OpenSSL.cnf, it’s not working. Don’t know what I can do.
If someone have the anwser, thanks a lot.
This has nothing to do with Let’s Encrypt.
You might try using a search engine.
“creating a self-signed cert with openssl”
If that doesn’t help…
Try replacing:
with:
-new -days 3650
[use any number of days that you desire and just walk through the prompts]
Hi @JNB_Dimo
that's a Unix command, I don't think that works on Windows.
Looks like try and error. Check the documentation of your OpenSsl.
Where did you find the keyword: EXT ?
Normally I use -reqexts SAN but that may not apply to your case.
Amending the search to:
create a self-signed san cert using openssl in "windows"
I found this link:
Seems the SAN trick is to include the SAN entries in a SAN.cfg file.
