I think it’s fine that way
I’ve checked my page again and I have a lot of errors, for example: https://check-your-website.server-daten.de/?q=gotobot.co
Do you think I should work on them all or?
I would direct my attention to
- “Fatal error: Nameservers mit different SOA Serial Numbers”; and
- “Error - more then one version with Http-Status 200. After all redirects, all users (and search engines) should see the same https url: Non-www or www, but not both with http status 200.”
the others, you choose.
Thanks.
I’m wondering now for my default.conf file does it make sense to write code like this if I want to accept only requests that are sending a proper token?
location = /hotel { rewrite ^ /hotel/ redirect; }
location /hotel {
#proxy_pass http://rasa;
rewrite /hotel/(.*) /$1 break;
proxy_pass http://rasa/webhooks/rest/webhook?token=;
include partials/common.conf;
#include partials/ssl.conf;
Or should I remove “?token=” ?
nginx can’t know if a token is proper. your application needs to send the proper http 4xx error response.
if nginx can proxy_pass
inside a querystring, I don’t know.
So I don’t have to specify the “?token=” and rather send it in post request and accept it with backend logic?
I have no idea. This only has to do with your application.
Rasa has built in auth token param and I just have to add this when running docker-compose up:
rasa run --auth-token thisismysecret
But I do not know how to enable this in config of SSL?
