Error auto renewing my ssl certificate
My domain is: mindmapmaker.org
The operating system my web server runs on is (include version): Centos 9 stream
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 5.5.0
My website's ssl expiry date is less than 29 days. However, there is an error renewing my SSL certificates. Here is the snippet from the log file.
2026-04-10 15:54:47,847:ERROR:certbot._internal.renewal:Failed to renew certificate mindmapmaker.org with error: urn:ietf:params:acme:error:malformed :: The request message was malformed :: No such authorization
2026-04-10 15:54:47,850:DEBUG:certbot._internal.renewal:Traceback was:
File "/var/lib/snapd/snap/certbot/5528/lib/python3.12/site-packages/certbot/_internal/renewal.py", line 715, in handle_renewal_request
main.renew_cert(lineage_config, plugins, renewal_candidate)
File "/var/lib/snapd/snap/certbot/5528/lib/python3.12/site-packages/certbot/_internal/main.py", line 1548, in renew_cert
renewed_lineage = _get_and_save_cert(le_client, config, lineage=lineage)
File "/var/lib/snapd/snap/certbot/5528/lib/python3.12/site-packages/certbot/_internal/main.py", line 131, in _get_and_save_cert
renewal.renew_cert(config, sans, le_client, lineage)
File "/var/lib/snapd/snap/certbot/5528/lib/python3.12/site-packages/certbot/_internal/renewal.py", line 565, in renew_cert
new_cert, new_chain, new_key, _ = le_client.obtain_certificate(sans, new_key)
File "/var/lib/snapd/snap/certbot/5528/lib/python3.12/site-packages/certbot/_internal/client.py", line 434, in obtain_certificate
File "/var/lib/snapd/snap/certbot/5528/lib/python3.12/site-packages/certbot/_internal/client.py", line 494, in _get_order_and_authorizations
orderr = self.acme.new_order(csr_pem, profile=profile)
File "/var/lib/snapd/snap/certbot/5528/lib/python3.12/site-packages/acme/client.py", line 142, in new_order
authorizations.append(self._authzr_from_response(self._post_as_get(url), uri=url))
File "/var/lib/snapd/snap/certbot/5528/lib/python3.12/site-packages/acme/client.py", line 400, in _post_as_get
return self._post(*new_args, **kwargs)
File "/var/lib/snapd/snap/certbot/5528/lib/python3.12/site-packages/acme/client.py", line 461, in _post
return self.net.post(*args, **kwargs)
File "/var/lib/snapd/snap/certbot/5528/lib/python3.12/site-packages/acme/client.py", line 812, in post
return self._post_once(*args, **kwargs)
File "/var/lib/snapd/snap/certbot/5528/lib/python3.12/site-packages/acme/client.py", line 827, in _post_once
response = self._check_response(response, content_type=content_type)
File "/var/lib/snapd/snap/certbot/5528/lib/python3.12/site-packages/acme/client.py", line 699, in _check_response
raise messages.Error.from_json(jobj)
acme.messages.Error: urn:ietf:params:acme:error:malformed :: The request message was malformed :: No such authorization
What is the issue? How can I fix it?
When I run the command manually, ie, certbot renew , it is renewing properly.
Thanks
your site is using new cert just signed an hour ago, so in issue I guess?
I mentioned it. It worked properly, when I ran the command manually. ie, certbot renew
But it gave an error when it was invoked through the timer. It showed error. I have put it in my question. Please check.
that's server side error and we don't know what certbot send as message, so nothing to look at:
This is the error in the log file.
I'd need few lines before error: but from link I linked it looks like LE side DB duplication delay
This is it.
2026-04-10 15:54:47,567:DEBUG:certbot._internal.display.obj:Notifying user: Renewing an existing certificate for mindmapmaker.org and 3 more
2026-04-10 15:54:47,568:DEBUG:acme.client:Requesting fresh nonce
2026-04-10 15:54:47,568:DEBUG:acme.client:Sending HEAD request to https://acme-v02.api.letsencrypt.org/acme/new-nonce.
2026-04-10 15:54:47,619:DEBUG:urllib3.connectionpool:https://acme-v02.api.letsencrypt.org:443 "HEAD /acme/new-nonce HTTP/1.1" 200 0
2026-04-10 15:54:47,619:DEBUG:acme.client:Received response:
HTTP 200
Server: nginx
Date: Fri, 10 Apr 2026 10:24:47 GMT
Replay-Nonce: wN0WXCrxu7XQpnzMghaiLvxAaIrX5DrLJg8VokEOYbXYYmsG2HE
X-Frame-Options: DENY
2026-04-10 15:54:47,620:DEBUG:acme.client:Storing nonce: wN0WXCrxu7XQpnzMghaiLvxAaIrX5DrLJg8VokEOYbXYYmsG2HE
2026-04-10 15:54:47,620:DEBUG:acme.client:JWS payload:
b'{\n  "identifiers": [\n    {\n      "type": "dns",\n      "value": "mindmapmaker.org"\n    },\n    {\n      "type": "dns",\n      "value": "app.mindmapmaker.org"\n    },\n    {\n      "type": "dns",\n      "value": "www.app.mindmapmaker.org"\n    },\n    {\n      "type": "dns",\n      "value": "www.mindmapmaker.org"\n    }\n  ]\n}'
2026-04-10 15:54:47,622:DEBUG:acme.client:Sending POST request to https://acme-v02.api.letsencrypt.org/acme/new-order:
  "protected": "eyJhbGciOiAiUlMyNTYiLCAia2lkIjogImh0dHBzOi8vYWNtZS12MDIuYXBpLmxldHNlbmNyeXB0Lm9yZy9hY21lL2FjY3QvMTQ3MTUwMzYyNiIsICJub25jZSI6ICJ3TjBXWENyeHU3WFFwbnpNZ2hhaUx2eEFhSXJYNURyTEpnOFZva0VPWWJYWVltc0cySEUiLCAidXJsIjogImh0dHBzOi8vYWNtZS12MDIuYXBpLmxldHNlbmNyeXB0Lm9yZy9hY21lL25ldy1vcmRlciJ9",
  "signature": "BVcOQESEkzXc1YC8eFhGkNMvowEY_IGFtP8AGaz2gm1CJTe3MAIItJTLjCPpZKzceRTmNCU6kigrSjIYILbONKKmo8IrH_BzEuDfBQxs-68cMOC8Sw_x4JLy3MkuQARiTQajvx5wg3QAJ2JIIYK2vsA5m4YgsGO4n-HQulIefEF-wRfP-9VMJMkqAvp4u0lLp5xnvgNlwp7xTObq8RFp9Bkguc4Zgmuy1AGT3ME7VOfI8VE-dGbBIVzjH0wKtzv4Q3WLjRuVEEfENC_hwGATP9FGiSApPuDZAXibYUC4bG4lR5XV7AJVEXS0dTco6uHNfKtCk0CNYhMis2NiexLVvw",
  "payload": "ewogICJpZGVudGlmaWVycyI6IFsKICAgIHsKICAgICAgInR5cGUiOiAiZG5zIiwKICAgICAgInZhbHVlIjogIm1pbmRtYXBtYWtlci5vcmciCiAgICB9LAogICAgewogICAgICAidHlwZSI6ICJkbnMiLAogICAgICAidmFsdWUiOiAiYXBwLm1pbmRtYXBtYWtlci5vcmciCiAgICB9LAogICAgewogICAgICAidHlwZSI6ICJkbnMiLAogICAgICAidmFsdWUiOiAid3d3LmFwcC5taW5kbWFwbWFrZXIub3JnIgogICAgfSwKICAgIHsKICAgICAgInR5cGUiOiAiZG5zIiwKICAgICAgInZhbHVlIjogInd3dy5taW5kbWFwbWFrZXIub3JnIgogICAgfQogIF0KfQ"
2026-04-10 15:54:47,816:DEBUG:urllib3.connectionpool:https://acme-v02.api.letsencrypt.org:443 "POST /acme/new-order HTTP/1.1" 201 807
2026-04-10 15:54:47,817:DEBUG:acme.client:Received response:
HTTP 201
Server: nginx
Content-Length: 807
Boulder-Requester: 1471503626
Location: https://acme-v02.api.letsencrypt.org/acme/order/1471503626/499232617081
Replay-Nonce: nkq3kksZulHdJsREClGsIZJYu_8ozUDRvclBkMY6JnWvammYVPo
  "status": "pending",
  "expires": "2026-04-17T10:24:47Z",
  "identifiers": [
      "type": "dns",
      "type": "dns",
      "type": "dns",
      "type": "dns",
  "authorizations": [
    "https://acme-v02.api.letsencrypt.org/acme/authz/1471503626/686008497311",
    "https://acme-v02.api.letsencrypt.org/acme/authz/1471503626/686008497401",
    "https://acme-v02.api.letsencrypt.org/acme/authz/1471503626/686008497481",
    "https://acme-v02.api.letsencrypt.org/acme/authz/1471503626/686008497541"
  "finalize": "https://acme-v02.api.letsencrypt.org/acme/finalize/1471503626/499232617081"
2026-04-10 15:54:47,817:DEBUG:acme.client:Storing nonce: nkq3kksZulHdJsREClGsIZJYu_8ozUDRvclBkMY6JnWvammYVPo
2026-04-10 15:54:47,817:DEBUG:acme.client:JWS payload:
b''
2026-04-10 15:54:47,819:DEBUG:acme.client:Sending POST request to https://acme-v02.api.letsencrypt.org/acme/authz/1471503626/686008497311:
  "protected": "eyJhbGciOiAiUlMyNTYiLCAia2lkIjogImh0dHBzOi8vYWNtZS12MDIuYXBpLmxldHNlbmNyeXB0Lm9yZy9hY21lL2FjY3QvMTQ3MTUwMzYyNiIsICJub25jZSI6ICJua3Eza2tzWnVsSGRKc1JFQ2xHc0laSll1XzhvelVEUnZjbEJrTVk2Sm5XdmFtbVlWUG8iLCAidXJsIjogImh0dHBzOi8vYWNtZS12MDIuYXBpLmxldHNlbmNyeXB0Lm9yZy9hY21lL2F1dGh6LzE0NzE1MDM2MjYvNjg2MDA4NDk3MzExIn0",
  "signature": "nbJroMeMpv_r3qhSRm9zjW43qMGD20U3RL6K-NjM-9nyxHWKHlgVSoqKGdNcBD0CXVrlf7GdFtjVG0FPtn-lUDjPggIBJMnEwpFuU44v0OMFvXkBtaneq9cdfEvC5qarj_1zoQMRaLCA1NcNE1Z-5p9J1bcHBU7s9cE9Sh04HwP2Gsrc9nyZOLlLRZl2U3kQh4cjVUy9ijOd4sFyCyVABmcEdwrllWPoNpnWdrtWEVgaw41G83fsLBoZiA1lm3vFVrbsdWnFuUAkz4T4Oiz1fp2yw8ToAa1AoqDQOaZ3KD0uUafSND_iL1ZKXjvY4jrSot7lmRtdzPZIOyxoydP4ng",
  "payload": ""
2026-04-10 15:54:47,846:DEBUG:urllib3.connectionpool:https://acme-v02.api.letsencrypt.org:443 "POST /acme/authz/1471503626/686008497311 HTTP/1.1" 404 106
2026-04-10 15:54:47,847:DEBUG:acme.client:Received response:
HTTP 404
Server: nginx
Content-Type: application/problem+json
Content-Length: 106
Replay-Nonce: wN0WXCrxrvSJZWTeWkk1ZlH9bnj0vvjXpYD3Ph7PA7ZYtY6AFqU
  "type": "urn:ietf:params:acme:error:malformed",
  "detail": "No such authorization",
  "status": 404
looks like long standing bug at LE side that auth sync get delayed for few seconds: that exact auth get used to make a valid challenge
Yes that is the issue. Timer job failed to generate a certificate. When I run the script manually, it is working fine.
How to fix this?
Thanks
Not yours to fix- someone from LE need to fix. but it's rare enough that not bother to abandon read-only mirrors I guess
Is that because I use 4 domains for a single certificate? I use these 4 domains on a single certificate.
For other domains, I use 2 domains only per certifcate. Those certificates had no issues so far.
Thanks
No. Up to 100 domain names can appear in a Let's Encrypt cert. And many certs have more than than just a few.
Is this "404" error occurring frequently? Because it is a known low-priority problem because it is rare. It might cause a single cert renewal request to fail but the next scheduled renewal would work. That is no different than a random failure due to a comms failure or other outages anywhere. Certbot should be running twice a day to check for renewals.
The "404" bug might cause an initial cert request to fail but repeating it should succeed.
If you are seeing these "404" errors persist that needs further debug.
Why LE team is reluctant to fix this issue?
They reported that this would fix the next time Certbot runs. But that was not happening.
I had this issue some months ago. Certbot renew service would run 2 times a day in my server using SNAP. But even after running continuous renewal process, it always showed the error. My certificate generation was not successful. Then I had to manually run, 'certbot renew' command.
Thats when it worked.
Then, for the next 2 or 3 times, it was running properly.
But the issue again occured on April 10. Next time, if it happens again, I shall provide the complete log files to show that the certifcate generation is not successful even after 2 or 3 retries.
Thanks
Because so far it has only ever been seen very rarely. I explained this already. If it happens to you frequently we need to look at this more.
Yes, please show multiple logs showing the "404" error. If you copy the log file to a .txt file you should be able to upload the file rather than copy/pasting the entire contents. If you have to copy/paste just show the "404" error and a few lines preceding it. Such as I show below
I looked at your cert history and you generally get a cert about every 60 days starting Apr 2025. I see 2025: Apr14, Jun13, Aug13, Oct12, Dec10 and 2026: Feb8, Apr10
You should not see "404" errors as often as you describe. But, Certbot may not renew exactly at the 30 day mark either. The exact timing depends on the ARI (ACME Renewal Info) it receives from the Let's Encrypt server. In the case of a CA revocation event you may even get a renewal much sooner than usual. My point is that you should not assume a "404" error is the reason for any renewal delay. The logs will be very helpful to isolate what is happening for you.
If you have to copy/paste please show starting with the POST to /acme/new-order URL through the "404" response like this:
HTTP 201
Server: nginx
Content-Length: 807
  "identifiers": [
      "type": "dns",
      "type": "dns",
      "type": "dns",
      "type": "dns",
  "authorizations": [
b''
  "payload": ""
HTTP 404
Server: nginx
Content-Length: 106
  "status": 404
