I don't completely understand this code, nor its' purpose:
And I don't see port 3000 in the listening list; So, I'm not sure that has been applied.
@rg305 Rudy may be I found something interestingā¦
inserting in the web browser: http://localhost:80
I get this pageā¦:
But it seems no Apache 2 Service is running:
(base) marco@pc:~ sudo systemctl stop apache2.service
Failed to stop apache2.service: Unit apache2.service not loaded.
(base) marco@pc:~ sudo systemctl start apache2.service
Failed to start apache2.service: Unit apache2.service not found.
(base) marco@pc:~$ sudo apt-get remove apache2
[sudo] password for marco:
Reading package listsā¦ Done
Building dependency tree
Reading state informationā¦ Done
Package āapache2ā is not installed, so not removed
What does it mean?
Actually, it happens the same on the laptop (192.168.1.4) ā¦ so I do not think this is the problemā¦
With this /etc/nginx/conf.d/default.conf :
listen 443 ssl http2 default_server;
server_name ggc.world;
ssl_certificate /etc/ssl/certs/chained.pem;
ssl_certificate_key /etc/ssl/private/domain.key;
ssl_session_timeout 5m;
ssl_protocols TLSv1 TLSv1.1 TLSv1.2 TLSv1.3;
ssl_ciphers EECDH+CHACHA20:EECDH+CHACHA20-draft:EECDH+AES128:RSA+AES128:EECDH+AES256:RSA+AES256:EECDH+3DES:RSA+3DES:!MD5;
ssl_prefer_server_ciphers on;
ssl_session_cache shared:SSL:50m;
ssl_dhparam /etc/ssl/certs/dhparam.pem;
#ssl_stapling on;
#ssl_stapling_verify on;
access_log /var/log/nginx/ggcworld-access.log combined;
add_header Strict-Transport-Security "max-age=31536000";
location = /favicon.ico { access_log off; log_not_found off; }
proxy_pass http://127.0.0.1:8080;
proxy_http_version 1.1;
proxy_set_header Connection "upgrade";
listen 80 default_server;
error_page 497 https://$host:$server_port$request_uri;
server_name www.ggc.world;
return 301 https://$server_name$request_uri;
# https://www.nginx.com/blog/nginx-nodejs-websockets-socketio/
# https://gist.github.com/uorat/10b15a32f3ffa3f240662b9b0fefe706
# http://nginx.org/en/docs/stream/ngx_stream_core_module.html
upstream websocket {
ip_hash;
server localhost:3000;
listen 81;
server_name ggc.world www.ggc.world;
#location / {
location ~ ^/(websocket|websocket\/socket-io) {
proxy_pass http://127.0.0.1:4201;
proxy_set_header X-Forwared-For $remote_addr;
proxy_set_header Host $host;
proxy_redirect off;
# https://stackoverflow.com/questions/40516288/webpack-dev-server-with-nginx-proxy-pass
with vue.config.js :
module.exports = {
// options...
publicPath: '',
devServer: {
host: 'localhost',
and with this webpack.config.js :
"mode": "development",
"entry": [
"src/index.js",
"webpack-dev-server/client?http://" + require("os").hostname() + ":3000/"
"output": {
"path": __dirname+'/static',
"filename": "[name].[chunkhash:8].js"
"module": {
"rules": [
"test": /\.vue$/,
"exclude": /node_modules/,
"use": "vue-loader"
"test": /\.pem$/,
"use": "file-loader"
plugins: [
new BrowserSyncPlugin(
host: 'localhost',
port: 3000,
proxy: 'http://localhost:8080'
reload: false
node: {
__dirname: false,
__filename: false
resolve: {
extension: ['*', '.pem']
devServer: {
watchOptions: {
aggregateTimeout: 300,
poll: 1000
And still get this error message:
GET https://localhost/sockjs-node/info?t=1580397983088 net::ERR_CONNECTION_REFUSED
I donāt know much about your app.
But I do know that ālocalhostā in human terms means āmeā or āIā [the computer conceptual equivalent of āselfā]; So that when any system refers to ālocalhostā it is actually referring to itself.
When you tried the link to https://localhost/sockjs-node/info?t=1580397983088, on which machine was that tested from?
@rg305 Hi Rudy!!
From within ghe PC-Server:
(base) marco@pc:~$ curl -Iki https://localhost/sockjs-node/info?t=1580397983088
HTTP/2 405
server: nginx/1.14.0 (Ubuntu)
date: Fri, 31 Jan 2020 08:19:02 GMT
allow: OPTIONS, GET
(base) marco@pc:~/vueMatters/testproject$ curl -vk https://localhost/sockjs-
GET /sockjs-node/info?t=1580397983088 HTTP/2
Host: localhost
User-Agent: curl/7.58.0
Accept: /
From a laptop:
(base) marco@marco-U36SG:~$ curl -Iki https://ggc.world/sockjs-node/info?t=1580397983088
HTTP/1.1 405 Method Not Allowed
Server: nginx/1.14.0 (Ubuntu)
Date: Fri, 31 Jan 2020 09:34:59 GMT
Allow: OPTIONS, GET
(base) marco@marco-U36SG:~$ curl -vk https://ggc.world/sockjs-node/info?t=1580397983088
GET /sockjs-node/info?t=1580397983088 HTTP/1.1
Host: ggc.world
User-Agent: curl/7.65.2
Accept: /
@rg305 If {"websocket":true,"origins":[":"],"cookie_needed":false,"entropy":1587194190}
why in the browser I get sockjs.js?9be2:1606 GET https://localhost:8080/sockjs-node/info?t=1580462612618 net::ERR_CONNECTION_REFUSED ? I do not understand
The capital "I" in curl -Iki
tries to do a HEAD request.
While your system is only allowing:
Iām sorry, I do not know.
@rg305 Hi Rudy!
In the PC I installed ex-novo Ubuntu 18.04.3 Desktop and I verified that the problem disappeared.
I ran the same tiny webapp in both laptop and pc, and using localhost and the ip-address both from within the laptop/PC and from the other device (PC/laptop) gave no error.
I reported everything here:
According to you, what kind of problems/missing parts/lacking features or whatever the Ubuntu 18.04.4 Server Edition could have compared to the Ubuntu 18.04.4 Desktop Edition?
It would be great if we could give to the Ubuntuās people some hints/suggestions and help in solving this problem.
The problem doesnāt appear to be in any way related to LE, or any acme client, or the certificate that was issued. Sorry, I donāt know how to help you.
