I created a brand new tiny webapp with vue cli, so without adding anything, apart from what the empty vue-cli scaffolding brings:
(base) marco@pc:~/vueMatters/testproject$ npm run serve
> testproject@0.1.0 serve /home/marco/vueMatters/testproject
> vue-cli-service serve
INFO Starting development server...
98% after emitting CopyPlugin
DONE Compiled successfully in 1409ms 8:14:46 PM
App running at:
- Local: localhost:8080
- Network: 192.168.1.7:8080
Note that the development build is not optimized.
To create a production build, run npm run build.
And got this error message : https://drive.google.com/open?id=10GcVFmqNVGRjox3wklJtcrAkIWM3kOp8
“GET https://localhost/sockjs-node/info?t=1580228998416 net::ERR_CONNECTION_REFUSED”
Using firefox as web browser, I get this error message: https://drive.google.com/open?id=1l6USIHrbHl6kBcQtormXplOgx0J653ko
“Cross-Origin Request Blocked: The Same Origin Policy disallows reading the remote resource at https://localhost/sockjs-node/info?t=1580304400023. (Reason: CORS request did not succeed).”
Looking at Mozilla Developer explanation:
"What went wrong?
The HTTP request which makes use of CORS failed because the HTTP connection failed at either the network or protocol level. The error is not directly related to CORS, but is a fundamental network error of some kind.
In many cases, it is caused by a browser plugin (e.g. an ad blocker or privacy protector) blocking the request.
Other possible causes include:
Trying to access an https resource that has an invalid certificate will cause this error.
Trying to access an http resource from a page with an https origin will also cause this error.
As of Firefox 68, https pages are not permitted to access http://localhost, although this may be changed by Bug 1488740.
The server did not respond to the actual request (even if it responded to the Preflight request). One scenario might be an HTTP service being developed that panicked without returning any data.
Checked the TLS Certificates with https://www.digicert.com/help/ :
and the result is:
" TLS Certificate has not been revoked.
TLS Certificate expires soon. The primary TLS Certificate expires on February 28, 2020 (30 days remaining)
Certificate Name matches ggc.world
TLS Certificate is correctly installed "
So may be my nginx configuration has to be improved:
node --version
v12.10.0
npm -v
6.13.6
webpack-cli@3.3.10
Ubuntu 18.04.03 Server Edition
This is the /etc/nginx/conf.d/default.conf :
listen 443 ssl http2 default_server;
server_name ggc.world;
ssl_certificate /etc/ssl/certs/chained.pem;
ssl_certificate_key /etc/ssl/private/domain.key;
ssl_session_timeout 5m;
ssl_protocols TLSv1 TLSv1.1 TLSv1.2 TLSv1.3;
ssl_ciphers EECDH+CHACHA20:EECDH+CHACHA20-
draft:EECDH+AES128:RSA+AES128:EECDH+AES256:RSA+AES256:EECDH+3DES:RSA+3DES:!MD5;
ssl_prefer_server_ciphers on;
ssl_session_cache shared:SSL:50m;
ssl_dhparam /etc/ssl/certs/dhparam.pem;
#ssl_stapling on;
#ssl_stapling_verify on;
access_log /var/log/nginx/ggcworld-access.log combined;
add_header Strict-Transport-Security "max-age=31536000";
location = /favicon.ico { access_log off; log_not_found off; }
proxy_pass http://127.0.0.1:8080;
proxy_http_version 1.1;
proxy_set_header Connection "upgrade";
listen 80 default_server;
error_page 497 https://$host:$server_port$request_uri;
server_name www.ggc.world;
return 301 https://$server_name$request_uri;
# https://www.nginx.com/blog/nginx-nodejs-websockets-socketio/
# https://gist.github.com/uorat/10b15a32f3ffa3f240662b9b0fefe706
# http://nginx.org/en/docs/stream/ngx_stream_core_module.html
upstream websocket {
ip_hash;
server localhost:3000;
listen 81;
server_name ggc.world www.ggc.world;
proxy_pass http://websocket;
proxy_set_header Host $host;
#location /socket.io/socket.io.js {
# proxy_pass http://websocket;
How to improve the nginx configuration?
