Ensuring Renewals Work With Certbot
My domain is: one of over 60
sudo git clone https://github.com/letsencrypt/letsencrypt /opt/letsencrypt
cd /opt/letsencrypt
./letsencrypt-auto --apache -d mydomain
A valid certificate at the time
My web server is (include version): Ubuntu 16.04 LTS
Ubuntu 16.04 LTS
DigitalOcean Inc
I run command when due to expire, ./certbot-auto renew
Please can someone confirm for me what needs to be done to ensure the certificate renewals work as required on 13th Feb.
Do I just need to make sure Cerbot is version 0.30? I have over 60 sites with Cloudflare so is going to be a lot of work disabling the Cloudflare SSL to check the origin server ssl and running LetsDebug to test all sites.
Thanks
As long as you are on 0.28 or higher, and you do not have any explicit challenge preferences set to TLS-SNI-01, you should be fine. You can check for the latter with:
grep -Ri pref_challs /etc/letsencrypt/renewal
The provided command
Provides no results
Thanks for confirming its version 0.28 + I require.
