test1.teide.cz
certbot certonly --standalone -d test1.teide.cz --dry-run
agree in order to register with the ACME server at
https://acme-staging-v02.api.letsencrypt.org/directory
(A)gree/©ancel: a
http-01 challenge for test1.teide.cz
Waiting for verification…
Failed authorization procedure. test1.teide.cz (http-01): urn:ietf:params:acme:error:dns :: During secondary validation: DNS problem: SERVFAIL looking up A for test1.teide.cz - the domain’s nameservers may be malfunctioning
Domain: test1.teide.cz
Type: None
Detail: During secondary validation: DNS problem: SERVFAIL looking
malfunctioning -
Your account credentials have been saved in your Certbot
Certbot standalone 0.31.0
Debian buster
The DNS is provided by a small Czech webhosting company called web4ce.cz. Webserver runs on a different provider but the problem seems to be with DNS.
no
certbot 0.31.0
It seems as if the DNS server does not answer DNS queries from some LE locations but I cannot investigate this properly because the DNS server is managed by the hosting provider. I tried querying it using public recursive resolvers and it seems to work:
$ dig test1.teide.cz @8.8.8.8
; <<>> DiG 9.16.1 <<>> test1.teide.cz @8.8.8.8
;; global options: +cmd
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 52182
;; flags: qr rd ra; QUERY: 1, ANSWER: 1, AUTHORITY: 0, ADDITIONAL: 1
;; OPT PSEUDOSECTION:
; EDNS: version: 0, flags:; udp: 512
;; QUESTION SECTION:
;test1.teide.cz. IN A
;; ANSWER SECTION:
test1.teide.cz. 7199 IN A 37.205.8.125
;; Query time: 30 msec
;; SERVER: 8.8.8.8#53(8.8.8.8)
;; WHEN: Ne dub 19 15:05:21 CEST 2020
;; MSG SIZE rcvd: 59
$ dig test1.teide.cz @1.1.1.1
; <<>> DiG 9.16.1 <<>> test1.teide.cz @1.1.1.1
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 4545
; EDNS: version: 0, flags:; udp: 1452
;; ANSWER SECTION:
test1.teide.cz. 6302 IN A 37.205.8.125
;; Query time: 10 msec
;; SERVER: 1.1.1.1#53(1.1.1.1)
;; WHEN: Ne dub 19 15:05:29 CEST 2020
;; MSG SIZE rcvd: 73
Can you confirm this issue is caused by the DNS server, or provide any details? I could then confront the DNS provider.
