Would you please provide more details? Such as what command or tool are you using to get a certificate?
Currently that domain uses a wildcard certificate from Sectigo not Let's Encrypt.
I see you have many Let's Encrypt certs both wildcard and non-wildcard. You must use a DNS Challenge for the wildcard but the others could use a different method like HTTP Challenge. If using HTTP Challenge there may be problems because your domain redirects HTTP Challenge tests to a different website.
What services does infomaniak provide for you? Are you using one of their tools to get the certificate?
