Domain ssl Expire Issue
My Domain https://uutinensuomi.fi/ show error of ssl will expire in 2 months what Can I do to fix the issue.
This has what to do with Let's Encrypt, exactly? You aren't using a Let's Encrypt certificate for your domain. Any event, that isn't an error, it isn't an issue, and it isn't something that needs to be "fixed." Your certificate will need to be renewed at the appropriate time. How to do that? No idea--I'd suggest you ask whoever's managing that web site for you.
Your domain is proxied at Cloudflare. Cloudflare will manage the certificates it uses at its CDN Edge.
It looks like you are using a Let's Encrypt cert on your Origin Server. And, you renewed it today. Today is still 32 days before expiration. Usually an auto-renew is set for 30 days. Did you manually renew it today not knowing you probably have an auto-renew that would have done that very soon?
If you want more help with that we need more details from you. Please answer as much as you can from the form you should have been shown when posting in Help section. I reposted that form below.
Here is your recent cert history from https://crt.sh
