Domain Blacklisted
Dear @jsha,
It seems like the policy is still in effect. I am still getting “Policy forbids issuing for name” messages in the log file.
Thank you for your help.
Thanks for the reminder @julio_costa - I’ll check on the status.
Hi Jsha,
What should we do if I want to create a certificate on a subdomain, while I don’t owe the TLD. The case is the TLD is owned by the company HQ, they delegate a subdomain to us here.
Please advice!
Thanks
Pavei
HI Pavei,
Is the subdomain blacklisted ? if not, then you should be able to obtain a cert for it.
@julio_costa, thanks to some work from my coworker @cpu, you should now be able to issue for wordpress.cl. Thanks for waiting.
@pavel, if the parent domain is on the high-risk domain list, the owner of that domain will have to request removal.
Hello @jsha
We have some problem in function autossl on cpanel:
10:55:49 AM WARN “ml.by” failed its authorization because of an error: The ACME function “https://acme-v01.api.letsencrypt.org/acme/new-authz” indicated an error: “Policy forbids issuing for name” (400, “Bad Request”, urn:acme:error:rejectedIdentifier).
Can you help us?
Hi @partizanes
What are the domain name(s) you were trying to issue for when you saw this error?
Ah I see now, ml.by
I’ll see what we can do to amend the blocklist to allow you to issue for ml.by.
Hi @partizanes - this should be cleared up now. Please let me know if you still receive a policy error when issuing for this domain.
