After correcting in all the virtual hosts files the path to the certification files Apache could restart
But now I am getting a "non-valid" certificate error form the browser but only for one of the sub-domains :
here is the VirtualHost config :
<IfModule mod_ssl.c>
<VirtualHost *:443>
ServerAdmin web@e-synergisud.fr
ServerName support.e-synergisud.fr
DocumentRoot /var/www/consult-e-syn/public_html
ErrorLog ${APACHE_LOG_DIR}/consult-e-syn_error.log
SSLCertificateFile /etc/letsencrypt/live/support.e-synergisud.fr/fullchain.pem
SSLCertificateKeyFile /etc/letsencrypt/live/support.e-synergisud.fr/privkey.pem
</VirtualHost>
</IfModule>
But the test on : SSL Server Test: support.e-synergisud.fr (Powered by Qualys SSL Labs)
comes back with a "Certificate name mismatch" error
What can I do in order to get it corrected ?
Thanks in advance for your help and advises,
WBR,
Stéphane
JuergenAuer:
apachectl -S
Result in :
AH00526: Syntax error on line 9 of /etc/apache2/sites-enabled/consult-e-syn-le-ssl.conf:
SSLCertificateFile: file '/etc/letsencrypt/live/support.e-synergisud.fr/fullchain.pem' does not exist or is empty
But this config is correct... so what could be wrong here ?
Thanks in advance for your help and advise,
WBR,
Stéphane
With admin sudo apachectl -S
I’ll get :
VirtualHost configuration:
*:443 is a NameVirtualHost
default server support.e-synergisud.fr (/etc/apache2/sites-enabled/consult-e-syn-le-ssl.conf:2)
port 443 namevhost support.e-synergisud.fr (/etc/apache2/sites-enabled/consult-e-syn-le-ssl.conf:2)
port 443 namevhost dev.e-synergisud.fr (/etc/apache2/sites-enabled/dev-e-syn-le-ssl.conf:2)
port 443 namevhost devform.e-synergisud.fr (/etc/apache2/sites-enabled/devform-e-syn-le-ssl.conf:2)
port 443 namevhost devska.e-synergisud.fr (/etc/apache2/sites-enabled/devska-e-syn-le-ssl.conf:2)
port 443 namevhost e-synergisud.fr (/etc/apache2/sites-enabled/e-syn.conf:20)
alias www.e-synergisud.fr
port 443 namevhost formation.e-synergisud.fr (/etc/apache2/sites-enabled/form-e-syn-le-ssl.conf:2)
port 443 namevhost qai.e-synergisud.fr (/etc/apache2/sites-enabled/qai-e-syn-le-ssl.conf:2)
*:80 is a NameVirtualHost
default server support.e-synergisud.fr (/etc/apache2/sites-enabled/consult-e-syn.conf:1)
port 80 namevhost support.e-synergisud.fr (/etc/apache2/sites-enabled/consult-e-syn.conf:1)
port 80 namevhost dev.e-synergisud.fr (/etc/apache2/sites-enabled/dev-e-syn.conf:1)
port 80 namevhost devform.e-synergisud.fr (/etc/apache2/sites-enabled/devform-e-syn.conf:1)
port 80 namevhost devska.e-synergisud.fr (/etc/apache2/sites-enabled/devska-e-syn.conf:1)
port 80 namevhost e-synergisud.fr (/etc/apache2/sites-enabled/e-syn.conf:1)
port 80 namevhost formation.e-synergisud.fr (/etc/apache2/sites-enabled/form-e-syn.conf:1)
port 80 namevhost forum.e-synergisud.fr (/etc/apache2/sites-enabled/forum-e-syn.conf:1)
port 80 namevhost proj.e-synergisud.fr (/etc/apache2/sites-enabled/proj-e-syn.conf:1)
port 80 namevhost qai.e-synergisud.fr (/etc/apache2/sites-enabled/qai-e-syn.conf:1)
ServerRoot: "/etc/apache2"
Mutex default: dir="/var/lock/apache2" mechanism=fcntl
Define: DUMP_VHOSTS
Define: DUMP_RUN_CFG
I cannot see any problem here… @JuergenAuer what do you think about Jürgen ?
What does it mean the entry : default server...
Many thanks in advance for your help and advises,
Kind Regards,
Stéphane
Restarting Apache solved the whole problem !
Many many thanks for your great help @JuergenAuer
Wish you a very pleasant rest of this day
MFG,
Stéphane
system
Closed
August 7, 2019, 1:14pm
25
