Docker Container options-ssl-nginx.conf
My domain is: etniapagana.com
My web server is (include version): Ubuntu20
The operating system my web server runs on is (include version): docker nginx-alpine
My hosting provider, if applicable, is: digital ocean
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): docker certbot/certbot
Hello.
I would like to know if there is any certbot image that include the options-ssl-nginx.conf file?
If not I figured out that I must manually configure ssl parameters in nginx.conf.
Can you confirm that? Why not to include this file into the image (like in any common installation)?
Thanks, Mateo.
Hi @Mateo, and welcome to the LE community forum :slight_smile:
Please do not install certbot on Ubuntu using apt.
Follow the recommended instructions [using snap]:
Certbot Instructions | Certbot (eff.org)
If you use the certbot --nginx plug-in as installer it will create that file and configure your https server block.
If you used another option (like certonly) then certbot only gets a cert and you must configure your https server block. The mozilla configurator can be helpful although I recommend avoiding HSTS and Stapling until you are certain you know what those are.
You didn't show the command you used otherwise we could be more specific.
Unfortunately, as far as I know, that's not possible with Docker, as Certbot and nginx would be running in separate containers.
Perhaps look at a guide like this: Nginx and Let’s Encrypt with Docker in Less Than 5 Minutes | by Philipp | Medium
Or use a dedicated nginx image with certbot combined, then use that the reverse proxy any other services you have (so only the one container is juggling certificates): https://hub.docker.com/r/jonasal/nginx-certbot
You could also consider using Caddy or similar as an ACME aware reverse proxy for your services.
