DNSSEC Not Provisioned in GoDaddy but Required By CloudFlare - Challenges Don't Pass
My domain is:ilesterg.net
I ran this command:/opt/letsencrypt/letsencrypt-auto certonly --standalone -d smtp.ilesterg.net
It produced this output:Saving debug log to /var/log/letsencrypt/letsencrypt.log
tls-sni-01 challenge for smtp.ilesterg.net
Waiting for verification…
Failed authorization procedure. smtp.ilesterg.net (tls-sni-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: DNS problem: SERVFAIL looking up A for smtp.ilesterg.net
    Domain: smtp.ilesterg.net
    Type: connection
    Detail: DNS problem: SERVFAIL looking up A for smtp.ilesterg.net
My web server is (include version): N/A
The operating system my web server runs on is (include version):CentOS Linux release 7.3.1611 (Core), kernel 3.10.0-514.26.2.el7.x86_64
My hosting provider, if applicable, is:Amazon AWS
I’m using a control panel to manage my site (no, or provide the name and version of the control panel):no
http://dnsviz.net/d/ilesterg.net/WWOGMQ/dnssec/
http://dnsviz.net/d/smtp.ilesterg.net/WWOHaA/dnssec/
The domain has a DS record indicating it uses DNSSEC, but it otherwise doesn’t use DNSSEC. Validating resolvers like those used by Let’s Encrypt will not be able to resolve it.
You need to remove the DS record at your registrar. Or enable DNSSEC on the DNS servers (and update the DS if necessary).
(The DS record looks like it’s from Cloudflare, but the domain is currently using GoDaddy nameservers.)
That did it! Thank you very much!
there is a step you have to take with GoDaddy if you enable DNSSEC on CloudFlare Servers
In case it crops up again the instructions can be found here: https://support.cloudflare.com/hc/en-us/articles/213586148-How-to-add-a-DS-record-to-GoDaddy
Andrei
