DNS-script for core-networks-de for certbot-auto
My DNS-provider has an API to change the DNS-entries.
The documentation is under https://beta.api.core-networks.de/doc/
First I have to create an auth-token with my login-credentials. The token is only valid for 1 hour. So every time I need a new own.
How can I run certbot-auto with the API?
Hi @Tjure,
Welcome to the community forum!
Take a look at the manual-auth-hook at https://certbot.eff.org/docs/using.html?highlight=dns. Here’s an example of another client project using it https://github.com/joohoi/acme-dns-certbot-joohoi. As for prompting for credentials each time, you’ll need to determine how to best deploy your login creds to your server.
OK, I don’t really understand much of python.
But I understand that certbot sets two enviroment variables.ā€œCERTBOT_DOMAINā€ and ā€œCERTBOT_VALIDATIONā€
So I can use them in a little bash-script with a few lines of ā€˜curl’ and certbot will wait for the script to end and will try to authenticate.
When getting a wild-card-certificate will the auth-hook run twice, for domain.tld and *.domain.tld?
If you're including both domain.tld and *.domain.tld in the certificate, yes.
Moreover, the second invocation must not delete the TXT record created by the first invocation.
