DNS problem: SERVFAIL looking up A for www.rnelnet.com DNSSEC issue?
So I’ve been having problems renewing my letsencrypt certs for awhile. I’ve read the forum and it seems like it could be a DNSSEC + certbot issue however I’m not able to determine what. When I check out my DNSSEC settings on erisignlabs.com/www.rnelnet.com everything is green.
Can someone help out?
Info filled below
My domain is: rnelnet.com
I ran this command: letsencrypt renew -a standalone
My web server is (include version): apache - I stop the service first
The operating system my web server runs on is (include version): CentOS 7
My hosting provider, if applicable, is: Ovh
I can login to a root shell on my machine (yes or no, or I don’t know):yup
certbot 0.31.0
Here is the full output:
–snip cmd line–
[root@ca renewal]# letsencrypt renew -a standalone
Processing /etc/letsencrypt/renewal/mail.rnelnet.com.conf
Cert not yet due for renewal
Processing /etc/letsencrypt/renewal/rnelnet.com.conf
Plugins selected: Authenticator standalone, Installer apache
http-01 challenge for rnelnet.com
http-01 challenge for www.rnelnet.com
Attempting to renew cert (rnelnet.com) from /etc/letsencrypt/renewal/rnelnet.com.conf produced an unexpected error: Failed authorization procedure. www.rnelnet.com (http-01): urn:ietf:params:acme:error:connection :: The server could not connect to the client to verify the domain :: dns :: DNS problem: SERVFAIL looking up A for www.rnelnet.com, rnelnet.com (http-01): urn:ietf:params:acme:error:connection :: The server could not connect to the client to verify the domain :: dns :: DNS problem: SERVFAIL looking up A for rnelnet.com. Skipping.
Processing /etc/letsencrypt/renewal/www.rnelnet.com.conf
Attempting to renew cert (www.rnelnet.com) from /etc/letsencrypt/renewal/www.rnelnet.com.conf produced an unexpected error: Failed authorization procedure. www.rnelnet.com (http-01): urn:ietf:params:acme:error:connection :: The server could not connect to the client to verify the domain :: dns :: DNS problem: SERVFAIL looking up A for www.rnelnet.com. Skipping.
  /etc/letsencrypt/live/rnelnet.com/fullchain.pem (failure)
  /etc/letsencrypt/live/www.rnelnet.com/fullchain.pem (failure)
  /etc/letsencrypt/live/mail.rnelnet.com/fullchain.pem expires on 2019-10-28 (skipped)
2 renew failure(s), 0 parse failure(s)
   Domain: www.rnelnet.com
   Type:   connection
   Detail: dns :: DNS problem: SERVFAIL looking up A for
   www.rnelnet.com
   Domain: rnelnet.com
   Type:   connection
   Detail: dns :: DNS problem: SERVFAIL looking up A for rnelnet.com
   Type:   connection
   www.rnelnet.com
--end cmd--
Hi @damic
that's curious.
Dnssec-analyzer is happy - DNSSEC Analyzer - rnelnet.com - all is green.
rnelnet.com
Found 6 DS records for rnelnet.com in the com zone
DS=22548/SHA-256 has algorithm RSASHA1-NSEC3-SHA1
DS=22548/SHA-1 has algorithm RSASHA1-NSEC3-SHA1
DS=13689/SHA-256 has algorithm RSASHA1-NSEC3-SHA1
DS=13689/SHA-1 has algorithm RSASHA1-NSEC3-SHA1
DS=13173/SHA-256 has algorithm RSASHA1-NSEC3-SHA1
DS=13173/SHA-1 has algorithm RSASHA1-NSEC3-SHA1
Found 1 RRSIGs over DS RRset
RRSIG=17708 and DNSKEY=17708 verifies the DS RRset
Found 6 DNSKEY records for rnelnet.com
DS=22548/SHA-256 verifies DNSKEY=22548/SEP
DS=13689/SHA-256 verifies DNSKEY=13689/SEP
DS=13173/SHA-256 verifies DNSKEY=13173/SEP
Found 6 RRSIGs over DNSKEY RRset
RRSIG=13173 and DNSKEY=13173/SEP verifies the DNSKEY RRset
rnelnet.com A RR has value 158.69.221.157
Found 3 RRSIGs over A RRset
RRSIG=54965 and DNSKEY=54965 verifies the A RRset
My tool isn't happy - https://check-your-website.server-daten.de/?q=rnelnet.com
rnelnet.com 6 DS RR in the parent zone found
1 RRSIG RR to validate DS RR found
Algorithm: 8, 2 Labels, original TTL: 86400 sec, Signature-expiration: 16.08.2019, 04:30:35, Signature-Inception: 09.08.2019, 03:20:35, KeyTag 17708, Signer-Name: com
• Status: Good - Algorithmus 8 and DNSKEY with KeyTag 17708 used to validate the DS RRSet in the parent zone
0 DNSKEY RR found
Fatal error: Parent zone has a signed DS RR (Algorithm 7, KeyTag 13173, DigestType 1, Digest BzsMTRgckKJvLSG6B7aBGh174mk=), but the destination DNSKEY doesn't exist or doesn't validate the DNSKEY RR set. No chain of trust created.
Fatal error: Parent zone has a signed DS RR (Algorithm 7, KeyTag 13173, DigestType 2, Digest 1gSzvRFXFm5PQGZIqZ4jH/V4m+iDPiS7o6/CWBlrfrE=), but the destination DNSKEY doesn't exist or doesn't validate the DNSKEY RR set. No chain of trust created.
Fatal error: Parent zone has a signed DS RR (Algorithm 7, KeyTag 13689, DigestType 1, Digest WassBSfptVtAbrvBAO1NxN+/cAQ=), but the destination DNSKEY doesn't exist or doesn't validate the DNSKEY RR set. No chain of trust created.
Fatal error: Parent zone has a signed DS RR (Algorithm 7, KeyTag 13689, DigestType 2, Digest lJOUVFQnC6grUIs5hmzLFRqRGUm4EGmchvYnqOAgsZk=), but the destination DNSKEY doesn't exist or doesn't validate the DNSKEY RR set. No chain of trust created.
Fatal error: Parent zone has a signed DS RR (Algorithm 7, KeyTag 22548, DigestType 1, Digest sisr7JxJDj+EcRg/XIwrbBjgDQ4=), but the destination DNSKEY doesn't exist or doesn't validate the DNSKEY RR set. No chain of trust created.
Fatal error: Parent zone has a signed DS RR (Algorithm 7, KeyTag 22548, DigestType 2, Digest 15Vp/8m06P1TrY8FG949H9+V0EtNy7tIEBu0kNInMFg=), but the destination DNSKEY doesn't exist or doesn't validate the DNSKEY RR set. No chain of trust created.
The tool can't find a DNSKEY, so it's impossible to create a chain of trust.
Unboundtest (Letsencrypt uses an unbound-instance with the same configuration) reports the same problem:
https://unboundtest.com/m/A/rnelnet.com/QMD6VJXT
Query results for A rnelnet.com
Response:
;; opcode: QUERY, status: SERVFAIL, id: 37643
;; flags: qr rd ra; QUERY: 1, ANSWER: 0, AUTHORITY: 0, ADDITIONAL: 0
So it can't work.
Looks like your DNSSEC is broken. That blocks Letsencrypt.
So
  • fix your DNSSEC (or)
  • remove the DS in the parent zone
You have the same problem as this thread:
(.com and .edu run on the same DNS infrastructure.)
You're not doing anything invalid, but a corner case in the DNS protocol, and the design of the authoritative and recursive DNS servers involved, means it doesn't work.
$ dig +dnssec +norecurse +bufsize=512 @h.gtld-servers.net. rnelnet.com
; <<>> DiG 9.15.1-Ubuntu <<>> +dnssec +norecurse +bufsize @h.gtld-servers.net. rnelnet.com
; (2 servers found)
;; global options: +cmd
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 31734
;; flags: qr; QUERY: 1, ANSWER: 0, AUTHORITY: 10, ADDITIONAL: 1
;; OPT PSEUDOSECTION:
; EDNS: version: 0, flags: do; udp: 4096
;; QUESTION SECTION:
;rnelnet.com.                   IN      A
;; AUTHORITY SECTION:
rnelnet.com.            172800  IN      NS      ns.rnelnet.com.
rnelnet.com.            172800  IN      NS      ns1.rnelnet.com.
rnelnet.com.            172800  IN      NS      ns2.rnelnet.com.
rnelnet.com.            86400   IN      DS      22548 7 2 D79569FFC9B4E8FD53AD8F051BDE3D1FDF95D04B4DCBBB48101BB490 D2273058
rnelnet.com.            86400   IN      DS      22548 7 1 B22B2BEC9C490E3F8471183F5C8C2B6C18E00D0E
rnelnet.com.            86400   IN      DS      13689 7 2 9493945454270BA82B508B39866CCB151A911949B810699C86F627A8 E020B199
rnelnet.com.            86400   IN      DS      13689 7 1 59AB2C0527E9B55B406EBBC100ED4DC4DFBF7004
rnelnet.com.            86400   IN      DS      13173 7 2 D604B3BD1157166E4F406648A99E231FF5789BE8833E24BBA3AFC258 196B7EB1
rnelnet.com.            86400   IN      DS      13173 7 1 073B0C4D181C90A26F2D21BA07B6811A1D7BE269
rnelnet.com.            86400   IN      RRSIG   DS 8 2 86400 20190816043035 20190809032035 17708 com. r+yL8SjhNyBMOc3aP7DT2VMT+l8uzC6H6zswYMVosJI99SF5k3p/OV/7 uvJlFJVNB3U+5+7SyVOfyr3sC33xt1FdgkCZfquQfJYH99rjwo5wpdzj WqH9SHDq1gh80UzQmvFn0Nvb5WeEKpYeIRBQjpqFAMXiOARLabe/caRY E6A=
;; Query time: 117 msec
;; SERVER: 2001:502:8cc::30#53(2001:502:8cc::30)
;; WHEN: Fri Aug 09 21:52:31 UTC 2019
;; MSG SIZE  rcvd: 508
You can follow the same workaround as given in that thread -- delete some of your DS or NS records, or add even more.
I'd suggest getting rid of the SHA-1 DS records. They're useless for most purposes.
Edit: You could also use DNS servers in a different domain or TLD.
(P.S.: It's not invalid, but your DNSKEY response is huge. You should consider deleting some of them, or using a DNS server that doesn't sign with ZSKs, or using smaller keys, or using ECDSA.)
(P.P.S.: .com is going to start using a bigger ZSK soon. That might inadvertently solve your problem; I haven't done the math to check, though.)
I first attempted to add a bunch, all the DS records that were older which didn’t work.
I then removed all DS records except for the one I just created and then resigned my domain. Waited a few days and everything worked fine.
Weird error. Not enough return data to include the A records when lookup the domain with DNSSEC enable.
Thanks for your help guys.
