DNS problem: SERVFAIL looking up A for rednour.net
My domain is: rednour.net
I ran this command: certbot certonly --webroot --config le-config.ini --non-interactive -d rednour.net -d www.rednour.net
It produced this output: Challenge failed for all domains. Upon looking up the challenge, it showed that it was having trouble getting the A records for my domain name on both the WWW and non-WWW. This is strange because I checked and made sure that the records are available via dig, dnschecker.org, intoDns, and Google Dig. Any ideas if this is a problem with Let’s Encrypt or the DNS provider?
It’s worth noting that I have issued certs for other domins both before and after attempting this domain, which would lead me to believe the issue is somewhere outside of my usage of certbot.
See them below:
https://acme-v01.api.letsencrypt.org/acme/authz-v3/778512045
https://acme-v01.api.letsencrypt.org/acme/authz-v3/778512027
My web server is (include version): Apache 2.4
The operating system my web server runs on is (include version): Amazon Linux 2
My hosting provider, if applicable, is: Amazon Web Services
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot): 0.25.1
Hi @retsdev
there are older checks of your domain, created yesterday - https://check-your-website.server-daten.de/?q=rednour.net
ns
Your name server configuration looks curious. Checking the name servers manual:
D:\temp>nslookup -type=NS rednour.net.
rednour.net nameserver = dns015.c.register.com
rednour.net nameserver = dns177.d.register.com
rednour.net nameserver = dns185.b.register.com
rednour.net nameserver = dns131.a.register.com
Looks like there are different configurations.
Unboundtest doesn't see errors - https://unboundtest.com/m/A/www.rednour.net/BNLJQUBA
That's curious, because Letsencrypt uses an unbound version with the same configuration.
And your dns131.a.register.com is buggy:
Nameserver doesn't pass all EDNS-Checks: dns131.a.register.com: OP100: no result. FLAGS: no result. V1: no result. V1OP100: no result. V1FLAGS: no result. DNSSEC: no result. V1DNSSEC: no result. NSID: no result. COOKIE: no result. CLIENTSUBNET: no result.
May be the reason "dns timeout"
"DNS problem: query timed out looking up A for www.rednour.net
Runs there an old dns software?
PS: There is no older certificate, so it's your first certificate.
Thanks Juergen,
With what you have shared it leads me to think the problem lies with the DNS provider’s namerservers behaving incorrectly. I think the best bet would be to move nameservers and see if that works.
If this is possible, yes, that's the easiest solution.
And yep, two checks - two different answers:
Using raw nslookup:
Using the a.gtld-servers.net, one of the authoritative name servers of the net zone:
D:\temp>nslookup -type=NS rednour.net. a.gtld-servers.net.
(root) nameserver = k.root-servers.net
(root) nameserver = l.root-servers.net
(root) nameserver = m.root-servers.net
(root) nameserver = a.root-servers.net
(root) nameserver = b.root-servers.net
(root) nameserver = c.root-servers.net
(root) nameserver = d.root-servers.net
(root) nameserver = e.root-servers.net
(root) nameserver = f.root-servers.net
(root) nameserver = g.root-servers.net
(root) nameserver = h.root-servers.net
(root) nameserver = i.root-servers.net
(root) nameserver = j.root-servers.net
rednour.net nameserver = dns1.srsplus.com
rednour.net nameserver = dns2.srsplus.com
Both results should be the same.
Correct:
D:\temp>nslookup -type=NS server-daten.de.
server-daten.de nameserver = ns.inwx.de
server-daten.de nameserver = ns5.inwx.net
server-daten.de nameserver = ns4.inwx.com
server-daten.de nameserver = ns3.inwx.eu
server-daten.de nameserver = ns2.inwx.de
versus
D:\temp>nslookup -type=NS server-daten.de. a.nic.de.
Both queries with the same result.
An additional check:
D:\temp>nslookup -type=NS rednour.net. dns1.srsplus.com.
So the name server of the net zone says: dns1.srsplus.com is the name server.
But that name server says: Ask these other ns.
Looks buggy, but I don't know exact, if such a dns configuration is allowed.
There were “unspecified” issues with register.com that have since been resolved and my domain has been validated by Let’s Encrypt.
This was also discussed in
It was a problem with register.com that several people were reporting.
