DNS problem: NXDOMAIN
aap.internal.ames.net
certbot -v certonly --nginx
1: aap.internal.ames.net
Requesting a certificate for aap.internal.ames.net
http-01 challenge for aap.internal.ames.net
Challenge failed for domain aap.internal.ames.net
Domain: aap.internal.ames.net
Type: dns
Detail: DNS problem: NXDOMAIN looking up A for aap.internal.ames.net - check that a DNS record exists for this domain; DNS problem: NXDOMAIN looking up AAAA for aap.internal.ames.net - check that a DNS record exists for this domain
nginx version: nginx/1.18.0
Red Hat Enterprise Linux release 8.5 (Ootpa)
NA
no
certbot 1.26.0
I have verified that forward and reverse entries are in my DNS server.
nslookup aap.internal.ames.net
Server: 172.16.1.1
Address: 172.16.1.1#53
Address: 172.16.1.4
nslookup 172.16.1.4
4.1.16.172.in-addr.arpa name = aap.internal.ames.net.
Hi @zigfreed, and welcome to the LE community forum :slight_smile:
LE can't validate your domain against your personal DNS server.
It must validate it against what the Internet sees/trusts.
Think about it this way...
If anyone could force LE to validate any domain against any DNS server, they could get certs issued for any/every domain on the Internet.
LE come validate me as "bank.com", see that I'm in control of that domain at these private DNS servers
[not the DNS servers that the bank.com domain lists to be authoritative].
So, you would need to put real Internet reachable IPs for your FQDN in the listed authoritative DNS servers for ames.net" before you can validate the certificate request via HTTP:
ames.net        nameserver = ns15.domaincontrol.com
ames.net        nameserver = ns16.domaincontrol.com
Thank you for the feedback. I am looking for a way to secure my internal only websites. :sunglasses:
@zigfreed do you really control ames.net as a whole, or are you just using that because you chose to?
That is, is this an internal name under your own domain, but not visible to the rest of the Internet or is it more of an internal name that you just made up?
In the first case, Let's Encrypt has a possible workaround for you. In the second case, you can't get a publicly trusted certificate for this name at all; it would be against industry rules for any publicly-trusted CA to give that certificate to you, for the reason that @rg305 mentioned before (the certificate is meant to be proof, for anyone, that you are really entitled to use that name, so it can never be a name that you just unilaterally decided to use).
