I’m using acme.sh on my GoDaddy Economy Linux hosting package (no root access). To complicate matters my domain is registered with 1&1.
I’m running acme.sh with:
acme.sh --issue --dns dns_gd -d inviska.com -d www.inviska.com
However, I’m getting the error:
inviska.com:Verify error:DNS problem: NXDOMAIN looking up TXT for _acme-challenge.inviska.com
Here’s the full --debug output from acme.sh:
inviska@n3plcpnl0027 [~/.acme.sh]$ acme.sh --issue --dns dns_gd -d inviska.com -d www.inviska.com --debug
[Fri Apr 13 22:43:06 MST 2018] Lets find script dir.
[Fri Apr 13 22:43:06 MST 2018] _SCRIPT_='/home/inviska/.acme.sh/acme.sh'
[Fri Apr 13 22:43:06 MST 2018] _script='/home/inviska/.acme.sh/acme.sh'
[Fri Apr 13 22:43:06 MST 2018] _script_home='/home/inviska/.acme.sh'
[Fri Apr 13 22:43:06 MST 2018] Using config home:/home/inviska/.acme.sh
https://github.com/Neilpang/acme.sh
v2.7.9
[Fri Apr 13 22:43:06 MST 2018] _main_domain='inviska.com'
[Fri Apr 13 22:43:06 MST 2018] _alt_domains='www.inviska.com'
[Fri Apr 13 22:43:06 MST 2018] ACME_DIRECTORY='https://acme-v01.api.letsencrypt.org/directory'
[Fri Apr 13 22:43:06 MST 2018] DOMAIN_PATH='/home/inviska/.acme.sh/inviska.com'
[Fri Apr 13 22:43:06 MST 2018] Using ACME_DIRECTORY: https://acme-v01.api.letsencrypt.org/directory
[Fri Apr 13 22:43:06 MST 2018] _init api for server: https://acme-v01.api.letsencrypt.org/directory
[Fri Apr 13 22:43:06 MST 2018] GET
[Fri Apr 13 22:43:06 MST 2018] url='https://acme-v01.api.letsencrypt.org/directory'
[Fri Apr 13 22:43:06 MST 2018] timeout=
[Fri Apr 13 22:43:06 MST 2018] _CURL='curl -L --silent --dump-header /home/inviska/.acme.sh/http.header -g '
[Fri Apr 13 22:43:06 MST 2018] ret='0'
[Fri Apr 13 22:43:07 MST 2018] ACME_KEY_CHANGE='https://acme-v01.api.letsencrypt.org/acme/key-change'
[Fri Apr 13 22:43:07 MST 2018] ACME_NEW_AUTHZ='https://acme-v01.api.letsencrypt.org/acme/new-authz'
[Fri Apr 13 22:43:07 MST 2018] ACME_NEW_ORDER='https://acme-v01.api.letsencrypt.org/acme/new-cert'
[Fri Apr 13 22:43:07 MST 2018] ACME_NEW_ACCOUNT='https://acme-v01.api.letsencrypt.org/acme/new-reg'
[Fri Apr 13 22:43:07 MST 2018] ACME_REVOKE_CERT='https://acme-v01.api.letsencrypt.org/acme/revoke-cert'
[Fri Apr 13 22:43:07 MST 2018] ACME_AGREEMENT='https://letsencrypt.org/documents/LE-SA-v1.2-November-15-2017.pdf'
[Fri Apr 13 22:43:07 MST 2018] ACME_NEW_NONCE
[Fri Apr 13 22:43:07 MST 2018] ACME_VERSION
[Fri Apr 13 22:43:07 MST 2018] Le_NextRenewTime
[Fri Apr 13 22:43:07 MST 2018] _on_before_issue
[Fri Apr 13 22:43:07 MST 2018] _chk_main_domain='inviska.com'
[Fri Apr 13 22:43:07 MST 2018] _chk_alt_domains='www.inviska.com'
[Fri Apr 13 22:43:07 MST 2018] Le_LocalAddress
[Fri Apr 13 22:43:07 MST 2018] d='inviska.com'
[Fri Apr 13 22:43:07 MST 2018] Check for domain='inviska.com'
[Fri Apr 13 22:43:07 MST 2018] _currentRoot='dns_gd'
[Fri Apr 13 22:43:07 MST 2018] d='www.inviska.com'
[Fri Apr 13 22:43:07 MST 2018] Check for domain='www.inviska.com'
[Fri Apr 13 22:43:07 MST 2018] _saved_account_key_hash is not changed, skip register account.
[Fri Apr 13 22:43:07 MST 2018] Read key length:
[Fri Apr 13 22:43:07 MST 2018] _createcsr
[Fri Apr 13 22:43:07 MST 2018] Multi domain='DNS:inviska.com,DNS:www.inviska.com'
[Fri Apr 13 22:43:07 MST 2018] Getting domain auth token for each domain
[Fri Apr 13 22:43:07 MST 2018] Getting webroot for domain='inviska.com'
[Fri Apr 13 22:43:07 MST 2018] _w='dns_gd'
[Fri Apr 13 22:43:07 MST 2018] Getting new-authz for domain='inviska.com'
[Fri Apr 13 22:43:07 MST 2018] _init api for server: https://acme-v01.api.letsencrypt.org/directory
[Fri Apr 13 22:43:07 MST 2018] Try new-authz for the 0 time.
[Fri Apr 13 22:43:07 MST 2018] url='https://acme-v01.api.letsencrypt.org/acme/new-authz'
[Fri Apr 13 22:43:07 MST 2018] payload='{"resource": "new-authz", "identifier": {"type": "dns", "value": "inviska.com"}}'
[Fri Apr 13 22:43:07 MST 2018] RSA key
[Fri Apr 13 22:43:07 MST 2018] GET
[Fri Apr 13 22:43:07 MST 2018] url='https://acme-v01.api.letsencrypt.org/directory'
[Fri Apr 13 22:43:07 MST 2018] timeout=
[Fri Apr 13 22:43:07 MST 2018] _CURL='curl -L --silent --dump-header /home/inviska/.acme.sh/http.header -g '
[Fri Apr 13 22:43:07 MST 2018] ret='0'
[Fri Apr 13 22:43:07 MST 2018] POST
[Fri Apr 13 22:43:07 MST 2018] _post_url='https://acme-v01.api.letsencrypt.org/acme/new-authz'
[Fri Apr 13 22:43:08 MST 2018] _ret='0'
[Fri Apr 13 22:43:08 MST 2018] code='201'
[Fri Apr 13 22:43:08 MST 2018] The new-authz request is ok.
[Fri Apr 13 22:43:08 MST 2018] entry='"type":"dns-01","status":"pending","uri":"https://acme-v01.api.letsencrypt.org/acme/challenge/2CshH5BplO3oL5WnY4fyUM5Cj7HMpAlJN476PIml97k/4214131961","token":"4L4mW7MAH_KcVqzhP3hqtnsErrfUQl09OoqAYzZhZp0"'
[Fri Apr 13 22:43:08 MST 2018] token='4L4mW7MAH_KcVqzhP3hqtnsErrfUQl09OoqAYzZhZp0'
[Fri Apr 13 22:43:08 MST 2018] uri='https://acme-v01.api.letsencrypt.org/acme/challenge/2CshH5BplO3oL5WnY4fyUM5Cj7HMpAlJN476PIml97k/4214131961'
[Fri Apr 13 22:43:08 MST 2018] keyauthorization='4L4mW7MAH_KcVqzhP3hqtnsErrfUQl09OoqAYzZhZp0.W1ivMB_eEgMc4wmvkt-XjeKU2EskJvEH7gcp2SdqWh8'
[Fri Apr 13 22:43:08 MST 2018] dvlist='inviska.com#4L4mW7MAH_KcVqzhP3hqtnsErrfUQl09OoqAYzZhZp0.W1ivMB_eEgMc4wmvkt-XjeKU2EskJvEH7gcp2SdqWh8#https://acme-v01.api.letsencrypt.org/acme/challenge/2CshH5BplO3oL5WnY4fyUM5Cj7HMpAlJN476PIml97k/4214131961#dns-01#dns_gd'
[Fri Apr 13 22:43:08 MST 2018] d='www.inviska.com'
[Fri Apr 13 22:43:08 MST 2018] Getting webroot for domain='www.inviska.com'
[Fri Apr 13 22:43:08 MST 2018] _w='dns_gd'
[Fri Apr 13 22:43:08 MST 2018] _currentRoot='dns_gd'
[Fri Apr 13 22:43:08 MST 2018] Getting new-authz for domain='www.inviska.com'
[Fri Apr 13 22:43:08 MST 2018] _init api for server: https://acme-v01.api.letsencrypt.org/directory
[Fri Apr 13 22:43:08 MST 2018] Try new-authz for the 0 time.
[Fri Apr 13 22:43:08 MST 2018] url='https://acme-v01.api.letsencrypt.org/acme/new-authz'
[Fri Apr 13 22:43:08 MST 2018] payload='{"resource": "new-authz", "identifier": {"type": "dns", "value": "www.inviska.com"}}'
[Fri Apr 13 22:43:08 MST 2018] POST
[Fri Apr 13 22:43:08 MST 2018] _post_url='https://acme-v01.api.letsencrypt.org/acme/new-authz'
[Fri Apr 13 22:43:08 MST 2018] _CURL='curl -L --silent --dump-header /home/inviska/.acme.sh/http.header -g '
[Fri Apr 13 22:43:09 MST 2018] _ret='0'
[Fri Apr 13 22:43:09 MST 2018] code='201'
[Fri Apr 13 22:43:09 MST 2018] The new-authz request is ok.
[Fri Apr 13 22:43:09 MST 2018] entry='"type":"dns-01","status":"pending","uri":"https://acme-v01.api.letsencrypt.org/acme/challenge/TEcta4MAANbD4QvFaA7qPXFiOXcoxfSupoou0mDtckM/4214132152","token":"oL72K2fBV8bY3F-Re7ljzb7uj8fYiaSsqI-ibrAM1EQ"'
[Fri Apr 13 22:43:09 MST 2018] token='oL72K2fBV8bY3F-Re7ljzb7uj8fYiaSsqI-ibrAM1EQ'
[Fri Apr 13 22:43:09 MST 2018] uri='https://acme-v01.api.letsencrypt.org/acme/challenge/TEcta4MAANbD4QvFaA7qPXFiOXcoxfSupoou0mDtckM/4214132152'
[Fri Apr 13 22:43:09 MST 2018] keyauthorization='oL72K2fBV8bY3F-Re7ljzb7uj8fYiaSsqI-ibrAM1EQ.W1ivMB_eEgMc4wmvkt-XjeKU2EskJvEH7gcp2SdqWh8'
[Fri Apr 13 22:43:09 MST 2018] dvlist='www.inviska.com#oL72K2fBV8bY3F-Re7ljzb7uj8fYiaSsqI-ibrAM1EQ.W1ivMB_eEgMc4wmvkt-XjeKU2EskJvEH7gcp2SdqWh8#https://acme-v01.api.letsencrypt.org/acme/challenge/TEcta4MAANbD4QvFaA7qPXFiOXcoxfSupoou0mDtckM/4214132152#dns-01#dns_gd'
[Fri Apr 13 22:43:09 MST 2018] vlist='inviska.com#4L4mW7MAH_KcVqzhP3hqtnsErrfUQl09OoqAYzZhZp0.W1ivMB_eEgMc4wmvkt-XjeKU2EskJvEH7gcp2SdqWh8#https://acme-v01.api.letsencrypt.org/acme/challenge/2CshH5BplO3oL5WnY4fyUM5Cj7HMpAlJN476PIml97k/4214131961#dns-01#dns_gd,www.inviska.com#oL72K2fBV8bY3F-Re7ljzb7uj8fYiaSsqI-ibrAM1EQ.W1ivMB_eEgMc4wmvkt-XjeKU2EskJvEH7gcp2SdqWh8#https://acme-v01.api.letsencrypt.org/acme/challenge/TEcta4MAANbD4QvFaA7qPXFiOXcoxfSupoou0mDtckM/4214132152#dns-01#dns_gd,'
[Fri Apr 13 22:43:09 MST 2018] d='inviska.com'
[Fri Apr 13 22:43:09 MST 2018] _d_alias
[Fri Apr 13 22:43:09 MST 2018] txtdomain='_acme-challenge.inviska.com'
[Fri Apr 13 22:43:09 MST 2018] txt='vPRamQ0RJz_dJbq8Fr0xx6q6YooZd7y95JBhdhvtgIo'
[Fri Apr 13 22:43:09 MST 2018] d_api='/home/inviska/.acme.sh/dnsapi/dns_gd.sh'
[Fri Apr 13 22:43:09 MST 2018] Found domain api file: /home/inviska/.acme.sh/dnsapi/dns_gd.sh
[Fri Apr 13 22:43:09 MST 2018] First detect the root zone
[Fri Apr 13 22:43:09 MST 2018] domains/inviska.com
[Fri Apr 13 22:43:09 MST 2018] GET
[Fri Apr 13 22:43:09 MST 2018] url='https://api.godaddy.com/v1/domains/inviska.com'
[Fri Apr 13 22:43:09 MST 2018] timeout=
[Fri Apr 13 22:43:09 MST 2018] _CURL='curl -L --silent --dump-header /home/inviska/.acme.sh/http.header -g '
[Fri Apr 13 22:43:11 MST 2018] ret='0'
[Fri Apr 13 22:43:11 MST 2018] _sub_domain='_acme-challenge'
[Fri Apr 13 22:43:11 MST 2018] _domain='inviska.com'
[Fri Apr 13 22:43:11 MST 2018] Getting existing records
[Fri Apr 13 22:43:11 MST 2018] domains/inviska.com/records/TXT/_acme-challenge
[Fri Apr 13 22:43:11 MST 2018] GET
[Fri Apr 13 22:43:11 MST 2018] url='https://api.godaddy.com/v1/domains/inviska.com/records/TXT/_acme-challenge'
[Fri Apr 13 22:43:11 MST 2018] timeout=
[Fri Apr 13 22:43:11 MST 2018] _CURL='curl -L --silent --dump-header /home/inviska/.acme.sh/http.header -g '
[Fri Apr 13 22:43:12 MST 2018] ret='0'
[Fri Apr 13 22:43:12 MST 2018] Adding record
[Fri Apr 13 22:43:12 MST 2018] domains/inviska.com/records/TXT/_acme-challenge
[Fri Apr 13 22:43:12 MST 2018] data='[{"data":"vPRamQ0RJz_dJbq8Fr0xx6q6YooZd7y95JBhdhvtgIo"},{"data":"g4VG3gpbQbkUUFotrE3QPW-BNPIRKki32TpM8pRHZ4Q"},{"data":"HAHKKfT9gPcfLhAOxJ3idHGgoBUgbs7TVBkCp8cSFUM"},{"data":"YoXXhg6LDd4gJIK8skWdnt8Au05baeKbzAB41DhqA5Y"}]'
[Fri Apr 13 22:43:12 MST 2018] PUT
[Fri Apr 13 22:43:12 MST 2018] _post_url='https://api.godaddy.com/v1/domains/inviska.com/records/TXT/_acme-challenge'
[Fri Apr 13 22:43:12 MST 2018] _CURL='curl -L --silent --dump-header /home/inviska/.acme.sh/http.header -g '
[Fri Apr 13 22:43:13 MST 2018] _ret='0'
[Fri Apr 13 22:43:13 MST 2018] Added, sleeping 10 seconds
[Fri Apr 13 22:43:24 MST 2018] d='www.inviska.com'
[Fri Apr 13 22:43:24 MST 2018] _d_alias
[Fri Apr 13 22:43:24 MST 2018] txtdomain='_acme-challenge.www.inviska.com'
[Fri Apr 13 22:43:24 MST 2018] txt='ie56OlR026_vD3d6qvVMwLrNktz5QCns9X23kh-dSE0'
[Fri Apr 13 22:43:24 MST 2018] d_api='/home/inviska/.acme.sh/dnsapi/dns_gd.sh'
[Fri Apr 13 22:43:24 MST 2018] Found domain api file: /home/inviska/.acme.sh/dnsapi/dns_gd.sh
[Fri Apr 13 22:43:24 MST 2018] First detect the root zone
[Fri Apr 13 22:43:24 MST 2018] domains/www.inviska.com
[Fri Apr 13 22:43:24 MST 2018] GET
[Fri Apr 13 22:43:24 MST 2018] url='https://api.godaddy.com/v1/domains/www.inviska.com'
[Fri Apr 13 22:43:24 MST 2018] timeout=
[Fri Apr 13 22:43:24 MST 2018] _CURL='curl -L --silent --dump-header /home/inviska/.acme.sh/http.header -g '
[Fri Apr 13 22:43:24 MST 2018] ret='0'
[Fri Apr 13 22:43:24 MST 2018] www.inviska.com not found
[Fri Apr 13 22:43:24 MST 2018] domains/inviska.com
[Fri Apr 13 22:43:24 MST 2018] url='https://api.godaddy.com/v1/domains/inviska.com'
[Fri Apr 13 22:43:25 MST 2018] ret='0'
[Fri Apr 13 22:43:25 MST 2018] _sub_domain='_acme-challenge.www'
[Fri Apr 13 22:43:25 MST 2018] _domain='inviska.com'
[Fri Apr 13 22:43:25 MST 2018] Getting existing records
[Fri Apr 13 22:43:25 MST 2018] domains/inviska.com/records/TXT/_acme-challenge.www
[Fri Apr 13 22:43:25 MST 2018] GET
[Fri Apr 13 22:43:25 MST 2018] url='https://api.godaddy.com/v1/domains/inviska.com/records/TXT/_acme-challenge.www'
[Fri Apr 13 22:43:25 MST 2018] timeout=
[Fri Apr 13 22:43:25 MST 2018] _CURL='curl -L --silent --dump-header /home/inviska/.acme.sh/http.header -g '
[Fri Apr 13 22:43:25 MST 2018] Adding record
[Fri Apr 13 22:43:25 MST 2018] data='[{"data":"ie56OlR026_vD3d6qvVMwLrNktz5QCns9X23kh-dSE0"},{"data":"O5iakJ5_915guWZnl1qgwkz40QPmVXfjKvnXR93ctDM"},{"data":"SjppaLspa6DVlki1tLPjrAVoNNK6hOdV877nOG43p1U"},{"data":"wiWDv5CHWXPnJK0xo31WiVaH1uTqYxEE15O4EkovKcE"},{"data":"VY566WSjK_5WX6-D_IC_wp8_Mi2RXzMcsAqJ6N-PKNU"},{"data":"-F_pVfP9zh8omQVIDTaPf2xKn_UzJMeIF_k2lHeJvG4"},{"data":"N4rnjaeZqlw3Y3FmNC-tMggRY39s3ZQm-ZPsiRCT6R0"},{"data":"AGJ-IJNtf4pgtGbtYxhWNi1h4alPghEunKMlHS3D69A"}]'
[Fri Apr 13 22:43:25 MST 2018] PUT
[Fri Apr 13 22:43:25 MST 2018] _post_url='https://api.godaddy.com/v1/domains/inviska.com/records/TXT/_acme-challenge.www'
[Fri Apr 13 22:43:26 MST 2018] _ret='0'
[Fri Apr 13 22:43:26 MST 2018] Added, sleeping 10 seconds
[Fri Apr 13 22:43:37 MST 2018] Sleep 120 seconds for the txt records to take effect
[Fri Apr 13 22:45:38 MST 2018] ok, let's start to verify
[Fri Apr 13 22:45:38 MST 2018] Verifying:inviska.com
[Fri Apr 13 22:45:38 MST 2018] d='inviska.com'
[Fri Apr 13 22:45:38 MST 2018] keyauthorization='4L4mW7MAH_KcVqzhP3hqtnsErrfUQl09OoqAYzZhZp0.W1ivMB_eEgMc4wmvkt-XjeKU2EskJvEH7gcp2SdqWh8'
[Fri Apr 13 22:45:38 MST 2018] uri='https://acme-v01.api.letsencrypt.org/acme/challenge/2CshH5BplO3oL5WnY4fyUM5Cj7HMpAlJN476PIml97k/4214131961'
[Fri Apr 13 22:45:38 MST 2018] _currentRoot='dns_gd'
[Fri Apr 13 22:45:38 MST 2018] url='https://acme-v01.api.letsencrypt.org/acme/challenge/2CshH5BplO3oL5WnY4fyUM5Cj7HMpAlJN476PIml97k/4214131961'
[Fri Apr 13 22:45:38 MST 2018] payload='{"resource": "challenge", "keyAuthorization": "4L4mW7MAH_KcVqzhP3hqtnsErrfUQl09OoqAYzZhZp0.W1ivMB_eEgMc4wmvkt-XjeKU2EskJvEH7gcp2SdqWh8"}'
[Fri Apr 13 22:45:39 MST 2018] POST
[Fri Apr 13 22:45:39 MST 2018] _post_url='https://acme-v01.api.letsencrypt.org/acme/challenge/2CshH5BplO3oL5WnY4fyUM5Cj7HMpAlJN476PIml97k/4214131961'
[Fri Apr 13 22:45:39 MST 2018] _CURL='curl -L --silent --dump-header /home/inviska/.acme.sh/http.header -g '
[Fri Apr 13 22:45:39 MST 2018] _ret='0'
[Fri Apr 13 22:45:39 MST 2018] code='202'
[Fri Apr 13 22:45:39 MST 2018] sleep 2 secs to verify
[Fri Apr 13 22:45:41 MST 2018] checking
[Fri Apr 13 22:45:41 MST 2018] GET
[Fri Apr 13 22:45:41 MST 2018] url='https://acme-v01.api.letsencrypt.org/acme/challenge/2CshH5BplO3oL5WnY4fyUM5Cj7HMpAlJN476PIml97k/4214131961'
[Fri Apr 13 22:45:41 MST 2018] timeout=
[Fri Apr 13 22:45:42 MST 2018] _CURL='curl -L --silent --dump-header /home/inviska/.acme.sh/http.header -g '
[Fri Apr 13 22:45:42 MST 2018] ret='0'
[Fri Apr 13 22:45:42 MST 2018] inviska.com:Verify error:DNS problem: NXDOMAIN looking up TXT for _acme-challenge.inviska.com
[Fri Apr 13 22:45:42 MST 2018] Skip for removelevel:
[Fri Apr 13 22:45:42 MST 2018] pid
[Fri Apr 13 22:45:42 MST 2018] No need to restore nginx, skip.
[Fri Apr 13 22:45:42 MST 2018] _clearupdns
[Fri Apr 13 22:45:42 MST 2018] Removing DNS records.
[Fri Apr 13 22:45:42 MST 2018] txt='vPRamQ0RJz_dJbq8Fr0xx6q6YooZd7y95JBhdhvtgIo'
[Fri Apr 13 22:45:42 MST 2018] d_api='/home/inviska/.acme.sh/dnsapi/dns_gd.sh'
[Fri Apr 13 22:45:42 MST 2018] _d_alias
[Fri Apr 13 22:45:42 MST 2018] First detect the root zone
[Fri Apr 13 22:45:42 MST 2018] domains/inviska.com
[Fri Apr 13 22:45:42 MST 2018] GET
[Fri Apr 13 22:45:42 MST 2018] url='https://api.godaddy.com/v1/domains/inviska.com'
[Fri Apr 13 22:45:42 MST 2018] timeout=
[Fri Apr 13 22:45:43 MST 2018] ret='0'
[Fri Apr 13 22:45:43 MST 2018] _sub_domain='_acme-challenge'
[Fri Apr 13 22:45:43 MST 2018] _domain='inviska.com'
[Fri Apr 13 22:45:43 MST 2018] Getting existing records
[Fri Apr 13 22:45:43 MST 2018] domains/inviska.com/records/TXT/_acme-challenge
[Fri Apr 13 22:45:43 MST 2018] GET
[Fri Apr 13 22:45:43 MST 2018] url='https://api.godaddy.com/v1/domains/inviska.com/records/TXT/_acme-challenge'
[Fri Apr 13 22:45:43 MST 2018] timeout=
[Fri Apr 13 22:45:43 MST 2018] _CURL='curl -L --silent --dump-header /home/inviska/.acme.sh/http.header -g '
[Fri Apr 13 22:45:44 MST 2018] ret='0'
[Fri Apr 13 22:45:44 MST 2018] domains/inviska.com/records/TXT/_acme-challenge
[Fri Apr 13 22:45:44 MST 2018] data='[{"data":"g4VG3gpbQbkUUFotrE3QPW-BNPIRKki32TpM8pRHZ4Q"},{"data":"HAHKKfT9gPcfLhAOxJ3idHGgoBUgbs7TVBkCp8cSFUM"},{"data":"YoXXhg6LDd4gJIK8skWdnt8Au05baeKbzAB41DhqA5Y"}]'
[Fri Apr 13 22:45:44 MST 2018] PUT
[Fri Apr 13 22:45:44 MST 2018] _post_url='https://api.godaddy.com/v1/domains/inviska.com/records/TXT/_acme-challenge'
[Fri Apr 13 22:45:44 MST 2018] _CURL='curl -L --silent --dump-header /home/inviska/.acme.sh/http.header -g '
[Fri Apr 13 22:45:45 MST 2018] _ret='0'
[Fri Apr 13 22:45:45 MST 2018] txt='ie56OlR026_vD3d6qvVMwLrNktz5QCns9X23kh-dSE0'
[Fri Apr 13 22:45:45 MST 2018] d_api='/home/inviska/.acme.sh/dnsapi/dns_gd.sh'
[Fri Apr 13 22:45:45 MST 2018] _d_alias
[Fri Apr 13 22:45:45 MST 2018] First detect the root zone
[Fri Apr 13 22:45:45 MST 2018] domains/www.inviska.com
[Fri Apr 13 22:45:45 MST 2018] GET
[Fri Apr 13 22:45:45 MST 2018] url='https://api.godaddy.com/v1/domains/www.inviska.com'
[Fri Apr 13 22:45:45 MST 2018] timeout=
[Fri Apr 13 22:45:45 MST 2018] _CURL='curl -L --silent --dump-header /home/inviska/.acme.sh/http.header -g '
[Fri Apr 13 22:45:46 MST 2018] ret='0'
[Fri Apr 13 22:45:46 MST 2018] www.inviska.com not found
[Fri Apr 13 22:45:46 MST 2018] domains/inviska.com
[Fri Apr 13 22:45:46 MST 2018] GET
[Fri Apr 13 22:45:46 MST 2018] url='https://api.godaddy.com/v1/domains/inviska.com'
[Fri Apr 13 22:45:46 MST 2018] timeout=
[Fri Apr 13 22:45:46 MST 2018] _CURL='curl -L --silent --dump-header /home/inviska/.acme.sh/http.header -g '
[Fri Apr 13 22:45:46 MST 2018] _sub_domain='_acme-challenge.www'
[Fri Apr 13 22:45:46 MST 2018] _domain='inviska.com'
[Fri Apr 13 22:45:46 MST 2018] Getting existing records
[Fri Apr 13 22:45:46 MST 2018] domains/inviska.com/records/TXT/_acme-challenge.www
[Fri Apr 13 22:45:46 MST 2018] url='https://api.godaddy.com/v1/domains/inviska.com/records/TXT/_acme-challenge.www'
[Fri Apr 13 22:45:47 MST 2018] ret='0'
[Fri Apr 13 22:45:47 MST 2018] domains/inviska.com/records/TXT/_acme-challenge.www
[Fri Apr 13 22:45:47 MST 2018] data='[{"data":"O5iakJ5_915guWZnl1qgwkz40QPmVXfjKvnXR93ctDM"},{"data":"SjppaLspa6DVlki1tLPjrAVoNNK6hOdV877nOG43p1U"},{"data":"wiWDv5CHWXPnJK0xo31WiVaH1uTqYxEE15O4EkovKcE"},{"data":"VY566WSjK_5WX6-D_IC_wp8_Mi2RXzMcsAqJ6N-PKNU"},{"data":"-F_pVfP9zh8omQVIDTaPf2xKn_UzJMeIF_k2lHeJvG4"},{"data":"N4rnjaeZqlw3Y3FmNC-tMggRY39s3ZQm-ZPsiRCT6R0"},{"data":"AGJ-IJNtf4pgtGbtYxhWNi1h4alPghEunKMlHS3D69A"}]'
[Fri Apr 13 22:45:47 MST 2018] PUT
[Fri Apr 13 22:45:47 MST 2018] _post_url='https://api.godaddy.com/v1/domains/inviska.com/records/TXT/_acme-challenge.www'
[Fri Apr 13 22:45:47 MST 2018] _CURL='curl -L --silent --dump-header /home/inviska/.acme.sh/http.header -g '
[Fri Apr 13 22:45:48 MST 2018] _ret='0'
[Fri Apr 13 22:45:48 MST 2018] _on_issue_err
[Fri Apr 13 22:45:48 MST 2018] Please add '--debug' or '--log' to check more details.
[Fri Apr 13 22:45:48 MST 2018] See: https://github.com/Neilpang/acme.sh/wiki/How-to-debug-acme.sh
[Fri Apr 13 22:45:48 MST 2018] url='https://acme-v01.api.letsencrypt.org/acme/challenge/2CshH5BplO3oL5WnY4fyUM5Cj7HMpAlJN476PIml97k/4214131961'
[Fri Apr 13 22:45:48 MST 2018] payload='{"resource": "challenge", "keyAuthorization": "4L4mW7MAH_KcVqzhP3hqtnsErrfUQl09OoqAYzZhZp0.W1ivMB_eEgMc4wmvkt-XjeKU2EskJvEH7gcp2SdqWh8"}'
[Fri Apr 13 22:45:48 MST 2018] POST
[Fri Apr 13 22:45:48 MST 2018] _post_url='https://acme-v01.api.letsencrypt.org/acme/challenge/2CshH5BplO3oL5WnY4fyUM5Cj7HMpAlJN476PIml97k/4214131961'
[Fri Apr 13 22:45:48 MST 2018] _CURL='curl -L --silent --dump-header /home/inviska/.acme.sh/http.header -g '
[Fri Apr 13 22:45:49 MST 2018] _ret='0'
[Fri Apr 13 22:45:49 MST 2018] code='400'
[Fri Apr 13 22:45:49 MST 2018] url='https://acme-v01.api.letsencrypt.org/acme/challenge/TEcta4MAANbD4QvFaA7qPXFiOXcoxfSupoou0mDtckM/4214132152'
[Fri Apr 13 22:45:49 MST 2018] payload='{"resource": "challenge", "keyAuthorization": "oL72K2fBV8bY3F-Re7ljzb7uj8fYiaSsqI-ibrAM1EQ.W1ivMB_eEgMc4wmvkt-XjeKU2EskJvEH7gcp2SdqWh8"}'
[Fri Apr 13 22:45:49 MST 2018] POST
[Fri Apr 13 22:45:49 MST 2018] _post_url='https://acme-v01.api.letsencrypt.org/acme/challenge/TEcta4MAANbD4QvFaA7qPXFiOXcoxfSupoou0mDtckM/4214132152'
[Fri Apr 13 22:45:49 MST 2018] _CURL='curl -L --silent --dump-header /home/inviska/.acme.sh/http.header -g '
[Fri Apr 13 22:45:53 MST 2018] _ret='0'
[Fri Apr 13 22:45:53 MST 2018] code='202'
[Fri Apr 13 22:45:53 MST 2018] Diagnosis versions:
openssl:openssl
OpenSSL 1.0.1e-fips 11 Feb 2013
apache:
apache doesn't exists.
nginx:
nginx doesn't exists.
socat:
socat by Gerhard Rieger - see www.dest-unreach.org
Usage:
socat [options] <bi-address> <bi-address>
options:
-V print version and feature information to stdout, and exit
-h|-? print a help text describing command line options and addresses
-hh like -h, plus a list of all common address option names
-hhh like -hh, plus a list of all available address option names
-d increase verbosity (use up to 4 times; 2 are recommended)
-D analyze file descriptors before loop
-ly[facility] log to syslog, using facility (default is daemon)
-lf<logfile> log to file
-ls log to stderr (default if no other log)
-lm[facility] mixed log mode (stderr during initialization, then syslog)
-lp<progname> set the program name used for logging
-lu use microseconds for logging timestamps
-lh add hostname to log messages
-v verbose data traffic, text
-x verbose data traffic, hexadecimal
-b<size_t> set data buffer size (8192)
-s sloppy (continue on error)
-t<timeout> wait seconds before closing second channel
-T<timeout> total inactivity timeout in seconds
-u unidirectional mode (left to right)
-U unidirectional mode (right to left)
-g do not check option groups
-L <lockfile> try to obtain lock, or fail
-W <lockfile> try to obtain lock, or wait
-4 prefer IPv4 if version is not explicitly specified
-6 prefer IPv6 if version is not explicitly specified
bi-address:
pipe[,<opts>] groups=FD,FIFO
<single-address>!!<single-address>
<single-address>
single-address:
<address-head>[,<opts>]
address-head:
abstract-client:<filename> groups=FD,SOCKET,RETRY,UNIX
abstract-connect:<filename> groups=FD,SOCKET,RETRY,UNIX
abstract-listen:<filename> groups=FD,SOCKET,LISTEN,CHILD,RETRY,UNIX
abstract-recv:<filename> groups=FD,SOCKET,RETRY,UNIX
abstract-recvfrom:<filename> groups=FD,SOCKET,CHILD,RETRY,UNIX
abstract-sendto:<filename> groups=FD,SOCKET,RETRY,UNIX
create:<filename> groups=FD,REG,NAMED
exec:<command-line> groups=FD,FIFO,SOCKET,EXEC,FORK,TERMIOS,PTY,PARENT,UNIX
fd:<num> groups=FD,FIFO,CHR,BLK,REG,SOCKET,TERMIOS,UNIX,IP4,IP6,UDP,TCP,SCTP
gopen:<filename> groups=FD,FIFO,CHR,BLK,REG,SOCKET,NAMED,OPEN,TERMIOS,UNIX
interface:<interface> groups=FD,SOCKET
ip-datagram:<host>:<protocol> groups=FD,SOCKET,RANGE,IP4,IP6
ip-recv:<protocol> groups=FD,SOCKET,RANGE,IP4,IP6
ip-recvfrom:<protocol> groups=FD,SOCKET,CHILD,RANGE,IP4,IP6
ip-sendto:<host>:<protocol> groups=FD,SOCKET,IP4,IP6
ip4-datagram:<host>:<protocol> groups=FD,SOCKET,RANGE,IP4
ip4-recv:<protocol> groups=FD,SOCKET,RANGE,IP4
ip4-recvfrom:<protocol> groups=FD,SOCKET,CHILD,RANGE,IP4
ip4-sendto:<host>:<protocol> groups=FD,SOCKET,IP4
ip6-datagram:<host>:<protocol> groups=FD,SOCKET,RANGE,IP6
ip6-recv:<protocol> groups=FD,SOCKET,RANGE,IP6
ip6-recvfrom:<protocol> groups=FD,SOCKET,CHILD,RANGE,IP6
ip6-sendto:<host>:<protocol> groups=FD,SOCKET,IP6
open:<filename> groups=FD,FIFO,CHR,BLK,REG,NAMED,OPEN,TERMIOS
openssl:<host>:<port> groups=FD,SOCKET,CHILD,RETRY,IP4,IP6,TCP,OPENSSL
openssl-listen:<port> groups=FD,SOCKET,LISTEN,CHILD,RETRY,RANGE,IP4,IP6,TCP,OPENSSL
pipe:<filename> groups=FD,FIFO,NAMED,OPEN
proxy:<proxy-server>:<host>:<port> groups=FD,SOCKET,CHILD,RETRY,IP4,IP6,TCP,HTTP
pty groups=FD,NAMED,TERMIOS,PTY
readline groups=FD,READLINE,TERMIOS
sctp-connect:<host>:<port> groups=FD,SOCKET,CHILD,RETRY,IP4,IP6,SCTP
sctp-listen:<port> groups=FD,SOCKET,LISTEN,CHILD,RETRY,RANGE,IP4,IP6,SCTP
sctp4-connect:<host>:<port> groups=FD,SOCKET,CHILD,RETRY,IP4,SCTP
sctp4-listen:<port> groups=FD,SOCKET,LISTEN,CHILD,RETRY,RANGE,IP4,SCTP
sctp6-connect:<host>:<port> groups=FD,SOCKET,CHILD,RETRY,IP6,SCTP
sctp6-listen:<port> groups=FD,SOCKET,LISTEN,CHILD,RETRY,RANGE,IP6,SCTP
socket-connect:<domain>:<protocol>:<remote-address> groups=FD,SOCKET,CHILD,RETRY
socket-datagram:<domain>:<type>:<protocol>:<remote-address> groups=FD,SOCKET,RANGE
socket-listen:<domain>:<protocol>:<local-address> groups=FD,SOCKET,LISTEN,CHILD,RETRY,RANGE
socket-recv:<domain>:<type>:<protocol>:<local-address> groups=FD,SOCKET,RANGE
socket-recvfrom:<domain>:<type>:<protocol>:<local-address> groups=FD,SOCKET,CHILD,RANGE
socket-sendto:<domain>:<type>:<protocol>:<remote-address> groups=FD,SOCKET
socks4:<socks-server>:<host>:<port> groups=FD,SOCKET,CHILD,RETRY,IP4,IP6,TCP,SOCKS4
socks4a:<socks-server>:<host>:<port> groups=FD,SOCKET,CHILD,RETRY,IP4,IP6,TCP,SOCKS4
stderr groups=FD,FIFO,CHR,BLK,REG,SOCKET,TERMIOS,UNIX,IP4,IP6,UDP,TCP,SCTP
stdin groups=FD,FIFO,CHR,BLK,REG,SOCKET,TERMIOS,UNIX,IP4,IP6,UDP,TCP,SCTP
stdio groups=FD,FIFO,CHR,BLK,REG,SOCKET,TERMIOS,UNIX,IP4,IP6,UDP,TCP,SCTP
stdout groups=FD,FIFO,CHR,BLK,REG,SOCKET,TERMIOS,UNIX,IP4,IP6,UDP,TCP,SCTP
system:<shell-command> groups=FD,FIFO,SOCKET,EXEC,FORK,TERMIOS,PTY,PARENT,UNIX
tcp-connect:<host>:<port> groups=FD,SOCKET,CHILD,RETRY,IP4,IP6,TCP
tcp-listen:<port> groups=FD,SOCKET,LISTEN,CHILD,RETRY,RANGE,IP4,IP6,TCP
tcp4-connect:<host>:<port> groups=FD,SOCKET,CHILD,RETRY,IP4,TCP
tcp4-listen:<port> groups=FD,SOCKET,LISTEN,CHILD,RETRY,RANGE,IP4,TCP
tcp6-connect:<host>:<port> groups=FD,SOCKET,CHILD,RETRY,IP6,TCP
tcp6-listen:<port> groups=FD,SOCKET,LISTEN,CHILD,RETRY,RANGE,IP6,TCP
tun[:<ip-addr>/<bits>] groups=FD,CHR,NAMED,OPEN,INTERFACE
udp-connect:<host>:<port> groups=FD,SOCKET,IP4,IP6,UDP
udp-datagram:<host>:<port> groups=FD,SOCKET,RANGE,IP4,IP6,UDP
udp-listen:<port> groups=FD,SOCKET,LISTEN,CHILD,RANGE,IP4,IP6,UDP
udp-recv:<port> groups=FD,SOCKET,RANGE,IP4,IP6,UDP
udp-recvfrom:<port> groups=FD,SOCKET,CHILD,RANGE,IP4,IP6,UDP
udp-sendto:<host>:<port> groups=FD,SOCKET,IP4,IP6,UDP
udp4-connect:<host>:<port> groups=FD,SOCKET,IP4,UDP
udp4-datagram:<remote-address>:<port> groups=FD,SOCKET,RANGE,IP4,UDP
udp4-listen:<port> groups=FD,SOCKET,LISTEN,CHILD,RANGE,IP4,UDP
udp4-recv:<port> groups=FD,SOCKET,RANGE,IP4,UDP
udp4-recvfrom:<host>:<port> groups=FD,SOCKET,CHILD,RANGE,IP4,UDP
udp4-sendto:<host>:<port> groups=FD,SOCKET,IP4,UDP
udp6-connect:<host>:<port> groups=FD,SOCKET,IP6,UDP
udp6-datagram:<host>:<port> groups=FD,SOCKET,RANGE,IP6,UDP
udp6-listen:<port> groups=FD,SOCKET,LISTEN,CHILD,RANGE,IP6,UDP
udp6-recv:<port> groups=FD,SOCKET,RANGE,IP6,UDP
udp6-recvfrom:<port> groups=FD,SOCKET,CHILD,RANGE,IP6,UDP
udp6-sendto:<host>:<port> groups=FD,SOCKET,IP6,UDP
unix-client:<filename> groups=FD,SOCKET,NAMED,RETRY,UNIX
unix-connect:<filename> groups=FD,SOCKET,NAMED,RETRY,UNIX
unix-listen:<filename> groups=FD,SOCKET,NAMED,LISTEN,CHILD,RETRY,UNIX
unix-recv:<filename> groups=FD,SOCKET,NAMED,RETRY,UNIX
unix-recvfrom:<filename> groups=FD,SOCKET,NAMED,CHILD,RETRY,UNIX
unix-sendto:<filename> groups=FD,SOCKET,NAMED,RETRY,UNIX
I’ve never had a website and I’m completely clueless about such things. I did try to solve the problem by creating a TXT record in the 1&1 DNS settings, but it asks for four fields and I didn’t know what to enter for value:
Type: TXT
Prefix: _acme-challenge
Value: ???
I don’t really know what I’m doing so I’d be grateful for any advice you can offer.
Generally most sites allow you to access them with and without the www. All the examples for acme.sh include both the www and non-www verion, e.g.
